What have you done to your Branson today?
   / What have you done to your Branson today? #1,251
Made up a little scuff pad to protect the paint on the fender where you mount the tractor. It’s very easy to kick.
   / What have you done to your Branson today? #1,254
   / What have you done to your Branson today? #1,255
Where did you buy the scuff pad material at?
   / What have you done to your Branson today? #1,257
It’s actually a material I’ve used in motorcycling made by Tech Spec. It’s called High Fusion. Really nice stuff, durable and has reuseable adhesive. I did have to polish off the ceramic paint coating to get it to stick.
   / What have you done to your Branson today? #1,258
Does your range transmission shift easily? My older three speed is really stiff. I used high gear for maybe the 5th time yesterday and the first time that was more than 50 yards, and it really did not want to shift back out. I keep it in second 95% of the time.
   / What have you done to your Branson today? #1,259
Yes, the new H pattern is like butter… it is so easy to shift. I had heard this is a huge improvement over the past range selector
   / What have you done to your Branson today? #1,260
just make sure your following that h pattern religiously.. if you try to shift into the other side( 1-2) to (3-4) too fast you can jump out of the pattern and wedge your linkage, ive fixed 30+ of these since they made the design change in 20, while its not very common it can occur if you're a tad to hasty shifting, while it is a much better design its not without its owns issues.
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
Compressor (A55973)
Compressor (A55973)
40' Sea Container (A55272)
40' Sea Container...
2023 FORD F-250 (A58214)
2023 FORD F-250...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
