Hydrolic chute for WOODS snowblower
   / Hydrolic chute for WOODS snowblower #11
Hello,
Does anyone know where I can purchase a hydrolic chute assembly for a WOODS 3 point snowblower?
WOODS discontinued the snowblower.
Thanks
Also . . . did you check Messicks? Looks to me like they have hydraulic rotation parts in stock for most Woods snowblowers.
They'd be a good place to compare parts diagrams across brands too.
Yes, I did check with them, they only have the parts and not the whole piece already assembled.
I may have to go that route.
   / Hydrolic chute for WOODS snowblower #13
screenshot_20230709-043313_google-jpg.810165
@NWKIOTI looking at your picture, can you take a picture with the black cover off?
I would think one of the motors from: Low Speed High Torque Hydraulic Motors | Hydraulic Motors | Hydraulics | www.surpluscenter.com could be made to fit and there is a good chance that they have the bolts for the cover setup for a 2 bolt bracket motor such as: 7.9 cu in White Drive Products 281130A6321BAAAA Hydraulic Motor | Low Speed High Torque Hydraulic Motors | Hydraulic Motors | Hydraulics | www.surpluscenter.com
If not, a bracket such as Mounts for Hydraulic Motors | Hydraulic Motors | Hydraulics | www.surpluscenter.com could work.
Beyond that, I second the advice to call Messicks, they are a big dealer and there is a good chance that they have a ready to go kit on the shelf.
Aaron Z
   / Hydrolic chute for WOODS snowblower #14
If you contemplating the do it yourself approach also look into kits for wood chippers. I expect it would be similar.
Which reminds me @riptides was going to build one for his chipper.
   / Hydrolic chute for WOODS snowblower #15
I agree with going electric. Whether it's a linear motor or a wiper motor would depend on the current setup. If it has a crank setup now, adding a motor and a mount is probably a 1/2-hour job.
Why do my 1/2 hour jobs always take all day?
rScotty
   / Hydrolic chute for WOODS snowblower #17
I agree with time of "quick jobs" I'd also go with more HP than a wiper motor.
I was talking about the geared type. Most are capable of killing you if you're in the way or caught up in rotating arm. :cool:
   / Hydrolic chute for WOODS snowblower #18
When a shoot is under snow load, turning them takes lots. Even my 32" Honda that has a plastic wear liner in the shoots rotation base gets hard to crank when under duress. I'd go more than a wiper motor since extra HP still works. If its under powered, they you start over with your 1/2 hour project. :ROFLMAO:
   / Hydrolic chute for WOODS snowblower #19
Now that someone said something about electric, I believe that is what I was able to find talking to someone from German-Bliss and that is all that was available from Woods. I don't think that they had a hydraulic. In the end I did not get it because I did not like the cost for the OEM unit. I also did not want to fabricate something on my own so in the end I just stuck with what the blower came with as the crank is not hard for me to use and I only need to adjust the deflector low when I have no choice but to blow into the wind, which I can usually avoid.
378811 (A51573)
378811 (A51573)
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2016 TRAILSTAR 40FT DUMP TRAILER (A54607)
2016 TRAILSTAR...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54313)
2017 FREIGHTLINER...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
New Swict 84" Skidloader Bucket (A50775)
New Swict 84"...
