Pat’s Quick Hitch / flail mower
/ Pat’s Quick Hitch / flail mower #11
Looks like I’m gonna be ordering Pat’s (when exactly does a person stop spending more money on their tractor?!?:LOL: )…
Your tractor and money is like your kids and money, there is always something ....
But ain't it fun?
/ Pat’s Quick Hitch / flail mower #12
One aspect I like about Pat's QA is the bolt on application. This means I can remove it and the tractor is unchanged.
One thing I didn't like was having to extend the top link connection 4 inches. Again I made a spacer I could remove if I change my mind about this modification.
Below you can see a bit of the top link extension and the PTO extension which is in the form of a quick attach also. It is super easy to change attachments now. I marked the spacer bar that comes with the Pat's QA for each attachment. Just set it to width and back in and lift.
I did mod the PTO shield angle and reinstall.
/ Pat’s Quick Hitch / flail mower #13
One aspect I like about the QH is that I knock the pins out and drop it. This means I can remove it and the tractor is unchanged.
:ROFLMAO: :ROFLMAO: :ROFLMAO:
/ Pat’s Quick Hitch / flail mower #14
QH and QA are 2 different things.
I bought a QH and sold it before using it.
The QA is a better way to go.
/ Pat’s Quick Hitch / flail mower #15
I know the difference. I'm one of the ones that wouldn't own a Pat's system but that's just me. Most of my attachments I never have to get out of the cab to attach. Only the ones with PTO.
/ Pat’s Quick Hitch / flail mower #16
Glad you found the hitching option that works best for you. Sounds like a strong opinion.
Have you used a Pat's QA?
I have a collection of old and new attachments.
They vary in width so a QH will not work for me.
Pat's was the logical solution.
/ Pat’s Quick Hitch / flail mower #17
I understand. I had the same thing and modified all of mine to fit my QH. I've seen the Pat's in use but it just isn't for me. I would still have to get off the tractor to connect the top link and honestly if I'm doing that I might as well connect with my extending links. With mine I never get off the tractor unless as I said if it's a PTO implement. And the other thing is I have several implements in excess of 2000 pounds. I just don't know how a set of bolt on QA hooks will work with that weight. Nah, I'm a QH guy all the way.
I have a QH on my other tractor (MF 135)… I’ve been accumulating implements second hand (‘cept my BB… got 25% off at Murdochs sale), as such, many implements aren’t QH compatible… found out rather quick that my implements also don’t play well with each other (as far as the QH was concerned)… I settled on a method that works for me… my “quick hitch” is only a “slightly quicker/easier hitch”… I remove the top hook, catch the lower pins with the lift hooks then install the top hook upside down to capture the top pin… obviously I can’t do most of this “from the seat” but I also don‘t have to wrestle the BB into position where it lines up correctly …
Enter Pat’s QA… if this works well on my new tractor I may get a second set for the Massey…
If I had the capability of modifying my implements, I could make good use of a QH… when they work on YouTube they look incredibly convenient, unfortunately my “home shop” welder (and my less-than-perfect welds) won’t hold up to being tugged around by even a small tractor… and I don’t have a hope of drilling a 7/8” hole in mild steel with my hand-held drill…
/ Pat’s Quick Hitch / flail mower #19
TBN people giving their opinion on something when they don't even know what it is is just a waste of everybody's time.
/ Pat’s Quick Hitch / flail mower #20
Everyone has their opinion on which is best a QA or QH. Like so many others I prefer the Pat's for the simple reason it will connect to every implement without having to "mod" any of them. Simple fact is not all implements (which is a shame) are QH compatible so unless you are independently wealthy and can purchase all new... Most of us have or have bought older used implements for use in our tractoring careers and the Pat's will connect, only require a longer top link or PTO extension. For me the Pat's was the way to go since most every implement I am using requires the PTO to be connected and the top link is hydraulic so that is a no brainer.
IMHO, it comes down to personal preference, one is not necessarily better than the other so I see no need to put down either style. There are trade offs with each so it all comes down to what fits ones needs, just choose the one that makes ya happy.
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Autocar...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
2022 John Deere Z930M (A57148)
2022 John Deere...
2016 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRUCK (A59823)
2016 FORD F-550 XL...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2016 TAKEUCHI TB216 EXCAVATOR (A62129)
2016 TAKEUCHI...
