Hydrolic chute for WOODS snowblower
   / Hydrolic chute for WOODS snowblower #1
NWKIOTI
Kioti 3510
Hello,
Does anyone know where I can purchase a hydrolic chute assembly for a WOODS 3 point snowblower?
WOODS discontinued the snowblower.
Thanks
   / Hydrolic chute for WOODS snowblower #2
Unless you can find a dealer who has one in stock you will either have to make one or adapt one.
Do you have a picture of the snow blower?
There are a few common ways that people go about it, but it depends on how it is set up.
Aaron Z
   / Hydrolic chute for WOODS snowblower #4
This is a good application for a simple 12v 'linear actuator'. Not used continuously and light loads and no 2nd hydraulic circuit is required on the tractor.
I have 3 rear remotes and I've contemplated adding a chute deflector to my blower and decided that IF I did, it would be an electric rather than hydraulic for simplicity and probably less costs.
   / Hydrolic chute for WOODS snowblower #5
I agree with going electric. Whether it's a linear motor or a wiper motor would depend on the current setup. If it has a crank setup now, adding a motor and a mount is probably a 1/2-hour job.
Oh yeah, if you can't spell it don't do it. ;)
Aaron Z
   / Hydrolic chute for WOODS snowblower #9
Hello,
Thanks
You don't really need a chute assembly, just a hydraulic kit for the one you have, right?
Is yours set up for a bellcrank and hydraulic cylinder to turn the chute? Or do you need a hydraulic motor to engage the teeth around the base of the chute? Either way, I'd investigate the other snowblower brands. When I needed a bellcrank and hardware to convert mine, I found that many used the the same parts. Woods might be compatible with Meteor, Blizzard, FarmKing, Buhler, Frontier, . . . at least I'd try to look at their parts diagrams and compare.
I much prefer hydraulic chute rotation if you can find it. I bet you can find the exact parts you need under a different brand name. Just look for the "optional" parts / kits for similar size snowblowers.
Good luck!
   / Hydrolic chute for WOODS snowblower #10
Google "snowblower hydraulic kit". Lots of leads and options to investigate.
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2007 Ford F-150 Ext Cab Pick-up Truck (A55788)
2007 Ford F-150...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
