The Life of a Custom Mowing contractor
/ The Life of a Custom Mowing contractor #301
The part that scares me the most about getting into cutting my own hay is all the little parts that can break on a baler. Then they seem to constantly need adjusting and a ton of maintenance. It overwhelms me to think of what it will take to fix it when it's not working properly. Eventually I'll probably go for it, but it's something that I really don't want to get into.
/ The Life of a Custom Mowing contractor #302
Eddie do you have a neighbor out at the farm that might bale it for you?
Cutting any raking equipment is pretty simple compared to a square baler.
If you can deal with rounds they're pretty trouble free as well.
Round balers are definitely less complicated than the newer large square balers, but can still give lots of headaches.
If I were going to buy a large square baler for limited use that would be simple, I’d check out a New Holland D-1000/2000 Or a Hesston 4710/4910.
It’s difficult to do, but it’s best to make the seller show you it can make bales. Buying off the lot is almost a guarantee of you fixing problems, unless the seller will give you a warranty.
/ The Life of a Custom Mowing contractor #304
The bearing didn’t come out. It’s supposed to look that way.
Holy s++t, the cams, levers, bearings. How in the he77 do you even adjust something like that, better yet, who designs it. I consider myself fairley mechanically minded but I would run far away if I had to work on that LOL.
/ The Life of a Custom Mowing contractor #307
The farm that I live on is being split up into 4 pastures for livestock. I don't plan on baling anything here. The farm that I want to do hay is an hour away. That's where the cows are right now, but once I get them here, I'll start removing the mesquite trees and working on getting it ready to bale hay. Option one is to hire a guy to bale it. Current prices are about $30 per bale for them to come there and do all the work. That's better then what I'm paying for hay right now. I might just do that forever and never get into baling it myself, but I hate being dependent on others. They have a way of not always being there when I need them, and their prices will always go up over time. If I decide to buy, I'll probably go to my Massey Ferguson dealer and do a package deal for everything brand new. Somehow, I think that will be more expensive then paying a guy $30 a bale. Maybe I'll get lucky and find somebody that wants to bale it and split the bales so I get what I need for free, and he takes the rest away. It's still a few years away, so I'm just in the thinking stage more then anything else.
/ The Life of a Custom Mowing contractor #308
I had assumed that it was your brothers place but was unaware that you planned on eventually bringing them home.
Farming isn't a cheap hobby especially with the price of the machinery. Even small "entry level" equipment is in the same category of stupid as pickup trucks. 😆
Did a little bale loading today. Always nice when you can stack 4 layers tall.
Mowed for about 10 hours until almost dark. Got about 30 cut yesterday and 40 today.
The days are getting shorter here in PA. Maybe 3 more weeks left of haying weather.
Fields are really beautiful this time of year.
/ The Life of a Custom Mowing contractor #310
The dew is so heavy here now it would keep hay to wet to bale till late afternoon, and anything that gets shaded early or late is likely to never get dry, silage time.
I, too am experiencing that drudgery.
One of my larger field mowing customers needed to be mowed so I took precious time off hay and spent 6 hours cutting their fields. Really had to go fast to get done. September is one of those months where you really have to push.
Hauled a load of biscuits in this morning, then made another 45 this afternoon.
Here‘s a baler code you’d rather not see on your monitor. Knotter motor fault. Luckily I was able to get it working.
Once I got going again, mostly a smooth afternoon. Although knotter #6 broke its’ twine and I had to re-thread the twine back to the knotter.
Here I am stacking bales at dusk.
/ The Life of a Custom Mowing contractor #314
If those are your biscuits, I'd like to see the skillet you make your gravy in!😝
Gettin it done HD👍
/ The Life of a Custom Mowing contractor #315
Has anybody tried to buy any of your giant square bales to build a house with? I think that houses built out of hay bales is a crazy idea, and crazy people are always looking for something crazier then what they did the last time.
So today started off fine. Stacked a bunch of bales in fields baled earlier in the week. This is a way of keeping busy until the sun burns off the morning dew.
About 12 I headed up to our current customers site and began raking for about 2 hours. By 2 I was ready to bale. Made a few bales, then got an error code. All 6 bale strings broke on the tie cycle. This has NEVER happened to me with this baler. Usually this means the bar that controls all the twine fingers has broken or twisted.
Here you can see the twine fingers are not all aligned the same direction Under the knotters. They all need to be in alignment.
I tried to do a couple manual tie cycles and see if it would clear and watch the twine fingers at the same time. They were jammed. I spent the next 2 hours of precious afternoon sun messing with it. Each time it mis-tied, I had to manually thread the top 6 knotters and bottom 6 needles. I took out a pry bar and tried to manually roll the bar that controls the twine fingers back.
I was on my last few tries, said a little prayer and asked my maker for some help. Low & behold, the twine fingers reset themselves.
Below you can see the twine fingers are all in the “home” position and all swung to the right.
I still don’t know what broke, or what I fixed. LOL. Sometimes you get the bear. Sometimes the bear gets you, right?
Well, I ended up finishing with a nice 20MPH breeze and got the fields all baled. Thank the Lord because tomorrow we are getting a tropical cyclone (Whatever that is) with 6” of rain.
Here I am rounding up and stacking bales at dusk again. I need a beer (or 12). ;)
/ The Life of a Custom Mowing contractor #317
Wow, those knotters make me shudder! Is that 4 hydraulic motors per knotter? Suddenly the old round baler with the manually guided twine feed seems not to bad! But I think you might be still baling if your used that, as I don't think it comes close the tonnage per hour the big square baler does when its happy... Interesting though to see the insides of a big square baler.
You can climb down inside the baler to fix things, there’s plenty of room. You can stand up inside the feed chamber and nobody would know you are in there Lol
I spent 8 hours in the baler trying to clear a jamb. :(
When it’s running properly, you can rake 3 rows together and it will eat them at 5-6 MPH for several hours.
We can bale 40 acres easily in 6-7 hours and make 60 tons. There’s just a few more “uh-ohs” than I’d like to have.
2014 18ft. Top Hat T/A Trash Trailer (A60352)
2014 18ft. Top Hat...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2014 Dodge Ram 4500 Versalift Bucket Truck (A60352)
2014 Dodge Ram...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
