Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #561
I was very happy with the price.
Yes, mine is the same as your posted mini-x. I am wanting to add some weight to the back. Do you think I could add 3-400 lbs without trouble?
I am looking at screw on filter assemblies. They range from 10-30 microns or so. Any thoughts on the appropriate filter size? Also, I can’t find any information on the digget em15 hydraulic pump gpm rating. I’d love a ballpark number so that I can size the filter fairly close.
I found metric din fittings and adapters at discounthydraulichose.com, does anyone have a better source, their prices and selection seemed ok. Again, this is all new to me.
Im thinking about sharing some pictures as I go, I like to do little mods. Hopefully you all wouldn't mind. I have really enjoyed this thread and there is not much out there for the import mini-x’s. This is my version of a hot rod.
Thanks, Mark
A 10 will do but i put on a 30 and it doesn't impair the flow. Amazon can be a source for parts like filters , Hose and fittings. Assuming you are putting it on the suction line you will most likely need 5/8" barbed to 3/4" npt.
I added 300lbs of sheet steel encased lead to mine. If you can find Bismuth it is denser than lead and not as deadly.
Please send pics of your mods.
   / Importing and modifying a new mini excavator from China #562
It does make sense that the cooler should look more like a radiator with top and bottom inlet/outlet configuration.
From what i can tell all the small coolers are arranged like mine.
The coolers are small ( 11" x 12" ) and the plates are less than an 1/8" thick Od. I was more afraid that the interior volume was insufficient.
The volume of added oil was 20 oz. My oil temp went from 58c to 35c .
All this being said, if there was room to turn the cooler on it's side thus working more like a traditional radiator I would have done that.
The problem with this is the very limited room. you need to be able to access the inside of the dog house and running hoses that don"t become pinched , collapsed ,or fried by the engine or exhaust becomes a challenge.
None the less pmsmechanic you are correct.
Thank you for being so gracious. I just wanted to point out something that was pointed out to me when I installed a hydraulic oil cooler on a mower that I built. It's a detail that can make a cooler ineffective and it's something I would have never thought of on my own.
   / Importing and modifying a new mini excavator from China #563
Note that some attachments are worth buying and others are not. I posted about them. Spares are very inexpensive if you include them. I don't know what the tariff is in other countries, but here in the US it is still 25%.
Big Qs you need to ask about the YFE10S is if it has oil filtration and what engine do you get. I would still go for the B&S gas over the ChangChai/Koop diesel, even if you are not in the US.
I'll look back and find your post.
They're assuring me the YFE10S has hydraulic fluid filtration, cooling and is equipped with the B&S gas engine.
Thanks for your comments
Oil filters on the suction side of the pump are bad news. Even the 100 micron mesh strainer in the tank is questionable. I posted pix of the strainer my machine came with, plus Rhino even included a spare. I cleaned out the tank when it was new, and installed new THF fluid. I don't know if all these machines have that strainer. It is good to check.
As for adding weights, where do you put them? I did not know that your could even buy bismuth in ingots or plates, but it is only a bit denser than steel (specific gravity, 7.9) at sg9.8, and less than lead (sg11.4). Lead weights are great if you can get them, and not dangerous at all. The danger from lead is in breathing or ingesting lead compounds.
   / Importing and modifying a new mini excavator from China #565
I can't recall any good quality hydraulic system I've been around that did not have a suction filter, usually between 25-50 Micron.
Then on the return there will be usually a 10 micron filter.
   / Importing and modifying a new mini excavator from China #566
My counterweight on my CAT E70 is a 1/4 inch steel box filled with concrete, with a steel lid welded on.
hugs, Brandi
   / Importing and modifying a new mini excavator from China #567
Sorry to get your goat dfkrug, it was meant as a joke. The active ingredient in Pepto-Bismol is Bismuth subsalicylate. The Gov. classifies lead as environmentally hazardous. Hazard Class 9. As we know now lead does not leave the body, ever. Any exposure including but not limited to handling is bad at any age . Trying to be a good steward ,I sheathed mine in sheet metal.My lead came from a dental office remodel years ago and was in the form of 1/8" sheet, easily cut and formed to the back of my mini.
In CA we have Proposition 65, which requires sellers to put a warning label on any product that has one of many cancer-causing compounds in it. Does not tell you which one is in it. Any products that involves fuel or many metals must have Prop 65 warning. Kinda meaningless.
BTW, Agrisupply in the East will no longer sell to CA residents cuz they don't want to do the Prop 65 label mambo. Too bad. I like them.
