What have you done to your Branson today?
   / What have you done to your Branson today? #1,251
Made up a little scuff pad to protect the paint on the fender where you mount the tractor. It’s very easy to kick.
   / What have you done to your Branson today? #1,254
   / What have you done to your Branson today? #1,255
Where did you buy the scuff pad material at?
   / What have you done to your Branson today? #1,257
It’s actually a material I’ve used in motorcycling made by Tech Spec. It’s called High Fusion. Really nice stuff, durable and has reuseable adhesive. I did have to polish off the ceramic paint coating to get it to stick.
   / What have you done to your Branson today? #1,258
Does your range transmission shift easily? My older three speed is really stiff. I used high gear for maybe the 5th time yesterday and the first time that was more than 50 yards, and it really did not want to shift back out. I keep it in second 95% of the time.
   / What have you done to your Branson today? #1,259
Yes, the new H pattern is like butter… it is so easy to shift. I had heard this is a huge improvement over the past range selector
   / What have you done to your Branson today? #1,260
just make sure your following that h pattern religiously.. if you try to shift into the other side( 1-2) to (3-4) too fast you can jump out of the pattern and wedge your linkage, ive fixed 30+ of these since they made the design change in 20, while its not very common it can occur if you're a tad to hasty shifting, while it is a much better design its not without its owns issues.
Dewalt DWM120 5" Deep Cut Variable Speed Portable Band Saw (A59076)
Dewalt DWM120 5"...
EZ-GO Electric Utility Cart (A55853)
EZ-GO Electric...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
ALLMETAL MOBILE PRESSURE WASHER (A58216)
ALLMETAL MOBILE...
2020 KOMATSU PC138USLC-11 EXCAVATOR (A52709)
2020 KOMATSU...
1704 (A58375)
1704 (A58375)
