Filter bundles
/ Filter bundles #1
jjeff
Super Member
MI
kubota l2850, kubota l4150
Curious if anyone has used these somewhat Inexpensive filter bundles. Definitely has an Ease of ordering online, comes with all the filters you want for a pm. Id be using them on older 30+ yr old Kubotas usually pm both tractors once a year sometimes skip a year so every two years max. I've used to use Napa Gold filters and run non Kubota aftermarket fluids in both for quite a few years now without apparent problems, of course I checked with manufacturer of fluids before and they are compatible and meet udt trans hydraulic fluid specs. Anyways if anyone has some experience with these filters or companies that bundle filters please let me and anyone else know.
/ Filter bundles #3
I've been burned by aftermarket (WIX) hydraulic filters. For those that have hydrostatic transmissions, my recommendation is don't consider anything but Kubota Hydraulic and transmission filters and Super UDT2 fluid. unless you enjoy a whiny, poor performing transmission. Quality aftermarket is probably OK for all other applications.
/ Filter bundles
Well none of my tractors are hydrostatic and not trying to make this a fluid debate, I've put several thousand hrs on both used tractors I own no fluid problems with what Ive used. Just looking for a convenient one stop shop to buy all my filters reasonably priced vs spending several days stopping at a Kubota dealership, Napa, and various other stores for filters 20-30 miles away. Usually some need to be ordered anyway so I have to make several trips.
/ Filter bundles #5
Exactly where do you think Kubota filters are manufactured?
/ Filter bundles #6
Hard to find much of anything these days that isn't manufactured overseas. I care more about who controls the spec they're made to.
Can't say there's never been a bad Kabota filter made, but having had to chase tranny issues only to find bad non Kabota filters were the cause, I can say I like my chances better with the OEM filters when it comes to their hydrostatic transmissions.
/ Filter bundles #7
So you’re a dealership mechanic and every hydrotrans problem has been created by using non-oem filters?
/ Filter bundles #8
No.... I happen to own a Kubota that had transmission problems stemming from non-OEM filters. After changing filters out to OEM, problems went away - that simple.
The poster asked what experience others had with inexpensive bundled filters.
/ Filter bundles
Well the heck with it, I'm going to purchase both complete filter bundles for 2 30+ yr old with 3k and 5k hrs respectively, l4150 and l2850 both gear driven tractors one with a hydraulic shuttle, I'll only report back with any issues or q/c problems if anyone cares.
/ Filter bundles #10
(y) thanks
/ Filter bundles
You can save even more money by not buying things like filters and oils.
Oh sure I could pay to get fluids sampled on old tractors but probably wouldn't like the test results anyway, I'll keep changing fluids and filters on a annual/ semi annual schedule instead, and keep them operational dealing with only minor quirks that I can live with, that others may spend lots of money to remedy.
/ Filter bundles #12
An answer to where does Kubota get their filters - can't speak for Kubota but as an engineer for a different major, our filtration group did work with filter manufacturers to develop proprietary filter media for critical applications (fuel systems and hydraulic systems with piston pumps and motors being two of the most critical). Some of the resulting filters could be sold by our supplier under their name and part number, and some critical ones could only be sold through our company. Sure, aftermarket filter makers could buy ours and reverse engineer, but some of our filter media was not possible to replicate (patents) so to meet our requirements (internal information not given to other filter companies), they would likely need to spend the same millions of dollars we did. Or they could use one of their existing filters with the same mounting dimensions and say its equivalent. Would you, the customer, know? Not possible. Even if you cut 2 filters apart and examined them, it would take special analysis of the media to determine materials, and even then a person wouldn't know the process used to make it. Yes, sometimes we use filters that could be considered generic. Have I seen warranty denied due to filter? Yes, but our customers normally make their living with the machines and don't risk failures and downtime to save a few bucks. Later on down the line when they reach the used and reused markets is where we found customers skimping on filters.
/ Filter bundles #13
I prefer to eliminate the chance of having problems by using Kubota filters. Messicks is right down the road and when they have sales on, I buy complete filter sets.
/ Filter bundles #14
Be very careful when buying from discount sellers. I bought 2 Bobcat OEM fuel filters from them and they turned out to be counterfeit. They looked very close with Bobcat labels etc but were missing a few details. I contacted them but they would not disclose their "Bobcat" source. Even though Bobcat has stopped making those filters over a year ago, this reseller continues to sell fake filters. I even took the filters to my dealer and the parts guy confirmed they were fake. He had just came back from a factory seminar discussing fraud.
/ Filter bundles #15
This guy even cut the filters apart to show what is inside the fake Bobcat filters. (Video at 2:00)
/ Filter bundles #16
I depend on my tractors so I always use genuine Kubota filters and my dealer always has them in stock and even delivers them to the farm, no charge.
/ Filter bundles #17
The revered 3 letter brand? With patented technology, wouldn’t the other major filter companies be foolish to say their filter will work? There aren’t any occasions where your group reached out to a manufacturer and used a COTS application?
Keeping in mind a patent is good for 20 years from the filing date unless the originator does not pay the maintenance fees.
As far as denial of warranty, any warranty claim could be pushed onto the after market supplier (assuming there is one) if nothing else for misrepresentation of product. The costs involved would certainly have to be weighed against other factors.
/ Filter bundles #19
Some K dealers have filter sales in February. My local dealers stock parts and even oddball parts come in within a day or so. I'd rather pay a little more and get the service and reward my local dealer with the business.
Good luck with your flea-bay or mystery amazon vendor selling their mystery wares from china/india. Penny wise and pound foolish to go skimping on relatively cheap maintenance items that can end up costing me $$$$$ in repairs and down time.
/ Filter bundles
I find that genuine Kubota filters are only a few pennies more than the 'other generic brands.
Nope definitely not a few pennies more, however after a few phone calls ordered all genuine Kubota filters. There goes my meager profits 😂. I may try cheaper off brand filter bundles eventually but not today. Thanks for all input.
