looking for Yanmar part...
/ looking for Yanmar part... #1
Big Hammer
hello
My Yanmar excavator needs a new part! (solonoid) Hoping someone here might be able to help.
The machine is a ViO50, ser # 10825B, 1998 year
The starter solonoid is remotely mounted up near the battery tray. The solonoid is 'married' to some sort of relay; the relay(?) is actually the suspect component. I beleive that if one were to order the solonoid, it would come with the relay.
The relay is approx 2"X3"X1/2" thick. There are 3 wires comeing from the solonoid into the relay. The relay has a 6" long set of wires that plugs into the harness.
On the relay is part # AST1-11 Hitachi
Any suggestions as far as source to purchase?
Many thanks
Mark
couple more pic's of the solonoid:
...Seems like getting parts may be somewhat of a problem for some of us...
I may have a parts source for (all sorts of) Yanmar parts from a direct importer. Will post my results here! May be of great benefit if you need something specific for your Yanmar tractor.
Mark
/ looking for Yanmar part... #4
Is this a gray market, or a "made for US" machine?
'Thought I wuz buying a US model when I purchased it. Now I am told that it is a gray mkt. model. (Vi050-1)
Not sure what the differences are, but hopefully parts sources are not going to be too much of an issue.
Had I known better, I may not have bought a gray market machine. I paid about the going price for a US model. $15,500 two years ago for a 1998 w/ 3000 hrs. No thumb, has rubber tracks, pretty clean machine.
What is the general consensus here regarding gray market machines?
thanks
Mark
/ looking for Yanmar part... #6
thanks
Mark
There is a huge difference in parts support for rare machines with little or no aftermarket parts. Out of about 150 Yanmar Authorized Parts dealers, (can actually get OEM parts from Yanmar), hardly any will sell parts to a gray market user.
So where are the ones that will sell parts for gray market machines?...:mad:
MArk
/ looking for Yanmar part... #8
I have a Japanese supplier, but before ordering patrts we will need a parts book since Ido not have one for this model. Email me & I'll see if Ican get you one.
...Got the part, came in yesterday. Looks just like the one that went bad. parts are available; just takes patience. Got mine from Dominion.
Thanks for the help, maybe we'll be back in business soon...
Mark
/ looking for Yanmar part... #10
hello
I'm looking for the same part, were did you manage to get yours from
Dominion is the name of the company... I am not home at the moment to get their contact info... will get back with you later in case you cannot find it yourself.
Mark
/ looking for Yanmar part... #13
I can supply the AST11-1 relay.
/ looking for Yanmar part... #14
Can also supply the AST1-11, which is a different relay.
/ looking for Yanmar part... #15
I also need a AST1-11
Are there any good offer on these relay?
/ looking for Yanmar part... #16
I have the same ast1-11 relay in our kobeco yanmar powered excavator. I have bypassed it for now but does anyone know what its actually for? Iam assuming its to lock out the starter motor whilst running given there is a pulse input to it from the alternator???
I’m recalling that it’s a fuel cut-off , but it’s been 14 years since I replaced mine, 🤣👌 and I have a different machine now
/ looking for Yanmar part... #18
cheers and appreciate your input even well after this was posted,
I have found some more information supporting what i assumed the purpose of this relay is for and it suggests its to disable cranking whilst engine is running as well which makes sence to me given it has a alternating signal from the alternator.
https://www.heavyequipmentforums.com/threads/takeuchi-tl150-safety-relay.78743/
According to this from yanmar 4tnv book, relay prevents cranking after starting. (At least that's what I think it says)Screenshot_20190913-231953_Drive.jpg
alternatively or complimentry the yanmar manual states this,
(4) When there is no safety relay
Over-running (when the electric current flows for too long) is a major cause of starting failure. This
burns the armature coil and causes clutch failure. Excessive work and failure of the key switch to
return properly are the main causes of over-running. The user must be given sufficient warning about
this.
Be sure to use the safety relay to prevent over-running. This safety relay is supplied as an option.
Consult Yanmar first when planning to install a safety relay at your own company. In the case of
failure to consult with Yanmar, our warranty will not be applied to all the electrical equipment.
given the hitachi relay is obsolete ( used ones available from breakers at up to 1000 bucks!!) and all modern installations use the NSK (or clone of it available for round 30 bucks ) R11EA i will be looking to substitute it in, have some sumitomo connectors ordered so will see how we go,
/ looking for Yanmar part... #19
a better explination of the safety relay from a kubota manual
The safety relay operates. When the engine speed reaches the rated speed, the alternator P
and safety relay P are connected.
Therefore, the alternator and safety relay are supplied with electric
current.
The signal from the alternator flows to the safety relay and cuts off
the connection between the safety relay S and the starter motor S,
which causes the pinion to be pulled back and the engine to be pre-
vented from overrunning.
/ looking for Yanmar part... #20
Replacement relay came, wired as per Yanmar wiring diagram which took very little deviation from the factory kobelco loom. I left the Hitachi solenoid in place and simply used the new NSK safety relay to pick this up, i also removed the Hitachi module from the Solenoid. . First I bench tested and relay came on, then tested after installing by removing feed to the internal relay contact "A" (as a precaution so the starter wouldnt operate whist engine running) after starting and then operating the ignition switch again with engine running. the relay didnt come on as expected and designed as it detected the pulse from the alternator. So i reconnected the 12v feed to the relay and called in done.
All in all pretty happy to have the protection relay back in play.
A
(5) 3" X 16" HYD CYLINDERS (1) 3" X 12" HYD (A64280)
(5) 3" X 16" HYD...
2025 Mini Bucket Excavator Attachment (A61572)
2025 Mini Bucket...
7 Barrel Masport Vac Pump (A62679)
7 Barrel Masport...
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
1992 21ft Four Winns 205 Sundowner Boat with 21 Ft. S/A Boat Trailer (A61574)
1992 21ft Four...
2025 Auger Drill Bit Skid Steer Attachment (A61572)
2025 Auger Drill...
