Marvel Mystery Oil
/ Marvel Mystery Oil #21
Used it in my TR6 that sat for very long time poured in each cylinder until after several days it just ran out as fast as was put in. I have used it in lawn mowers etc for years
/ Marvel Mystery Oil #23
The only thing I've ever used it for is to moisten foam air filters and pre-filters so dust will stick to them instead of going right through.
/ Marvel Mystery Oil #24
I use it all the time.
It has multiple uses
It's basically a penetrating oil like wd40 but I think it's more oily and thicker and I think it works better for soaking rusted parts.
The spay cans, I think wd40 works better.
I usually have a bowl of it for stuff that needs to soak for a while, like chains.
It also works pretty good as a cleaning solvent but then so does diesel and diesel is a bit cheaper. Not really sure which works better.
You always hear of people putting it in a froze motor to unfreeze it but that's not something I've ever done or ever will do.
If it's froze up it needs to at least be disassembled and cleaned.
/ Marvel Mystery Oil #25
A good friend recommended MMO back in the 60's. I stored a Honda CB350 for over a year by hooking up a gas feed after the stock tank and adding MMO till the engine stalled. Enough smoke to hide a house! Restart included emptying the bowl and cranking intermittently to not overheat the starter. Ran fine for years, sold the machine and new owner (co-worker) had no issues.
/ Marvel Mystery Oil #27
I use it in all of my old garden tractor engines from the 50's, 60's & 70's that were designed to run on leaded gas. Just a cap full when it came in the metal quart cans added to the gas, it lubricates and prevents exhaust valves from sticking. I also add it to the oil for the same reason, and to help keep internals clean.
I first used it back in the 70's in a Ford 1 ton truck w/6 cylinder. I'd asked the machinist who worked the head for me about Stellite valves, and he suggested using MMO. he used it in his racing bike at the strip. He's the one that told me it's great for the older engines designed to run on leaded gas, and it's upper cylinder lubrication properties.
What really made a believer out of me was when a neighbor girl had an older big box store riding mower with a B&S vertical shaft engine would stop running after an hour or so in hot weather but start back up after it cooled down. She called wanting me to come fix it. I just assumed it was vapor locking but when I tried to start it. it turned over very fast like no compression. I pulled the small cover off at the base of the valves and saw the exhaust valve was stuck open. Came back home and got my can of MMO. By the time I got back, the valve had freed itself. Replaced the cover and added a good capful of MMO to the gas and told her to run it and call me if it does it again. She called me 3 hours later pretty happy it never stopped on her the rest of the day. She then got her own can and added to the gas before mowing and never had any problems with it for the next 4-5 years running it. She done flat wore the mower out after that amount of time, so replaced it.
I use it mainly in older single cylinder air cooled engines but will add it to oil in new to me small farm tractors I collect/use to help clean things up and lubricate the upper cylinders. Gotta' believe it helps to free up/clean piston rings too. Some claim using detergent oil in older engines that has only had non-detergent oil ran in them since new will plug up the return ports. I've never personally had that problem.
With newer engines today and oils out there on the market, don't know that I'd use it in them. But it is great for older engines pre-unleaded gas.
I wouldn’t think adding MMO to engine oil would be very good for any engine oil. Add it to fuel yes but I want my engine oil thick especially in old engines
/ Marvel Mystery Oil #29
Used it in a 1.6 liter 2008 Hyundai Accent. It had about 200k miles on it and I usually ran 10k between oil changes. It was getting really gummy and things were sticking. Added a quart to the crank case and some to the gas tank. Changed the oil about 200 miles later and the results were amazing. The engine ran like new.
In an NTSB post aircraft accident investigation published in 2003, it was reported that Marvel Mystery Oil was composed of 74 percent mineral oil, 25 percent stoddard solvent, and 1 percent lard.[4]
/ Marvel Mystery Oil #30
You could mix up a small batch of mmo and acetone for penetrating oil. you may have to add more acetone if it sits a long time
/ Marvel Mystery Oil #31
Don’t quote me on this but I have read that Stabil works by floating on top of gasoline and preventing air/moisture interacting with the fuel. I wonder if MMO works in the same manner.
No, Sta-bil does not float on top. It is fully miscible.
/ Marvel Mystery Oil #33
Is this stuff still made and marketed? Back in the 50s and 60s my FIL was a master mechanic. He worked for a auto parts/rebuild located in a farming/logging area. They did a huge business rebuilding engines for farming and logging equipment. In those days rebuilt components were not as popular as custom rebuilding. He was a popular consultant to fleet owners and even individuals. He claimed that engines he rebuilt that had used MMO were cleaner and contained no carbon residues compared to others that were usually gunked up badly.
