Rockbadchild
Super Member
I never thought of octane in terms of more or less power or faster/slower burning.
To me, octane was simply a measure of the tendency of a fuel to ignite when compressed.
That's the biggest misconception out there...
You are correct. Fuel sold in Denver has 2 points less octane.I actually think it’s the other way around. You see a lot of 85 octane fuel sold at higher elevations and it’s my understanding that’s fine if you stay at higher elevations.
Mixed results here. I've had a couple of cheapie string trimmers as well as an old 2 stroke Polaris ATV that were definitely happier with higher octane fuel. Other stuff not as much.I've run chain saws, leaf blowers, snowmobiles, etc all being 2 strokes on everything from 87 to 94 octane fuel and never noticed any difference in performance or longevity
Meet the new boss.All these old 2 stroke street bike riders coming out of the woodwork. Next, y'all are going to tell me you like The Who too!
That was then. Look up "power valve". The exhaust port timing is controlled in every modern 2-stroke dirtbike the past 25 years. Lots of discussion on KTM forums as to the most desirable spring to control the opening for different conditions. Beta adjusts theirs with a threaded shaft making changes in the woods very easy.I know, effective port timing can be changed by the use of expansion chambers and intake manifold changes. Exhaust and intake resonance can be used to control the fuel/air mixture flow into and out of the cylinder. RPM is part of the way resonances are controlled. Nevertheless the physical location of the ports cannot be changed like variable valve timing in a 4-stroke.
Yamaha had the YPVS power valve and other makers had theirs too:That was then. Look up "power valve". The exhaust port timing is controlled in every modern 2-stroke dirtbike the past 25 years. Lots of discussion on KTM forums as to the most desirable spring to control the opening for different conditions. Beta adjusts theirs with a threaded shaft making changes in the woods very easy.
The last RD400 was the first I remember having a power valve in the exhaust.
I didn't know about the power valve. Thanks. Though I really liked 2 strokes at first I became disenchanted with them for several reasons, the main ones being poor fuel economy and the oil sheen from outboard motors. Things have really changed since my RD 350.That was then. Look up "power valve". The exhaust port timing is controlled in every modern 2-stroke dirtbike the past 25 years. Lots of discussion on KTM forums as to the most desirable spring to control the opening for different conditions. Beta adjusts theirs with a threaded shaft making changes in the woods very easy.
Not to mention the smell of the exhaust.I really liked 2 strokes at first I became disenchanted with them for several reasons, the main ones being poor fuel economy and the oil sheen from outboard motors.
I always found the smell of 100 octane burning in my RD400 mixed with the oil thrilling.Not to mention the smell of the exhaust.
I too was concerned about fuel mileage when I took my 1999 Husky 360WR to Baja. Turned out I used less fuel than another guy riding a Yamaha YZ450. My 2016 TE300 uses even less and using Amsoil at 50:1 neither one smoked.I didn't know about the power valve. Thanks. Though I really liked 2 strokes at first I became disenchanted with them for several reasons, the main ones being poor fuel economy and the oil sheen from outboard motors. Things have really changed since my RD 350.
Eric
Yes, I miss that too!!!!!Castor Bean oil smoke....yummm.
If I one day put my RD400 back together, I'll try that. Otherwise, I'll have to contract out to the county to fog for skeeters just to make it legal.I too was concerned about fuel mileage when I took my 1999 Husky 360WR to Baja. Turned out I used less fuel than another guy riding a Yamaha YZ450. My 2016 TE300 uses even less and using Amsoil at 50:1 neither one smoked.
