Loader Old man and tree
/ Old man and tree #1
Smokeydog
Elite Member
Knoxville, Tennessee
Kubota B26, M59, M5030DT
Had red oak come down this week. 34” diameter 120’+ tall. Decades of leaning, weathering storms finally succumbing force of gravity. Age like gravity wins in the end.
Jacked up the corner of the steer/goat shed about 4’.
Have 50 years experience cutting trees. It is a risk complicated by age. Using a hydraulic polesaw I built, cut the limbs into 10-12’ sections. Sure beats being on the ground in the danger zone. Hate admit it but not nearly as quick or strong as I use to be. 70-80 cuts took about 3 hours. Stopping to put the saw chain back on twice and replace the bar once. Thickest cut 14” and all cuts at idle.
Now can use the grapple to haul the limbs away to the gulley.
/ Old man and tree #2
Pardon my ignorance, but what attachment is that on your FEL to operate the chainsaw? I live in the middle of the woods and that would be an awesome addition for clearing around here.
/ Old man and tree #3
I believe it’s a hydraulic powered chainsaw rigged up as a pole saw attached to his FEL. I’ve seen power line crews use hydraulic pole saws from bucket trucks. There are hydraulic plug ins for the saw in the bucket.
Nice setup and looks like some good firewood if you cut firewood.
/ Old man and tree
There are several manufacturers now of similar saws. LimbHog, LimbSaw, limbinator. Built this one to match my scrap pile and needs.
Have next 6-7 years of firewood cut. Being next to 300 year wagon road and farm buildings be a risk of milling the lower log section.
/ Old man and tree #5
That's a slick looking rig. One TBN member's signature says something about working smarter, not harder using diesel and hydraulics.
It seems like that saying fits your setup perfectly. 👍
/ Old man and tree #6
Good days work. (y)
/ Old man and tree #7
For those who haven't seen Smokey's limb saw build -
enjoy... Steve
/ Old man and tree #8
Hydraulic Pole Saw/////////// didn't know there is such a thing. Looks quite handy for big jobs. Alas, I'll still be standing with my traditional Gas Pole Saw.....but it gets heavier every year.:mad:
Cheers,
Mike
/ Old man and tree #9
Dad needs one to get some high limbs.
/ Old man and tree #10
well done rig. all pole saws sometimes get pinched high up. have you run into any problems with pinching w/a arm that length? good work.
/ Old man and tree
Cutting from top helps prevent pinching. Manual polesaw a good educator persuader. Small 2-4” limbs are so shocked from being cut so fast binding is minimal. Pinch does happen and having a reverse to crawl out indispensable. Also cutting over 10” can stall the chain. Quick reverse to forward usually gets it cutting again. Lots of force on the chain but still using the my first chain showing little wear from either cutting tooth or drive links which in remarkable. Bars another story. Have bent two bars. Just part of the consumables. 20” bar and chain $40. Just got to let cut under it’s own weight and not force it with FEL or tractor.
Being able to section fallen trees enough to push back into the woods or haul off all from the tractor seat been helpful.
/ Old man and tree #12
Must be super, duper nice to not have to get off the tractor seat to run a chainsaw by hand. No worries about snakes in the woodpile, either.
/ Old man and tree #13
the reverse feature would be the selling pt for me were i buying one.
2003 Isuzu NPR Box Truck, VIN # 4KLB4B1R13J801508 (A61165)
2003 Isuzu NPR Box...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
IR IRET13 ELECTRIC TRICYCLE (A62130)
IR IRET13 ELECTRIC...
New/Unused Wolverine 84in Quick Attach Snow Plow (A61166)
New/Unused...
2000 Kenworth Tri-Axle Dump Truck (A61568)
2000 Kenworth...