He was and swore by MMO. Assembled all his engines and other components such as transmissions with MMO. He was very successful in selling it over the counter. in those days you could buy it in large containers; 5 gallon and even 55-gallon containers. The area had huge farms and logging operations with large fleets and even their own mechanics.
He had me using it in my vehicles. Never had anything long enough to establish a strong opinion.
Ron
/ Marvel Mystery Oil #34
I saw a youtube video then went out and tried it. Do not know whether it helps or not.
2006 Mercedes 5 cylinder diesel sprinter(No def) MH and 2014 chevy cruze diesel.
2 parts MMO and 1 part Howes Lubricant in the diesel fuel every fillup.
about 10 ounces in the 16 gallon tank and 16 ounces in the 26 gallon tank
19.3 miles to the gallon in the Heavy sprinter 2500 and 34 mpg overall in 85,000 miles
on the cruze last time i looked. (it has a button that tells you)
Been doing it a couple years now. I am sure it is helping lubricate the injector nozzles
but both just purr.
No Earthshaking news on it's performance to relate well except the Good News!
/ Marvel Mystery Oil #35
A friend gave me a quart of Marvel Mystery Oil? I remember it from the 1960's but I have never used it. Where do you use it and what is it good for?
I remember using it as an additive to regular oil in my dad's boat (which used a 357 Chevy 8 cyl engine). THis would have been in the 1970s.
/ Marvel Mystery Oil #36
It can be used as a upper cylinder lubricant when mixed with gasoline.
/ Marvel Mystery Oil #37
I do not normally go for snake oil products and considered MMO as one BUT it is definitely not snake oil. I now add it to every storage can of gas I have. I use Eagle Safety cans for my gas storage, they seal tight and have no worries about leakage during transport that happened occasionally with plastic containers. I keep about 50 gallons of gas on hand for the tractors, mowers, etc. and before I started adding MMO the gas would go bad. I had used MMO in the past for sticky valves as mentioned and since I had some on the shelf, that was getting pretty long in the tooth, decided to add it to the storage cans. Mainly to get rid of it. Best move I have ever made, have not had a can of ethanol laced stuff they call gas go bad since. I NEVER, at the end of season/use, run the carbs dry and leave the tanks full and even after some of the engines set for a year with the tank of gas they fire easily and run smoothly.
As an added bonus, that surprised me, I added some to the tank of my old 1992 GMC K3500 flatbed with a 7.4L for some valve noise and noticed that the gas mileage seemed like it was up. I keep meticulous records on all my vehicles pertaining to every drop of gas or oil added to them and after several tests running tanks of gas with and without MMO added it happened every time that the mileage was up by 1 to 2 miles per gallon with the MMO added. Doesn't sound like much but going from 10 mpg to just over 12 on that truck makes a worthwhile difference to me.
So, how much would "some" be, added to your fuel?
I remember it smelling rather sweet and pleasant, using it in air tools.
/ Marvel Mystery Oil #38
Many years ago an old man who was a GMC/Pontiac dealer told me, "Marvel Mystery Oil, it fixes sh*ts, fits and floppy ****"! I've got a can somewhere around if I can find it!
/ Marvel Mystery Oil #39
As somebody said "good for what ails ya". It is a top lube. I use it in the gas and add a little to the oil also. It will free stuck rings also. My brother had an old Buick that was given to him and it smoked like crazy so he used it in there and a couple tanks of gas later and it didn't use oil at all any more.
/ Marvel Mystery Oil #40
Guys... MMO is basically a thin lubricating oil (Like ATF) but includes Methyl Salicylate - That is "oil of wintergreen." That's the chewing-gum or "Life-Savers" smell you notice.
Methyl Salicylate DISSOLVES ferrous rust. I'm an old Navy guy and 50 years ago our NASU engineering publication ran a short article on the effectiveness of Methyl Salicylate to remove severely rusted hardware (salty sea-water really does a number on steel) - IT WORKS! It does NOT work on aluminum or stainless/aluminum dissimilar metal corrosion. The thin oil carries the methyl salicylate into the frozen hardware and given some time (and maybe a little heat) it will dissolve the rust and free the nut, bolt, shaft, etc.
I know not the percentage of methyl salicylate in Marvel Mystery Oil but I know from years of experience it does work on ferrous metals, like piston rings and cylinders and such. As an additive to fuel and crankcase it can't hurt.
my 2 cents worth...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
