What have you done to your Branson today?
   / What have you done to your Branson today? #1,261
just make sure your following that h pattern religiously.. if you try to shift into the other side( 1-2) to (3-4) too fast you can jump out of the pattern and wedge your linkage, I've fixed 30+ of these since they made the design change in 20, while its not very common it can occur if you're a tad to hasty shifting, while it is a much better design its not without its owns issues.
and before its asked there's really only one way to fix it and hat involves removing the tire and disassembling the linkage and reinstalling it back into the correct position.
   / What have you done to your Branson today? #1,263
   / What have you done to your Branson today? #1,264
Ceramic paint protection. Yesterday I installed the hydraulic flow restrictors for the hydraulic top link, and the quick hitch.
   / What have you done to your Branson today? #1,265
   / What have you done to your Branson today? #1,267
   / What have you done to your Branson today? #1,268
   / What have you done to your Branson today? #1,270
Finally took the 3 pt snow blower off the Branson today.
Put the box blade on and swapped the bucket for the forks.
Have to move some pallets and IBC totes tomorrow.
I'm having an issue with my SSQA latch pins sticking hard.
I'll probably look into it deeper tomorrow. May start a new thread depending on how it goes.
204549 (A52707)
204549 (A52707)
107" Bucket (A57148)
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
SD Lanch SDLD 25 Rubber Track Dumper (A57149)
SD Lanch SDLD 25...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
Caterpillar T30B Warehouse Forklift (A57148)
Caterpillar T30B...
