trail clearing technique and tools
/ trail clearing technique and tools #1,081
I was using that style of pole saw but a different brand. I hated paying for the Echo PF225, but it just cuts better than what I was using. Part of it is because the oil mechanism does a better job of lubricating the chain so it stays sharper longer and cuts better. The other thing I like is the Echo uses regular chain, not the smaller proprietary chain.
/ trail clearing technique and tools #1,082
I use the small Stihl battery pole saw and like it much better than the heft of the gasser but the gasser also extends.
Over the weekend we hiked in to some bridges on the North Country Trail we've not been to since they were new. These are built from Corten steel and installed around 2003. They were around 80 to 100ft long, built in two sections and had no concrete used that we could see. There are two of them so don't let the photos fool you. The fellow is a through hiker we chatted with while there.
I was out on my trails today cutting the droopy branches (heavy snow last winter). I giotta say I don't love pole saws as much as Arly. That much over the shouder stuff is fatiguing.
I've carried these units all day on a few occasions. (not all that much fun :oops: ) I do carry these on my shoulder but will switch to hands now and then. Must give shoulder a break!
The telescoping type pole-saws are awful. Waaaay to heavy to use for more than a few minutes.
Was again stung by a wasp yesterday which might have been the 5th time this year. It still hurts 12 hours later. These stings might be catching up on me.
/ trail clearing technique and tools #1,088
They get so aggressive when it cools down a bit.
My trails can wait for <50 degrees to maintain.
But I miss working on them and using them. Other projects have taken priority, but later in the fall I intend to clean the fallen Ash trees out and rope the branches on the ones that havn't fallen yet and make the trails dangerous.
You'd think with all the storms we've had that they would have all fallen by now, most have been dead for 2 years or so.
You must mean "less aggressive when it cools" ?
/ trail clearing technique and tools #1,090
I’m getting more allergic to wasp stings as I get older. No restricted breathing yet but last time I got stung on the side of my head I was breaking out in hives. Benadryl helps me with the stings but makes me tired too,
/ trail clearing technique and tools #1,091
I'm an amateur bee keeper and get stung quite a bit in that endeavor. I would rather get stung 5x by bees that once by a wasp. Don't know what it is, a wasp can just land on me and not even sting and I swell up and start hurting. Wasps are jerks!
I took some benadryl last night and it put me right asleep!
/ trail clearing technique and tools #1,093
OUch!
My wife got stung by a yellow jacket a couple weeks ago. Nest was in a flower bed she was weeding. Told me to stay away from it, so I did. I got stung the next day by one from another nest in the ground about 25' away. OUch!
Then Saturday, I was cleaning up our grilling area and move the grill cover, which has been folded up all summer. Another yellow jacket nest in that! I saw them and ran into the house. 5 seconds later, I got stung on the back of my neck! Two of them followed me into the house! :ROFLMAO:
Seems that weve been having a banner year for wasps here this summer. Gosh its no fun to try keep an eye out for them all the time at work! I've not been taking much for pics but I've been brushing back a yard which is not much to see anyway.
/ trail clearing technique and tools #1,095
Not too bad this year… hardly any but it varies greatly.
/ trail clearing technique and tools #1,096
Also tested a new steel cutting blade for small tress reputed to "can cut thousands acres of trees with". When we cut small trees, there are hundreds of them. That means when you cut one, it falls over and keeps you from seeing others. Keep cutting along as best you can and visibility goes further down and trees you think we cut, are actually 90% off and can't be removed.
Conclusion. Limited use when have a thick growth of trees to remove. Limited usability at best.View attachment 817143View attachment 817144
How do you clear trees in those situations.
Loppers. I can and do use the steel blade but the trees then need to be smaller, upright and few of them not packed together. Not "thousands of acres cleared" as some claim. I'll try to get pics sometime.
/ trail clearing technique and tools #1,098
The good thing about loppers is they can cut close to the ground and don't get dulled by dirt like trying to cut with a chainsaw. Plus there's no noise and no having to start a chainsaw not to mention being safer to operate.
They do dull in dirt but are easy to resharpen. I did promise to do a post about doing that........ :unsure:
2019 Chevrolet Tahoe (A64194)
2019 Chevrolet...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
SURE FIRE 5.3GPM LIQUID FERTILIZER UNIT TOWER (A64278)
SURE FIRE 5.3GPM...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
