Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #21
Again, not is and never has been an issue with either of mine but then they aren't CUTS either. I know nothing about them and candidly, don't care. Not in my wheelhouse at all.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #23
How many front axles ahve been broken on tractors by lifting something that exceeds the capacity?
It seems ridiculous the manufacturer would have a rated load on the front axle that is less than the weight added by maxing the FEL?
I would suggest that the low capacity number is for a load over rough terrain. Heaven knows that nobody here has ever loaded a bucket and gone bouncing across hills and hummocks but I am sure some have. 😀
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #24
In my view, none are over rated for capacity. It's the owner that overloads them by adding 'ballast' to the tractor, something I don't do.
My little tractor will lift a ton out of the back of my pickup as delivered, but is just a little tippy without something hanging on the back, usually a landplane, box blade, or in winter, a snow blower. Ballast makes loader work safer.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #25
My question is why someone would buy a 1,500 lb lawnmower and expect to operate it like a 10,000 lb skidsteer?
A lot of the SCUT and CUT buyers lack the knowledge and experience to buy the tractor they are. They also are prone to roll-overs and similar things due to no load awareness and the effects of your Cg.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #27
What 1600 lbs worth of mulch and shrub looks like in the BX brochure
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #28
Exactly. If that 1600lb rating is good for when you hit a 6” rut at 8 mph, it’s good for 2000lbs on a stone driveway at 3 mph.
What the axle is rated isn’t just one number.
Hey 50 you probably shouldn't apply for a loader position at this place then 😄
2014 BMW 5 SERIES 4 DOOR CAR (A59906)
2014 BMW 5 SERIES...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59906)
2019 WABASH...
