Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #21
Again, not is and never has been an issue with either of mine but then they aren't CUTS either. I know nothing about them and candidly, don't care. Not in my wheelhouse at all.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #23
How many front axles ahve been broken on tractors by lifting something that exceeds the capacity?
It seems ridiculous the manufacturer would have a rated load on the front axle that is less than the weight added by maxing the FEL?
I would suggest that the low capacity number is for a load over rough terrain. Heaven knows that nobody here has ever loaded a bucket and gone bouncing across hills and hummocks but I am sure some have. 😀
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #24
In my view, none are over rated for capacity. It's the owner that overloads them by adding 'ballast' to the tractor, something I don't do.
My little tractor will lift a ton out of the back of my pickup as delivered, but is just a little tippy without something hanging on the back, usually a landplane, box blade, or in winter, a snow blower. Ballast makes loader work safer.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #25
My question is why someone would buy a 1,500 lb lawnmower and expect to operate it like a 10,000 lb skidsteer?
A lot of the SCUT and CUT buyers lack the knowledge and experience to buy the tractor they are. They also are prone to roll-overs and similar things due to no load awareness and the effects of your Cg.
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #27
What 1600 lbs worth of mulch and shrub looks like in the BX brochure
/ Publishing Loader Capacity Numbers That Far Exceed The Capacity Of The Axles #28
Exactly. If that 1600lb rating is good for when you hit a 6” rut at 8 mph, it’s good for 2000lbs on a stone driveway at 3 mph.
What the axle is rated isn’t just one number.
Hey 50 you probably shouldn't apply for a loader position at this place then 😄
2016 John Deer 5075E (A60462)
2016 John Deer...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
2000 Sakai SV505 (A60462)
2000 Sakai SV505...
150 Gallon Saddle Tank (A60463)
150 Gallon Saddle...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
