Gas string trimmer aka weed eater recommendations wanted
   / Gas string trimmer aka weed eater recommendations wanted #101
No it's not. The straight shaft still isnt $460..in fact is $10 more than your $230 echo.
You assume I have an Echo trimmer, I don't. I have an FS Stihl straight shaft and it was appreciably more than the Echo and I fully expect it to outlast me anyway.
   / Gas string trimmer aka weed eater recommendations wanted #102
I bought a husky 326LX and a maruyama (forget the number) solid steel shafts in both about 20 years ago.
Both are still running strong.
I have only had to replace the fuel lines on both twice in those 20 years.
They are likely to out last me !
   / Gas string trimmer aka weed eater recommendations wanted #103
The curved shaft looks easier to edge a sidewalk... maybe a guy needs one of each?
Buy once, cry once. Look at the Stihl KM trimmer heads. You can put several different attachments on them. The KM 131 that I have is very powerful but they have a lower power model that still has plenty of power. You can add all kinds of stuff to these units. Edger, trimmer heads, chain saws, hedge trimmers, very versatile.
   / Gas string trimmer aka weed eater recommendations wanted #104
Seems its a KM 131 we also have. Its heavy, but a good and powerful unit. I did a review of it on TBN somewhere...
   / Gas string trimmer aka weed eater recommendations wanted #105
I also have the leaf blower attachment and man, has that been an awesome tool. I even use it to blow-off and clean my equipment after each use.
I have a string trimmer attachment, dedicated brush cutter attachment, dedicated saw blade attachment, prune chainsaw attachment, shaft extension attachment and the leaf blower attachment. It’s a very powerful and versatile piece of equipment and well worth the investment.
Mike
   / Gas string trimmer aka weed eater recommendations wanted #106
I decided to go ahead with the KM131 based on your review and recommendations.
   / Gas string trimmer aka weed eater recommendations wanted #107
If you have Milwaukee tools and batteries, buy a Milwaukee string trimmer. I've had a Pro Husky 225R and a Stihl Kombi.
I have 7 acres, including a 1 acre yard. I wish they made the Milwaukee years ago and saved me all the years of hassle. I'm a power tool guy and love things with engines, but a gas string trimmer is a hassle and frustration I can do without. I was incredibly surprised at how well the Milwaukee trimmer works. It's lightweight, quiet, powerful and holds a ton of string. And it starts every time I depress the little trigger. I have a couple of the larger amp hour batteries and one battery will do my whole 1 acre yard.
   / Gas string trimmer aka weed eater recommendations wanted #108
I second the trimmer and have 3 8AH batteries, which covers the amount of work I can do in one shot.
I do the front road area one day, the roads to the house the next and the yard a third day. Now I have some more area in the back woods, so that will be a forth day.
Once a month during the summer, about 2-3 hours each walk.
As long as I get to the heavy grass before it's full grown, have no issues with the trimmer bogging down, and the self feed, easy refill head works great.
   / Gas string trimmer aka weed eater recommendations wanted #109
Not to derail this, but is there a reason you want gas? I switched to a Dewalt 20 volt and would never go back to a gas unit. It seems to be one of the most appropriate uses of battery power for lawn equipment.
Electric here, I have the cheapo Walmart thing does well on lighter stuff, has decent runtime annnd, my wife will even use it. I agree with KennyG, I’ll never go back to a gas string trimmer
   / Gas string trimmer aka weed eater recommendations wanted #110
I'm looking for a recommendation on a brand or even a model you think is better than the rest.
My use is semi-light and seasonal. And speaking of light - Light and powerful would be good. Also I'm 6ft tall if that weighs into the ergonomics.
Thanks for any suggestions.
Depends on terrain, you might consider a walk behind.
2025 K2010 UNUSED Chicken Coop (A50860)
2025 K2010 UNUSED...
2013 Nissan Armada SUV (A50860)
2013 Nissan Armada...
Generac 15KW Generator (A50860)
Generac 15KW...
CASE CX37C EXCAVATOR (A51242)
CASE CX37C...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
