Gooseneck or bumper pull?
/ Gooseneck or bumper pull? #42
Actually, a properly installed GN hitch will be CENTERED on the centerline of the rear axle, not in front of it.
I don't think so, almost all I have ever seen are just a couple inches in front which makes perfect sense.
These all say centered or just in front.
/ Gooseneck or bumper pull? #43
With me, a lot. I like to park the GN at 90 degrees to the truck when loading. That eliminates the shock load on the trucks transmission (especially when in 'Park') because the parking sprag in most transmissions isn't all that strong anyway. I'd much rather 'tighten up' round bales on the GN with it at 90 degrees to the truck.
That's what the parking brake is used for. It should be used every time a pickup with trailer is parked. Although more and more rare, a manual trans makes it obvious.
/ Gooseneck or bumper pull? #45
I can't find my paperwork for my B&W hitch. Best I can tell the GN ball is 3.5" ahead of axle center. This is on a 2002 SD Crew Cab short bed.
/ Gooseneck or bumper pull? #47
Not 2 5/16".
Expert Reply:
The measurement of the Replacement Hitch Ball for B&W Turnoverball Underbed Gooseneck Hitches - 2-5/16" # BWGNXA2000 is 2-1/2 inches by 2-1/2 inches by 4 inches. The ball on top of this shank is 4-1/16 inches tall. The hitch pin hole is centered in the shank so it is exactly 2 inches on center from the bottom of the shank. I've attached a couple photos to assist.
/ Gooseneck or bumper pull? #48
Couple of points: The reason to put the ball ahead of the rear axle is that when the tow vehicle starts to turn, the trailer immediately initiates a turn in the same direction. If behind the rear axle (bumper pull style), when the tow vehicle starts to turn, the trailer starts to turn in the opposite direction then has to catch up. When at the rear axle, the trailer is on its own without an initial condition boost. Maybe not that important at speeds below 50 mph, but now we see all kinds of trailer combos at speeds at over 80+ mph. And many start to self actuate a sway condition. Hitch ball Height is also a player in the physics of trailer towing if you don't want your critters to roll around a lot on the way to a show.
Second point is that I see a fore-aft cushion type hitch is now available for GN users.
/ Gooseneck or bumper pull? #51
Expert Reply:
So it's 2 5/16" not 2 7/8". Glad there's not a new size out there.
/ Gooseneck or bumper pull? #53
I also have both. The worst place for a GN is a “T” where you have to make a 90* turn and there are pillars or a mailbox right out by the road. The bumper pull will make it. The GN might knock mailbox or pillars over.
I dont know how many times I have said this very same thing on here.
And a number of times there are the "die-hard" gooseneck guys that want to argue and just say I dont know how to drive :ROFLMAO:
Its funny though. Because its a FACT that you can make a TIGHTER 90-degree turn with a BP trailer.
The "average" country driveway around here only has ONE 20' length of culvert at the road ditch. And unless its a 3-lane wide road where you can swing wide.....dont even think of getting a 25' GN in there or you are gonna crush one of the culvert ends
/ Gooseneck or bumper pull? #54
To the OP:
So far we know you are looking at a 14k-16k trailer and a 2500 truck.
But I think we need to know more about what you plan on trailering.....and trailering to where to answer your questions.
For example....how long of a trailer are you looking at? And assuming you are looking at a ~9000-10000 payload capacity?
Too many different configurations of a 3/4-ton truck out there right now.....but my concern with a GN would also be the payload capacity of a 3/4-ton may limit you.
a 1-ton dually with a GN is definitely alot more forgiving about load placement/balance. IE....tongue weight. But a 3/4-ton truck with a 10k load on a GN.....it would be pretty easy to overload the truck if one isnt careful.
And are you looking for something to tow around a farm? In and out of fields? Or to-from businesses? Or are you looking at moving equipment to/from customers jobsites (residential) jobs. Because there are ALOT of driveways I would just park a GN at the road because there was no way to get a GN in the drive.
I went from a 25' GN to a 24' BP trailer. I wasnt opposed to staying with a GN....Just couldnt find what I wanted. Because I did NOT want a deckover. Its a lot easier loading/unloading.....and climbing on/off of a lower trailer with the deck between the fenders.
GN trailers are also HEAVIER.....which can eat into the payload capacity of both truck and trailer if you plan on towing something that is pushing the 26k limit.
My objective is to deliver bulk bags of firewood. Like this:
The bags are on 40x48 pallets. Four units on a trailer and the tractor. It seems the best approach is to park on the road and lift the bags off the side of the trailer. I was looking at about a 22-24' foot trailer.
The bags hold 1/3 cord of wood and should weigh about 1300-1600 lbs each. That puts a max. of 6400 lbs on the first 8 ft of the trailer and the tractor weighs 5500 lbs.
/ Gooseneck or bumper pull? #56
Interesting. One of my good friends does exactly that down here but instead of large sacks like that, he bundles split wood in 50 pound bundles and sells it to local campgrounds and does real well with it actually. Keeps all the local campgrounds in firewood which they in turn sell to campers. He delivers the bundles in his pickup truck.
/ Gooseneck or bumper pull? #57
If I were you, I'd consider a trailer mounted hydraulic jib crane with sufficient capacity to load and off load the totes instead of hauling your tractor around, similar to what loggers use to load and offload cord wood.
I jib crane would weigh a lot less and give you more cargo capacity.
/ Gooseneck or bumper pull? #58
That all depends on the length of the trailer tongue. With a BP trailer with a short tongue, a really tight turn will destroy your bumper or worse. Not an issue with a GN until you put one past 90 degrees and run the upper deck or GN into your truck cab.
That is a FACT.
One of the options I am looking at is a used flatbed with a jib crane. A flatbed would be easier to maneuver. I can use the tractor to load the flatbed and then use the crane to off load the bags or dump them where the customer wants them.
One advantage of the bulk bags is being able to stage them in a garage, under a car port, etc so I would like to be able to move them once unloaded. I am looking at using a powered pallet jack to move the bag/pallet if I go with the flatbed idea.
I have found a few flatbeds with lift gates and then a crane will not be needed.
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
Hydraulic Breaker Skid Steer Attachment (A66734)
Hydraulic Breaker...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2020 Bobcat E26 Mini Excavator (A66734)
2020 Bobcat E26...
2021 Ford Explorer AWD SUV (A66738)
2021 Ford Explorer...
