octane and 2-strokes
   / octane and 2-strokes
I'd love to own a Kenny Roberts Yamaha RD 350. Last screamer I owned was a Kawasaki H1 triple. Kind of surprised I'm actually still alive. Way too much motor in way too little frame with marginal brakes.
Yeah, I rode an RD350. It was fast. I made it even faster. It eventually burned a hole through a piston. I goofed somehow when modding it. It was so damn fast but was running too hot apparently. I sold it after I burned that hole in the piston. Good thing too, it was too fast for my skill.
Eric
   / octane and 2-strokes #12
I've been told by a small engine mechanic that if you store gasoline it should be the higher octane because as the gasoline ages, the octane number goes down. Thus if you start with 87 octane and it goes down it becomes unusable. I've also been told that small engines need a minimum of 87 octane to run, so I've been using 92. Any one able to confirm this or correct this?
   / octane and 2-strokes #13
I've run chain saws, leaf blowers, snowmobiles, etc all being 2 strokes on everything from 87 to 94 octane fuel and never noticed any difference in performance or longevity
   / octane and 2-strokes #14
I took 4 strokes to the track - Norton & Ducati.... , but loved the slower 2 strokes for weekend mountain riding and touring around the state. For longer trips to the East or West Coast I took other bikes of course,
But for just putting through the mountains I liked my old Jawa CZ 350 Californian. After all these years it's the bike I think about. Marvelous craftsmanship on that Jawa. Funny thing is I owned or worked on and rode most every British bike made....the Atlas, Goldies, REs, Matchless --- but it's the old black BMW and that Jawa I remember best. Both were simple & slow, both surprisingly well-balanced and comfortable. Actually sort of tractor-like.
The shop had a couple of Suzukis that were popular as loaners. The 250 X6 & 500 Titan were deceptively fast, nervous, flashy, quiet, indestructible and chrome/ugly.
rScotty
   / octane and 2-strokes #15
All octane dose is it makes the gas more stable to compression/heat so it initiate when the timing dictate it and not before. Any compression of any gas or object will generate heat so these two are link, it all depend the compression of that specific engine. I use 91 for my quad since its a 1000cc and it generate a lot of heat my 450WR he get 91 as well its a high performance engine so it need it, then my snow blower and chainsaw gets it as well only because there isn't any ethanol in 91 gas.
   / octane and 2-strokes #16
Back in the 70s I rode 2-stroke bikes and used lawn mowers with 2-stroke engines. I really liked 2-strokes because of the high power to weight ratio. Interestingly, all the manuals for the bikes said not to use high octane fuels for the best performance. 89 was usually suggested. I did stuff to my bike engines to get more power. Things like porting and raising the compression and using expansion chambers. I had lots of success increasing HP and RPM. The reason for the low octane rated fuel, I was told, was because the gas would burn faster and this was necessary because as much power as possible must come before the exhaust ports are effectively open. I know, effective port timing can be changed by the use of expansion chambers and intake manifold changes. Exhaust and intake resonance can be used to control the fuel/air mixture flow into and out of the cylinder. RPM is part of the way resonances are controlled. Nevertheless the physical location of the ports cannot be changed like variable valve timing in a 4-stroke. The long preamble is just so you know why I am curious why so many folks these days talk about how higher octane is desirable in 2-stroke engines. I saw this once again in the recent E15 ethanol thread. Octane does not add heat energy, it just helps control burning. Higher octane being slower burning. And adding ethanol, while increasing octane, actually lowers the heat energy of the gasoline and ethanol mix. But by increasing octane the compression ratio can be raised and this will allow getting more energy from the fuel. Which in 4-stroke engines is usually a good thing.
Eric
I had (still have in little pieces) a 77 RD400 that I used to drag race at the local strip. Higher Octane gas prevents pre-ignition, and that's about it. You can get pre-ignition in a 2 stroke from high compression, carbon deposits in the cylinder head, things like that. I had higher compression and free access to 100LL avgas at the time. It ran very nicely, especially on cold days when the air was denser. Otherwise, I just ran regular gas most of the time, when I wasn't beating on it.
It would turn very consistent 11:92 at 119mph. Not bad for 25 cubic inches.
   / octane and 2-strokes #17
Im lucky I can get 91 octane ethanol free fuel. For a while I was using 87 octane ethanol free. I never knew what was worse, running to low an octane or using 10% ethanol. Stihl is saying 89 octane in their manual for their chainsaws.
   / octane and 2-strokes #18
The oil in 2-stoke fuel will lower the octane 1-2 points hence the need for slightly higher octane to start with.
Alcohol does act as a cooler but it is also an oxygenator which adds heat.
I tend not to mess with the ports in the cylinder. I have matched the bottom of the transfer ports to the bottom of the piston at BDC and get good results. This adds flow without changing port timing. Also, mill head to get squish area down to 0.04".
Past bikes: Two H1 500, Mach III 500, H2 750 (high comp,ported,carbs,chambers), and 2 Quadracers, a 250 and a 500. (short list)
   / octane and 2-strokes #19
I never thought of octane in terms of more or less power or faster/slower burning.
To me, octane was simply a measure of the tendency of a fuel to ignite when compressed.
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
