Hydrolic chute for WOODS snowblower
   / Hydrolic chute for WOODS snowblower #1
NWKIOTI
Kioti 3510
Hello,
Does anyone know where I can purchase a hydrolic chute assembly for a WOODS 3 point snowblower?
WOODS discontinued the snowblower.
Thanks
   / Hydrolic chute for WOODS snowblower #2
Unless you can find a dealer who has one in stock you will either have to make one or adapt one.
Do you have a picture of the snow blower?
There are a few common ways that people go about it, but it depends on how it is set up.
Aaron Z
   / Hydrolic chute for WOODS snowblower #4
This is a good application for a simple 12v 'linear actuator'. Not used continuously and light loads and no 2nd hydraulic circuit is required on the tractor.
I have 3 rear remotes and I've contemplated adding a chute deflector to my blower and decided that IF I did, it would be an electric rather than hydraulic for simplicity and probably less costs.
   / Hydrolic chute for WOODS snowblower #5
I agree with going electric. Whether it's a linear motor or a wiper motor would depend on the current setup. If it has a crank setup now, adding a motor and a mount is probably a 1/2-hour job.
Oh yeah, if you can't spell it don't do it. ;)
Aaron Z
   / Hydrolic chute for WOODS snowblower #9
Hello,
Thanks
You don't really need a chute assembly, just a hydraulic kit for the one you have, right?
Is yours set up for a bellcrank and hydraulic cylinder to turn the chute? Or do you need a hydraulic motor to engage the teeth around the base of the chute? Either way, I'd investigate the other snowblower brands. When I needed a bellcrank and hardware to convert mine, I found that many used the the same parts. Woods might be compatible with Meteor, Blizzard, FarmKing, Buhler, Frontier, . . . at least I'd try to look at their parts diagrams and compare.
I much prefer hydraulic chute rotation if you can find it. I bet you can find the exact parts you need under a different brand name. Just look for the "optional" parts / kits for similar size snowblowers.
Good luck!
   / Hydrolic chute for WOODS snowblower #10
Google "snowblower hydraulic kit". Lots of leads and options to investigate.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F450...
2012 FORD 4 DOOR TAURUS SEDAN (A52576)
2012 FORD 4 DOOR...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
