EGO electric trimmer review
/ EGO electric trimmer review #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I have two EGO electric trimmers. Model ST1510S-FC. I bought one last year and decided to buy another battery for it a couple weeks ago. The new, bigger battery was about 3/4 the price for a new trimmer complete with the new and bigger battery so I bought a second trimmer. Now my wife and I don't need to share. Even though the 4 amp hour battery is considerably heavier it lasts for about an hour of use, and by then I'm ready for a break.
The electric trimmers are heavier than my gas trimmers because of the battery weight. The 2.5 amp hour one is only slightly heavier though. But I am willing to live with this. Not having to deal with gas and oil is great. And not having to keep the thing running when I'm not cutting anything is great. The quietness is great. When I was younger I didn't mind the noise so much, or the gas and oil. But now I REALLY appreciate these features.
The trimmers use .095 line and have no problem cutting through blackberry canes. Salmon berry canes, if new and green, can also be cut with the .095 line. The brushless motor has plenty of power which is why the trimmer needs the .095 line.
If the motor is overloaded it instantly shuts off. Letting go of the trigger and pulling it again restarts the motor.
The trimmer also has one fantastic feature that I at first thought would be a gimmick: it auto loads the line. I don't think this would even be possible on a gas driven trimmer. To reload the trimmer head you push the line through either hole until it comes out the other hole. Then pull it so the ends are even. Then you press a button by the head and the line is automatically wound in. So easy. I never thought something like this would matter much but it really does. Especially since the arthritis in my fingers is getting worse.
I did run into one slight problem, but I have had a similar problem with gas trimmers. When cutting nettles the fibers sometimes get caught under the part of the head that compresses when tapping on the ground to feed line. When enough fibers get in the space the line won't feed and the auto fill function won't work. The fix is simple though. Two tabs need to be pressed to remove the head cap, then a 1/2" nut needs to be unscrewed with a 1/2" socket. Doing this allows the movable parts of the head to come off. Then the nettle fibers are easily removed. The whole operation, taking the head apart, cleaning it out, and putting it back together takes about 5 minutes.
Anyway, I really like these trimmers. I'm sure there are other trimmers available that work as well but I don't now if any others have the auto feed feature, which I really like. I am not benefiting in any way by posting this review, I am not spamming this site. I just thought folks here might be interested in an unbiased review of an electric weed trimmer because there are so many brands available now.
Cheers,
Eric
/ EGO electric trimmer review #2
This is a timely post. I went to use my Kobalt 80v weed eater yesterday and it would start for one second and die (Full battery). Tried that 4 or 5 times and put it back in the garage. We bought the Kobalt combo kit about 3 years ago for over $300. Blower-Weed eater. I don't even have 3 hours on the weed eater, disappointing. Kobalt has gotten my last $. Their batteries die too soon too.
I went to Ace hardware and bought the EGO Combo (Blower/Weed eater) while it was on sale for $229 with Ace rewards. I just ran it for about 20 minutes and it is as much a beast as any gas trimmer I've used. I was taking out weeds the size if my thumb with no problem. Didn't wear the battery down, got rained out. So far, I like it a lot.
/ EGO electric trimmer review #3
I have a Ego trimmer too. Also have a chainsaw and hedge trimmer. I only have the 2.5ah batteries that came with them. Oldest battery being 2017_and the newest 2019. So all within 3 years old. All seem to have around the same run time. I can run about 1/2- 3/4 hour trimming before changing. Which is time for me to take a little break anyway.
/ EGO electric trimmer review #4
Glad you like your Echo. I Can't afford an Echo.
/ EGO electric trimmer review #6
I definitely can't afford or justify Stihl for what little weed eating I do. I do less than two hours a year total. I'm usually spraying roundup but I can't around my garden area.
We have 10 or 12 wooded acres with lots of trails through the woods. Plus we have about 1 acre or so of of our property cleared and landscaped. Since we use no herbicides at all while at the same time have lots of nettles and blackberries a weed trimmer (or two) really is necessary to keep the trails open and the landscaped areas free of undesirable plants. It for sure takes more work than using herbicides but we do what makes us happy.
Eric
/ EGO electric trimmer review #9
I will say that Echo makes the best string trimmer head on the market today and you can retrofit them to any straight or curved shaft trimmer.
/ EGO electric trimmer review #10
We have EGO stuff. I'm limbing up some cedar and fir to clean them up and get them off the ground. Bought a pole saw for getting into the thick of things. That and the little battery C/ saw work great for this project.
/ EGO electric trimmer review #11
Do any of the electric trimmers take a steel blade? I like a blade for weeds as it cuts rather than shredding.
/ EGO electric trimmer review #12
Milwaukee M18 trimmer autofeed head I agree it's amazing and rare to take the head apart anymore. .095 and about 20' feeds right through.
It does go through batteries as I usually trim out 600-1200 feet in each session, takes three 8AH batteries to do that.
Milwaukee now advertises a brushcutter version of the M18 trimmer.
I still use my Stihl FS110 handlebar with blade for now as I still have plenty of thick autumn Olive , multflora and berry brush to keep cleaned up. even takes out trees 3+ inches which would seem difficult for a battery trimmer.
/ EGO electric trimmer review #14
Those 3 edge blades are barely able to cut blackberry no less autumn olive.
Can the Ego drive a sawtooth blade, that would be useful to me or a renegade type saw blade.
I hear good things about the EGO reliability, a long term review would be welcome.
I don't know if the EGO can drive a sawtooth blade but my experience with the three edge blades tells me it can. For years I have used Ryobi or Troybilt weed trimmers. They were the same machine. I could buy their three lobed blade for twelve bucks. OR, I could modify the blade mount to accept a blade with a 1/2 inch diameter hole. Then use carbide tooth circular blades with 1/2 inch holes. The carbide toothed blades could be had for 7 bucks on sale. And even when quite dull cut better that those crappy three lobed blades. Really, the many toothed blades require less energy, even when very dull.
I intend to machine whatever adapter necessary to enable my EGO weed trimmer to accept circular saw blades. For sure it is dangerous to use this type of blade on a weed trimmer. Even a dull blade would do severe damage to any part of a human body. So don't do it. Even though I am going to do it I don't recommend anybody else doing so.
Eric
/ EGO electric trimmer review #16
My brushcutter is setup for blades, they are circular, but not circular saw.
Special metal guard goes on, not the plastic one.
Still need to pay attention though, would certainly hurt more than a string !
/ EGO electric trimmer review #17
The only downside (or caution that I'd say) is the type of driveshaft that goes from the powerhead to the business end.
If it's not a solid square ended shaft but instead is a coiled wire shaft, the chances of failure from shock loading is great. The Stihl I have has a solid shaft from the powerhead to the angled gearbox so shock loading is a non issue.
I'd never consider a curved shaft trimmer with anything but a string head, just not stout enough for any metal blade, and I use a carbide tipped circular saw (cheapest I can find) as a brush blade.