   / Importing and modifying a new mini excavator from China #569
My Mother Passed last December, one of the reasons I could afford a Mini in the budget. She was 90, lived a great life.
Anyway, She grew up at a Saw Mill, was actually Born there according to her Birth Certificate, on a "Lake" because that is how the Logs were shipped to the Mill. She would talk about Tram Walkways, playing on the Tie Piles.
The land was designated "Contaminated" 20 years ago, Creosote from the Wood Preservative, and every household still on it were moved to New Uncontaminated Lots. This year, Land reclaiming has begun and many Big Hoes, are busy digging and hauling the Earth away and New Earth is being moved in. Millions in Rehab.
If I make it to 90! Color Me Happy, Contaminated or Clean. Labels or Nothing
   / Importing and modifying a new mini excavator from China #570
That Creosote is bad, bad stuff. Many locations are trying to clean it up now.
   / Importing and modifying a new mini excavator from China #571
How can creosote be so bad, it's all natural. Isn't that good?? :ROFLMAO:
:ROFLMAO: :ROFLMAO:
   / Importing and modifying a new mini excavator from China #572
Yes, I do agree, but Bad Bad Stuff in who's eyes? Like I said, my Mother made 90, out lived my Father who didn't grow up in the same area.
Long Term effects are very Inconclusive in Many Hazardous materials. What we Know, and what we Believe sometimes get very messed up.
Just as the ICE causing Global Warming. Yes they might have an effect, but what about the 540,XXX Kilotons of Nuclear Testing that has taken place around the World? BEV Vehicles, being the answer to the problem, but what of all the Coal Fired Generating Stations that provide the Electricity?
And I think my Favourite, Volkswagen's Emission Cheating 60 mpg Diesels, being bought back, sold in other areas of the World, and replaced with 30 mpg Gassers in many cases?
What do Label Stickers do to help?
Last year we Flooded. Weather related yes, and beat the Flood of 1950 (long standing level) Thousands of Sandbags were deployed. All of those Sandbags were to be retrieved and discarded at a Landfill because they were Contaminated when they came in contact with Fresh Water? Does it not Rain on Dirt?
   / Importing and modifying a new mini excavator from China #573
Ok a Question What is the 3rd line to 1 Drive Motor?
   / Importing and modifying a new mini excavator from China #574
If you look closely there is a 3rd line on both motors. It's probably a case relief line. If the output shaft seal starts leaking there is a way for the hydraulic oil to drain back to the resevoir instead of pressurizing the casting.
Yeah, it is probably a "case drain", as PMS says.
I have not seen that connection used on any of these units. I have noted that there are more than one unused ports on many (most?) of the wheel motors. On the one I have seen with the wheel brakes (HeChuang), there is a separate external attachment and 2 RVs, but no case drain.
Did you trace the extra hoses to see if they connect right to the hyd tank?
   / Importing and modifying a new mini excavator from China #576
Not my Unit, just watching the Auction and seen it.
Stopped At $10K CDN for a MMS MS180K Kubota/Swing Boom, shouda kept going but a 1600km trip to pick it up.
   / Importing and modifying a new mini excavator from China #577
I have a word of caution for anyone thinking of adding weight to the a** end of their mini. It helped a lot when digging perpendicular to the tracks.
My trailers are low and the ramp angle is shallow. I've always loaded blade and boom forward even though larger ( 3 to 6 ton) minis load a** end first.
It seems my weight addition has thrown off the CG substantially. I've had no trouble loading until the other day..... Don't know what i did different but heres the result.
Nobody hurt , but wimpy looking ROPs worked. I'll straighten the rops and sleeve it . I will be loading Butt first from now on.
   / Importing and modifying a new mini excavator from China #578
Nobody hurt , but wimpy looking ROPs worked. I'll straighten the rops and sleeve it . I will be loading Butt first from now on.View attachment 812066View attachment 812067
gee whiz, glad no one was hurt.
   / Importing and modifying a new mini excavator from China #579
Thanks ArlyA, It was ridiculously slow motion, such that I had time to jump off and watch it turtle itself. I laughed until i realized I would have to fix something.
Wow.
Your ramp does not look that steep. I have gone up/down slopes as steep as 40%, measured. And, the guy I posted about earlier who loads his minis into a PU truck bed, about as steep. Not for the faint-of-heart.
Thx for posting. These small minis can be dangerous.
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
2016 INTERNATIONAL PROSTAR (A59904)
2016 INTERNATIONAL...
Schulte SBW800 Rock Windrower (A56438)
Schulte SBW800...
