Anyone Found a Heavier-Duty Throttle Return Spring?
/ Anyone Found a Heavier-Duty Throttle Return Spring? #1
nobbyv
Member
NH
Long 360DTC
A stick mangled the throttle return spring on my Landtrac 360DTC. Parts for this machine are a bit tough to track down, so I've tried two different Dorman throttle return springs from the auto parts store, and neither has been 'strong" enough: the throttle sometimes gets stuck. Anyone found a Dorman or other generic spring that has a bit more tension/strength for use on a tractor?
/ Anyone Found a Heavier-Duty Throttle Return Spring? #2
Some of the strongest springs are for trapolins. I bet its overkill for your use.
10 TON HYD JACK (A62131)
10 TON HYD JACK...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL4DL295841 (A61165)
INOP/NON-RUNNING...
Pat's QH and hydraulic top-link.
Pat's QH and...
2015 Ford F750 Dump Truck (A64047)
2015 Ford F750...
BUNDLE OF ASSORTED LUMBER (A62131)
BUNDLE OF ASSORTED...
UNUSED CFG INDUSTRIAL MX15RX MINI EXCAVATOR (A62130)
UNUSED CFG...
