octane and 2-strokes
/ octane and 2-strokes #22
Elevation also plays a role in octane. The higher the elevation, the easier it is to pre-ignite a lower octane fuel.
For my twin turbo truck, premium is a must at high elevation to not have the timing so retarted that it robs all the power turbos were designed to produce.
/ octane and 2-strokes #23
I actually think it’s the other way around. You see a lot of 85 octane fuel sold at higher elevations and it’s my understanding that’s fine if you stay at higher elevations.
/ octane and 2-strokes #24
/ octane and 2-strokes #25
you guys are correct...Also elevation will reduce your HP, mountain sleds will run on 91+ octane or even airplane fuel since they turbo charge them swap the heads to increase compression and play with their fuel/air delivery via fuel controller in order to produce the same HP at elevation then at see level...
/ octane and 2-strokes #26
I've run chain saws, leaf blowers, snowmobiles, etc all being 2 strokes on everything from 87 to 94 octane fuel and never noticed any difference in performance or longevity
Mixed results here. I've had a couple of cheapie string trimmers as well as an old 2 stroke Polaris ATV that were definitely happier with higher octane fuel. Other stuff not as much.
/ octane and 2-strokes #29
A lower AKI (not "octane") is acceptable at higher elevations because the issue is not compression ratio but the compression chamber pressure.
A lowly Prius has a 13:1 mechanical compression ratio but with variable valve timing and throttle-by-wire happily runs on 87 AKI. The ECU manages load keeping combustion chamber pressures down. Will give an CEL if fed 93 AKI.
/ octane and 2-strokes #30
I know, effective port timing can be changed by the use of expansion chambers and intake manifold changes. Exhaust and intake resonance can be used to control the fuel/air mixture flow into and out of the cylinder. RPM is part of the way resonances are controlled. Nevertheless the physical location of the ports cannot be changed like variable valve timing in a 4-stroke.
That was then. Look up "power valve". The exhaust port timing is controlled in every modern 2-stroke dirtbike the past 25 years. Lots of discussion on KTM forums as to the most desirable spring to control the opening for different conditions. Beta adjusts theirs with a threaded shaft making changes in the woods very easy.
The last RD400 was the first I remember having a power valve in the exhaust.
/ octane and 2-strokes #31
Yamaha had the YPVS power valve and other makers had theirs too:
Two-stroke power valve system - Wikipedia
I didn't know about the power valve. Thanks. Though I really liked 2 strokes at first I became disenchanted with them for several reasons, the main ones being poor fuel economy and the oil sheen from outboard motors. Things have really changed since my RD 350.
Eric
/ octane and 2-strokes #33
Not to mention the smell of the exhaust.
/ octane and 2-strokes #35
RD400, no power valve.
RZ350, power valve and liquid cooled. Plus catalytic converters for American models.
/ octane and 2-strokes #37
Eric
I too was concerned about fuel mileage when I took my 1999 Husky 360WR to Baja. Turned out I used less fuel than another guy riding a Yamaha YZ450. My 2016 TE300 uses even less and using Amsoil at 50:1 neither one smoked.
/ octane and 2-strokes #39
If I one day put my RD400 back together, I'll try that. Otherwise, I'll have to contract out to the county to fog for skeeters just to make it legal.
/ octane and 2-strokes #40
as a footnote to pre ignition & octane count. my 4x4 Toyota 4 cyl began to ping a lot after hitting 200k. previous, went w/87 but gradually pinging got worse. took me a while, but figured with that mileage, carbon build up hot spots on piston caused pre ignition with lower octane.
been using 91 ethanol since & the pinging has completely disappeared.
the original engine (never opened) now has 305k & runs like new, compression still holding 185 to 200 psi.
glad i discovered the higher octane advantage & non ethanol before damage to pistons.
like modern tractors & vehicles, i will never own one w/regen or all the damn sensors, etc.
