House Build 2023
/ House Build 2023 #81
The water department only inspects the hookup at the meter and electric says they only need a foot of separation. I did send pics to the Entergy engineer assigned to my project and the inspector for the water department before I covered the trench and they both said they were good with it.
The reason they want it in separate ditches in my area is because a water break will flood the ditch and it could be extremely dangerous to fix that water line with the high voltage line in the same, flooded ditch. Off the top of my head, I believe they want two feet of virgin, undisturbed soil between the ditches.
/ House Build 2023
As big of a headache as it was to make that trench, I almost think I would just re-do the whole water line in a different spot, with a trencher if I ever get to the place where I need to dig it up. It does also scare me a little thinking about digging with primary voltage that close. That is another one of those hindsight things. But, it's done now.
/ House Build 2023 #83
A couple of more comments. Daughter's home was built by feller who had been building for 50 years. 2x6 walls. Filled with standard fiberglass batt. Osb, Wrapped,and hardy siding. Well over a foot of blown cellulose, I didn't measure, but it's at least that. One thing I liked, was before they sheetrocked the walls, every hole that was drilled foe electric work was foamed. Every hole in walls was foamed. Flex duct. Indoor unit is in mechanical room with the WH. Inside. Not in the garage and dang sure not in the attic. If the AC contractor wants to put the refrigerator unit and blower in the attic, find another guy. You'll lose 10% of your heating and cooling doing that plus with all this stuff having electronic minds, heat kills circuit boards fast. Yes, from experience.
Mini split is fine in the attic room. You can control and program them to only come on when you want it cool or warm. Cost is fine. And I'd stay with the 14 seer. You will take 50 years to recoup the 10k.
/ House Build 2023 #84
I don't see an issue with water lines and power in the same trench. Around here it's done all the time for irrigation center pivots. Water on one side of a 3 foot trench and power on the other. If you have to repair anything there is a disconnect at the main power line before it goes underground. Surely you would shut that off before doing any kind of work on either the water or power line.
Meters in this area. Urban has their meters on the house and rural has them on the transformer pole.
/ House Build 2023 #85
Yep, last 25 feet of trench has both water and power. Power came from different direction and met up with water line. Zero issues
/ House Build 2023
Let's keep this thread going. How about some footers? I realized I didn't get many pictures of this stage... Whoops.
I hired a surveyor to lay it all out, a crew came in and excavated, then a crew came in to tie rebar, set forms for the height steps, and set height markers. I was surprised at how much fall the site has and I was equally impressed the crew stepped the footers up and down by 1 block increments based on the fall of the land. That saved me a bunch of blocks. there were a total of 3 different heights/ steps, and they came out exactly a block height.
Then a crew came in and poured. It took 38 yards of concrete. That is way more than I would have imagined. After that cured the surveyor came back and marked all the outside corners with nails.
/ House Build 2023 #87
I've never heard of surveyor's being used to lay out a house. Is it expensive to hire them to do this?
/ House Build 2023 #88
That’s how almost everyone does it in my area. It’s $500-800 depending on the size and number of piers for them to set the dig stakes and come back and set nails for the block.
/ House Build 2023 #89
View attachment 818361View attachment 818366View attachment 818362
View attachment 818363View attachment 818364
I guess the more the better but that is a lot of concrete. I usually use a 18” bucket for economical houses and a 2ft bucket for houses with brick. It looks like they used a 3 foot bucket.
/ House Build 2023
4570Man has it about right for my area too. As many twists and turns as this house has, I can't imagine it would have been any cheaper to put up batter boards and pull strings.
I did not measure the trench but I think it was a 2' bucket. Those blocks are 8" wide if I remember correctly and it looks like the footer is about 3 blocks wide.
/ House Build 2023
So, I'm not exactly up to real time with this post. Here are some blocks for your enjoyment.
A crew came out to start laying and got rained out so they set up the layout and staged some blocks.
I got a text at work from my small child that "people are here". By the time I got home for lunch they had already finished and were packing up. They couldn't have been there more than 3-4 hours.
/ House Build 2023 #92
It's truly amazing what an experienced crew can get done in such a short amount of time!!!!
/ House Build 2023 #93
It takes forever to put up batter boards especially with any hill involved. And if you messed up you could spend thousands fixing it. It’s well worth the money for the surveyor to do it IMO.
/ House Build 2023
I think that got us to around the 4th of July.
And a break to plant an apple tree. I decided against the shovel...
