dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,727
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
An upgrade to the pump would be to lower flow unit, not higher. This would make the machine less jerky, as I discussed above. The boom, dipper, bucket, and house all move plenty fast now.So, has anyone upgrade their Pump yet? I figure there is room for more flow.
18L/m @ 2300 PSI only requires around 4.7hp, where a 23L/m pump from say a 1600 machine is only 6hp. And it shows with the likes of a Diggit 15, still running the same 13.5hp B&S
I do not know the size of the pump in the Diggit, but it looks larger than the 6.8cc units found in most of the 1-ton minis. Some of the flow goes to the servos, however.
With a 6.8 cc pump, the gasoline engine, running at 3000RPM, will put out about 5.4 GPM. Below 3000RPM, the engine will bog as it does not make much power at lower revs.
If you think you have plenty of power, then crank up the RV pressure to 2600 or more psi.
