Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #7,862
The 5 horsepower per foot rule is simple hearsay and a marketing gimmick and not a useable
means to determine the needed PTO horsepower for a flail mower or rototiller.
/ Let's talk flail mowers #7,863
5hp per foot is a general rule of thumb. Some areas don't need that much hp and others need more.
For me and really heavy mowing, 7hp is where I'm at but, on short stuff my 20hp tractor pulls a 6' mower just fine and rarely bogs down.
/ Let's talk flail mowers #7,864
I run a Woodmaxx 62" flail mower with Y-knives on a Kubota BX2200. I've cut 2-3' tall grasses with it no problem in L gear going 2-3 mph.
Mulches it up perfectly.
I also use it to mow my lawn occasionally and it does a fantastic job with how much air it pulls to lift and cut the grasses with the Y-knives.
The efficiency of a properly maintained flail mower is second to none if you have a smaller machine.
The flail mower does such a great job, I get excited and can't wait to use it. It's my favorite implement.
/ Let's talk flail mowers #7,865
We have small acreage and are clearing a 20 acre section of fallen timber. We use a tow behind flail mower with our Kawasaki 600 mule. It does a brilliant job of cutting through thick tussock grass, weeds and crap. It also handles the odd hidden log, big tree root or rock. We just go at a walking pace with the Kawasaki in low gear.
It has transformed our lightly wooded center section.
We can't get the tractor on a wet property but the Kawasaki will.
It is early days yet, but we love the UTV/Flail mower combination at the moment.
Future mows should be easier than current churn through thick long grass, weeds and vines.
/ Let's talk flail mowers #7,866
Hit a hidden rock in the weeds last weekend and monkeyed up a whole section of blades on the drum. For now plan on just beating them back into shape on the old anvil.
Come winter though I was thinking about maybe putting a heavier duty blade on since I'm mostly doing bushhog type work with it. It's a fine cut 88" Alamo that uses the long thin blades like #1 in the picture. I'd like to use the parts in the box to swap to one of the blades with a 1x1/2 hole in it, like a heavy duty side slicer or a duck foot. The ring is 3/8 instead of 1/2 but that's only 1/16 on either side and when it's spinning it shouldn't matter anyway. Is that reasonable?
/ Let's talk flail mowers #7,867
If you do this the flail mower rotor will become unbalanced. The best thing to do is simply
remove the opposite knife mounting station if you do not have the identical knife to replace it
and raise the cutting height of your beautiful flail mower.
/ Let's talk flail mowers #7,868
For what you say, I would look at Agrisupply and the Caroni flails built in Italy. They work really well in conditions like what you describe with similar tractors.
I have a 10 YO 6’ Caroni from Agri Supply with the Y blades. I use it mostly for clipping old Bahai grass pastures frequently. With 45 PTO HP the tractor doesn’t know it’s back there. I don’t believe considerably less HP would be an issue for my use. My favorite implement and tractoring past-time.
/ Let's talk flail mowers #7,869
I'm talking about replacing all the blades, not just the mangled ones....long as you're using the same blades at every station balance shouldn't be an issue I'd think...
/ Let's talk flail mowers #7,870
I know I've seen this talked about on this forum, but I can't find it now.
I would like to be able to trim trees back from paths and shooting lanes. Do people have much luck running a flail mower vertically? I like flail mower and have an old Rhino RF60 which works well for me. I would be interested in a 72" mower but I'm not sure how to size these for stability running vertically. Tractor is a John Deere 4600 (35 hp, 3,450 lb plus FEL). I'm open to filling tires to add weight.
Open to other suggestions too (sickle bar?)
/ Let's talk flail mowers #7,871
My flail mowers can mow in the vertical position,
one of them is a 78" and it bounces a 10,000 tractor around,
the other is a 48" boom arm mower and it also is the maximum mower I'd want on my tractor.
I wouldn't recommend these types for a tractor your size.
They do make sickle bar mowers that will trim smaller sized brush and limbs.
FH-BRM Boom Sickle Hedge Cutter | Betstco Sales, Parts, and Service:
/ Let's talk flail mowers #7,872
LouNY, if one didn’t run a 78” ditch bank flail vertically could it be run on a 4800 pound tract with 39 PTO HP?
/ Let's talk flail mowers #7,873
I think to 78" would be just to much weight when swung out to the side. While directly behing or just a sliver offset you'd likely be alright. But any offset is going to really load the heavy side axle and hub.
The HP needs would be directly related to how heavy of a material being cut and how fast you want to go.
A 48" is going to be under 1000 pounds and would likely be much more manageable.
/ Let's talk flail mowers #7,874
Thanks for the advice! What does that 78" weigh? There's a Del Morino Centurion Super line that are all under 1,000 lbs.
That sickle is interesting, looked a little fussy in their video, but I'll think on it a little.
/ Let's talk flail mowers #7,875
Around 1800-2000 pounds as I recall.
/ Let's talk flail mowers #7,877
My Peruzzo 7.2" is 1,500lbs. My L4060hstc is probably under 5,000lbs with loader & loaded rears. If I side shift it over. It torque my machine pretty good. That's just side shift with only 1/3 or so of the flail hanging out to the side. Not even an offset one like the other guys are talking about.
I'd look at an old sickle that can run vertical for your use case. A sickle also slices cleanly. A flail is pretty safe on the ground, but raise it up in the air & the spinning hammers or knives is going to have the ability to throw debris around a lot.
/ Let's talk flail mowers #7,878
Thanks, you have the most directly comparable tractor to me, I would be around 4,500 lb with beet juice in the tires plus whatever a FEL weighs. You would still feel unstable in your rig with an 800 lb mower?
/ Let's talk flail mowers #7,879
On my L-4600, no way would I try that. When you upset the balance, most people will not react fast enough to save it, if they can at all, before it rolls over.
Big heavy mowers require big heavy tractors for safe operation. Hanging them off the side of the tractor multiples the problems and risks.
/ Let's talk flail mowers #7,880
Yeah, I'm just getting advice all over the place, trying to compare apples to apples. Peruzzo lists pretty mowers as compatible with smaller tractors. My advice from a Del Morino dealer was more conservative. I'm not trying to be argumentative, but the only chart, or rule of thumb I have is the one attached.
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
2018 FORD TRANSIT 350 4X2 CARGO VAN (A59909)
2018 FORD TRANSIT...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2013 Lincoln MKZ Sedan (A61569)
2013 Lincoln MKZ...
(2) 18.4-34 TIRES W/8 LUG RIMS (A62130)
(2) 18.4-34 TIRES...
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