/ House Build 2023
Next was filling the foundation in with sand. I should have done this part myself, could have saved a couple thousand on this step. But, not having experience I thought there was more to it. The block layers just left out a couple of areas to give the dump truck a way in. Dump trucks brought material, the dirt guy used a mini X to move the sand around to course grade then walked a little D4 dozer up to compact and do the bulk of the fine grading, then it was rakes.
Looks like quite a few pieces of equipment out here...
Gaps in the blocks
Good and level.
Cleaned back out for the block layers to fill back in.
/ House Build 2023
This is the real reason I was a little miffed about paying someone to grade the foundation... It was a wasted effort. The plumbers left it as bad as if it was never leveled in the first place! The first thing they did was dig a bunch out of the garage area to pile on top of the blocks to get their mini x on top. Then dug another big area out for material to pile onto another set of blocks to get it into the house.
At least the plumbing looks good though. It passed inspection with no more than a cursory glance. Inspector was out of his truck no more than 30 seconds.
Oh, and I forgot to show the safe room in the post above. Blocks go all the way down to the footer with re-bar up in the blocks that is poured into the footer.
/ House Build 2023 #98
Gaps in the blocks
Good and level.
Slab houses aren’t a big thing in my area but I’ve built 2. The first time I graded the area slick and accurate to grade. And the same thing happened that the plumber made a big mess. Also the added volume from the pipe required material to be removed. From that experience I decided to just dump the material in the best I could with the skid steer and not rake anything and also leave it several inches low. Then do the final grade work after the plumbing is done.
/ House Build 2023 #99
If I ever get around to buying property and building our retirement home, I plan to hire Eddie Walker as a consultant :) I'm always amazed at the little nuances that Eddie chimes in with that make perfect sense and can only be learned by "been there, done that". The 42" door is a prime example.
We have some friends in OK that built their retirement home. The main structure of the house is actually (3) Morton Building barn packages. Their house design is about 100% perfection as anything I could have ever dream up. In fact, when we visited them the other week, they gave us their plans to copy. Like others, I want my Master bedroom closet to connect directly to the laundry/utility room and I want that Laundry/Utility room to have a door to the outside, so I have access to the garden and a clothesline. Our friends did a massive utility room/laundry room that even slopes to a central floor drain. The entire room serves as a laundry, farmers kitchen, which could also allow game processing if you put a stainless table in the center and/or you could grow indoor hydroponics against one of the walls. Attached to this room, they have a big walk-in pantry, that I'd reconfigure as a walk-in gun safe, storm shelter. It's a really well-designed house layout.
/ House Build 2023 #100
I've been really impressed with everything that has been done to build your house so far until I saw the wire mesh. Technically, wire is stronger then rebar at holding concrete together. Concrete will always crack, but the goal is to minimize it. Two ways to do this is using as little water as possible in the mix, and reinforcing it with metal, like rebar.
For the rebar to work, it needs to be on chairs so it's at 1/3 up from the bottom, to the middle of the slab. The same applies for wire, but since it's impossible to walk on wire while spreading it, the biggest lie in construction is told over and over again. We'll pull it up while spreading the concrete. And for the first half hour, they do this for pictures, but then they get too busy spreading the concrete, and quite pretending. I've seen crews where a guy was supposed to just pull up the wire, but he never makes it through the entire pour. Even worse, when they do play that game, and pull up the wire, they walk on top of the wire and push it back down again.
100% of ever slab done with wire ends up with the wire under the slab.
The main reason to use wire is it's easier. No tying, no bending, and a lot less physical work. Guys who do this also tend to add too much water to the mix. You have to be there to make sure they don't add extra water. Water creates volume, when that volume evaporates, you are left with a solid mass that has to deal with losing all that volume. This is why concrete cracks!!!! The less water it has to evaporate, the fewer the cracks. In a perfect pour, the cracks are all so fine and minor that it's almost impossible to see them. In a wet pour, the cracks can be massive!!!!
Cracking from a lack of compaction will take a decade to happen, and even then, it's pretty rare. Cracking from too much water is very very common.
If the concrete is flowing like liquid when they pour it, you have too much water. It should slump. It should pile up on itself and not want to flow. This is where all the work is, spreading concrete that doesn't want to spread is very hard work. Adding water so it flows easily is ten times easier for them. If you have a lazy crew, they will add water. It spreads easier, it finishes easier, and they are out of there sooner. The cracks will start in a few days, long after they are gone. And then you just have to live with it.
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
Mini Universal Land Plane (A65640)
Mini Universal...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
