Filter bundles
/ Filter bundles
Some K dealers have filter sales in February. My local dealers stock parts and even oddball parts come in within a day or so. I'd rather pay a little more and get the service and reward my local dealer with the business.
Good luck with your flea-bay or mystery amazon vendor selling their mystery wares from china/india. Penny wise and pound foolish to go skimping on relatively cheap maintenance items that can end up costing me $$$$$ in repairs and down time.
Doing the pm on my truck this afternoon found my rather expensive air filter purchased at a local carquest and the one I replaced before was made in China. Anyways been kind of burned before buying cheap parts online due to mediocre descriptions and wrong part numbers that's why I asked more knowledgeable folks if they have purchased filter bundles online. Knowing I wasn't looking at genuine Kubota filters. However after Input from a few on knockoffs and qaulity etc, I guess you don't really know what your buying in terms of filters unless it's from a known reputable company that's been around awhile e-commerce or brick and mortar.
/ Filter bundles #22
I use the filter cross reference the OP posted then find name brand part numbers (typicaly US made filters) then type them into ebay. Theres alot of new filters people have sitting on a shelf and throw up on there.
If it's for a piece of equipment I'm planing on keeping I typicaly buy a case of oil filters. I do have a few pieces of equipment that share the same oil filter even though there not the same engine make.
/ Filter bundles
So replaced all filters with genuine Kubota filters/ aftermarket fluids. There is a Peace of mind knowing what I bought is correct and works like it's supposed to. Btw a Kubota l 4150 or 3750 takes over 45 qts of trans hydraulic fluid. Got to test my homemade drain pan still overfilled, my diy welds held up ok fortunately, however I still made a mess and had to put plugs in mid drain my calculations for liquid volume capacity using an old drum was off lol. 600 hrs I'll do it again.
/ Filter bundles #24
Lets see, my M9's hold just under 15 gallons each so if one gallon is 4 quarts times 15, that is 60 quarts, give or take. Why I use a plasma cut big truck aluminum fuel tank with welded on (TIG) handles. The Chevron THF synthetic I use is getting pretty expensive too. Currently $121 a pail. I can not only drain the gearcases but the sumps as well on one shot.
Only money. $121 x 6 ain't chump change.
/ Filter bundles #25
I like to drain mine on the gravel out front of the shop, that way if any spills, it just keeps the dust down. I like your bung / valve idea. I may have to do that. Now, I just prop the half full fuel tank on a block and use a gallon plastic jug to get the oil out which goes in the empty 5 gallon pails and off to my friendly recycler.
Just ordered a couple 5's from the local NAPA. Seems they now carry Chevron THC.
/ Filter bundles #26
Looks to me (from your pictures) that it's getting time for a sheet metal repaint. The Rustoleum (in rattle cans or pints if you want to spray it) is a dead match for Orange 2. Orange 1 is a dead match with Majic paint, rattle cans or pints again and the Majic hardener is compatible with both.
/ Filter bundles #27
Why I own 2 identical Kubota's (other than one is an open station and the other is a cab). All filters and lubricants interchange. My dealer always has my filters in stock, glad of that.
/ Filter bundles
Ran Napa premium hydraulic transmission fluid before. Seems I have easier shifting with both tractors after I switched to Mystic hydraulic trans fluid both are udt fluid compatible per manufacturers, might try Chevron thc if I find a good deal on it. I do occasionally use Napa Gold filters but they aren't much different in price than OEM Kubota filters. Udt fluid must have gold flakes in it lol, and imo is a unnecessary expense for my old gear driven tractors, found amazing deals with mystic brand fluids occasionally, also servicing them close to specs is probably helpful to keep them running.
/ Filter bundles
Nope not me I'll never paint my inexpensive, used, rusted beat up relics. Id rather spend my time mechanically maintaining or using them and not worried about accidentally scratching or denting it. Plus I can add non conventional, sometimes not recommended by most (accessories) to utilize it better for what I want it to do and not worry about resale on it lol.
/ Filter bundles #30
Never used anything but Chevron (after the initial change many moons ago). I like the cold weather flowability of it and as an added plus, it comes dyed orange of all things so it's easy to see on the dipstick. Problem is, it's not a cheap date, even costs more than SUDT at my dealer but SUDT is clear and hard to see on the dipsticks, especially for my old tired eyes.
I was buying it from my local jobber (in Toledo) until I found out that NAPA has it.
I only change my gearcase oil every 2 years anyway and that also applies to the front axle and I run 85-140 GL5 in that.
The THC exceeds the Kubota SUDT specs.
/ Filter bundles #31
I'd say mine are 'relics' as well being a 2002 and a 2004, but unlike the new stuff, no emissions junk to get in the way. Had them both in last fall for a valve adjustment and injector spray test and both are good to go and the turbo's are tight too. Both live on Rotella T6 and a shot of Nano Borate additive on each oil and filter change. At 6000 hours and 4000 hours, I've had nothing major go wrong either. I like looking at the new ones at my dealer (Carleton farm Supply in Carleton, Michigan) but like Dennis says (he's the head tech there, the difference is, mine have no payment books as well as no emissions stuff.
Wife bought a new Kubota side by side last spring (gasser) and it has a cat on it. it has to go in for a recall of all things. Something about the steering failing.
/ Filter bundles
When I got my first tractor I changed all fluids and filters regardless of hrs annually I look back now and wonder what the heck was I thinking. Definitely changing trans hydro fluid every 2-5 years now unless I go over the hrs. Reminds me wonder how many folks pull the rubber dust collector cap off the back of air filter canister on older Kubotas? That can and will get nasty. 1st pic is from a broken sealing washer on goes in between filter retaining nut and filter, it was broken when I took filters out at least Kubota OEM filters give you a new seal for it and you don't even have to pay extra for it lol.
/ Filter bundles #33
The revered 3 letter brand? With patented technology, wouldn’t the other major filter companies be foolish to say their filter will work? There aren’t any occasions where your group reached out to a manufacturer and used a COTS application?
Keeping in mind a patent is good for 20 years from the filing date unless the originator does not pay the maintenance fees.
As far as denial of warranty, any warranty claim could be pushed onto the after market supplier (assuming there is one) if nothing else for misrepresentation of product. The costs involved would certainly have to be weighed against other factors.
Just because…….
I ordered a NAPA Gold 1229, inside the box is a Wix 51229
/ Filter bundles #34
During the worst of the supply chain issues,I bought a NAPA 1085(WIX 51085).
Inside the box was the MANN equivalent with a note..
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
More info coming soon (A61574)
More info coming...
