AZ ranch
/ AZ ranch
Eventually there will be windows and vents, but I’m just trying to get it buttoned up for now.
/ AZ ranch #1,443
I'm glad you are your own contractor and we are learning together.
Thinking out loud. I suppose moisture is a precious commodity out in the desert, so if rainfall gets in around the base perimeter, it would probably be a good thing.
Will the internal temps be high enough in the winter to melt snow that lands on top?
/ AZ ranch
You know, I put in French drains and then I waterproofed the outside of the block walls, because that’s what you’re suppose to do.
But with only 12-15 inches of rain per year, I’m not convinced I needed to do either.
So what if moisture gets in. That would be that much less watering I need to do. I guess the French drains with gravel above them is more for keeping water from collecting in the clay soil and expanding enough to affect my wall integrity.
Yes I think the snow will melt unless we get a foot or so, then I’ll scrape it off. Eventually I’ll design some type of curtain to pull across, just under the panels, to provide insulation in winter and to block out the sun if needed on very hot days.
/ AZ ranch #1,445
Water proofing the walls might be a blessing to help keep moisture in. You want it to feel balmy when you go in there. Curtains might need to be reflective and insulated if installed in the interior. Kind of like a sun shade in a car window?
/ AZ ranch #1,447
I mentioned this before, but annual precipitation averages don’t reflect extremes. I have seen Ash Fork get 3’ of snow in one storm and extreme thunderstorm downpours of several inches in a day. Ash Fork is on the uplift of the Coconino Plateau, so some of the Pacific storm fronts can drop surprising amounts of moisture in your area. Be prepared for extremes.
/ AZ ranch #1,448
I'm really curious to see how you water proof the plywood. I've never seen anything like this before and it's going to be interesting to see your finished roof.
/ AZ ranch
Yesterday I had to remove one of the siding panels on the end while I was working inside. At 112, it was just too dang hot in there. I guess I need to get my exhaust fans pronto.
/ AZ ranch
I went to town today to get shingles. After I got back I put the felt paper on the top part. Kind of windy and not very warm (53 degrees), so that was a lot of fun. NOT!
/ AZ ranch
These are the shingles. I just have them laying there to see what it looks like. I haven’t done the felt on the lower part yet.
/ AZ ranch #1,453
Maybe I'm not seeing things correctly, but I'm thinking you need to "tuck" those bottom shingles under the polycarb. Or make a flashing and silicone under the flashing. You have to keep the runoff off of your wood.
/ AZ ranch
Yes, the felt and the shingles will be over the poly on top and under the poly at the bottom. Like I said, I just laid them there to get a feel for how it was going to look.
/ AZ ranch
I needed to finish up the trim on the sides so I could put the drip guard on.
/ AZ ranch
Yes, I used treated wood for the fascia on the lower side.
I will also be putting a gutter on there to collect rain water.
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A60736)
2021 QUALITY...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
