Marvel Mystery Oil
/ Marvel Mystery Oil #81
I've done that too and it worked. I was told to shut the engine down immediately after drizzling the MMO into the carb and let it set at least a day. There were no skeeters around for a bunch of hours :)
I did something like this with Seafoam and a rototiller.The guy left ethanol gas in it for more than a year. I drained the fuel, put in some new non-ethanol but couldn't keep it running.
Then I put in way too much Seafoam and started it. When it again quit I unintentionally left it for four or five days and when I started it again it ran fine. 🤷‍♂️
/ Marvel Mystery Oil #82
I have seen water used in the same manner for the same purpose.
Yrs ago my wife found a lo mileage under warranty used '85 Fleetwood Cad. she wanted. We bought it. Soon started giving trouble. Cadillac was going put new engine in it but was delayed.
I was back in mechanic dept & mechanic was drizzling water down thru carb while running & said same thing, that when water burns & explodes the shock cleans up valves & pistons carbon.
I've also done the "ATF overhaul" before & get rid of neighborhood mosquitoes.
/ Marvel Mystery Oil #83
I use it for air tool oil, won't gunk up air motors and it's less expensive than IR air tool oil.
My dad was an air tool repair skilled tradesman at GM, He always used MMO for air tool oil. I have used it in all of mine air tools for over 40 years and I never have an air tool motor issue. In fact, I have purchased "bad" air tools from garage sales that "had no power" or "doesn't work well". Take it home and flush the motor thoroughly several times with MMO and they came back from the dead. It works well on rusty bolts and as a general lube as mentioned above too.
/ Marvel Mystery Oil #85
I was given a 1953 Willys M38A1 Army jeep that had been left sitting on a farm, was vandalized and pushed into a dry creek bed which later flooded. The engine was seized. When I got the Jeep home, I pulled all the plugs and squirted each cylinder liberally with Jet A jet fuel and let it set for a few days, adding more each day. After a week I put a breaker bar on crankshaft pulley and rocked it back and forth and got slight movement. That worked up to rocking entire jeep, in gear, and got the engine to turn over. Throughout the process changed to MMO for more lubrication. Ultimately, got it loose enough that I could turn it over with starter after fogging cylinder walls with oil.
Next step was starting with starting fluid and getting good oil pressure. With all the Jet A, penetrating oil, regular oil in combustion chamber, it smoke like no tomorrow for a a good bit. Once it was running and good gas supply provided, I started and ran it having done nothing to carb. A buddy suggested using ATF fluid drizzled in the carb. It filled a large hangar where we were working with smoke to the point you couldn’t see ten feet!
After this treatment, the engine settled down ran smoothly and quietly. Other than changing oil, I never did anything else but change the water pump. I cleaned the old jeep up, fixed some rust and body damage and painted and went through all brake system with new and changed transmission, transfer and differentials and flushed them. I finally painted it semi-gloss OD paint as it was from factory.
I drove that jeep for several years before trading it for another earlier model. It was still running and going well the last time I saw it. The only maintenance was changing the clutch pressure plate and servicing.
And I ran MMO in both oil and gas in all my old Army jeeps.
/ Marvel Mystery Oil #90
A friend who died about 15 yrs years ago, had a antique car junkyard since the 1940s and swore by Marvel Mr Oil to free up frozen engines. i used it many times after that with 99% good results.
i also worked as a mechanic in the 50s and we used Rislone anytime we had sticky valves by revving to about 1/2 throttle and flooding the engine completely out, let it set at least overnight Started it up smoked everybody out in the area but most of the times avoided the valve job. one time the owner of the garage insisted we leave the car parked backed up to the garage overnight. when started a day or so later that side of the white garage got a black paint job. used the Rislone treatment this past winter on my son's 2010 Chevy Suburban showing misfire codes with over 200,000 miles, took it garage they they said sticking valves and lifters and wanted about $2,000 to pull heads replace lifters and deGunk. when he said I can't afford that they said ,well we can try flooding it out ( with some newer product than Rislone) which they did and it has been running ever since with no problems so far knock on wood. i wonder why they didn't say they could do that before they tried selling a $2,000 engine job!!!!
Smiley
/ Marvel Mystery Oil #91
We used to mix gas, water, oil and kerosene run the engi;ne
wide open and pour in the carb but not kill the engine and it
would run like a top no problems after that treatment
willy
/ Marvel Mystery Oil #92
My neighbor bought a Deere B and it wouldn't run right. He tried everything including MMM, which he said always worked. This time it didn't so as a last effort he tried some of my Kroil oil in the cylinder and left both it for two weeks while other work was being done.
When he started it up, it ran fine and compression was all good. It might have been the MMM and Kroil together loosened the rings up or it may have just been the Kroil but it worked. It's hard to believe you can loosen things up and get gunk out with these products.
/ Marvel Mystery Oil #93
I look at this stuff as a last ditch effort to use in your engine oil, down the carb or in the fuel tank. I wouldn’t use it in fuel or oil on a regular basis. When people say “I’ve used for years and my car keeps running” doesn’t mean a thing. Maybe it would have done better without it.
/ Marvel Mystery Oil #94
Man-0-man you got that right. Downy fabric softener works on everything as well! :ROFLMAO:
/ Marvel Mystery Oil #95
I always remember an ad where they got the latest oil additive. It clings to everything. They opened an engine crankcase. Started it up and ran it while squirting water on the lower end from a fire hose. Of course water is a lubricant and it would cool it so it had nothing to do with the additive.
/ Marvel Mystery Oil #96
Unfortunately I never checked my air compressor oil level (ever).
Came to my attention when the circuit breaker kept tripping. Discovered the compressor part seized. Friend recommended dumping Marvel Mystery Oil in the top air port on top of the piston. Over several days I was able to turn the wheel that is driven by the electric motor by hand. Within 10 days it was spinning freely. Added the compressor oil and replaced the belt. Running like new.
/ Marvel Mystery Oil #97
Well I've used MMO, Kroil Oil, ATF sparingly several times thru the yrs on/in different things. Sparingly because of the cost. I'd like to use it more constantly but the time to measure MMO for a fuel fill-up on my older daily driver trucks I really don't have added to the extreme cost.
Qt of MMO is bout double what it was 2 yr ago, runs good in fuel & some in oil....maybe?
ATF in fuel helps & is good & helps.....fuel not what it was several yrs ago.....how come??? Hi $ low quality road fuel plus some additive equals bout $20-$30-$40 per gal for fuel!! hahaha
So all in all I keep MMO, Kroil Oil, Seafoam around to use, but not daily. :):(:cool: :mad:
/ Marvel Mystery Oil #99
Only thing that goes in my crankcases besides Rotella T6 is Nano Borate and it's not cheap but it's a superior internal engine cleaner.
/ Marvel Mystery Oil #100
What is Nano Borate? New one on me. You run it all time or short time then dump it?
I got couple Ford '90 IDI engine work trucks as well as a '14 Chev Silverado 6.6 Duramax.
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2012 C&M TRAILER 16' ENCLOSED CARGO TRAILER (A65643)
2012 C&M TRAILER...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
