TYM 494 or Branson 4820
/ TYM 494 or Branson 4820 #124
We are tilling a couple acres this year!
Something to think about. On many soil types, tilling creates a great seedbed, but over time it forms a plow pan of hard soil just below the tiller depth. I have a ripper plow (Fred Cain style) that I use to open the soil and break the plow pan before tilling in the spring. Then I also rip the ground in the fall after putting the garden to bed. This allows snow to accumulate deep moisture over the winter.
/ TYM 494 or Branson 4820 #125
Your uses may differ. For my uses, I would rent the box blade and buy a good rear blade.
Not saying you're wrong and I'm right but I have a hydraulic angle rear blade I bought new in 2013 and I think I've used it twice. My box blade gets used daily all summer for road building and maintenance. They can do almost anything a rear blade can do with all the different adjustments they have.
I thinks it's one of those things where you need to try both and see which one you prefer working with.
Yeah, I’ve watched folks do some amazing work with a box blade
/ TYM 494 or Branson 4820 #127
Just saw your tractor . Sweet! I have never looked at these other brands before, but now that Kubota raised their prices so high in Canada I've been looking at other brands.
These Branson's seem to have a lot for the dollar.
I found a cabbed 5520C with loader and backhoe for $56,000.
A USED Kubota Grand L with loader and backhoe is $90,000 here. I can't even buy a 26 h.p. Kubota with cab and loader for the price of that 5520C!
And the ability to "repair" the DPF really interests me also.
Yeah, so the legacy Branson models are a little more expensive than the comparable TYM legacy models, but I do think the build quality justifies it. Better fit, finish and paint quality. Also, welds on the TYM 494 were pretty rough. If you looked at the fender welds and the platform mud guard welds. Not saying they are not a reliable unit, but I noticed this right away. The Branson unit has much nicer it and finish
Yes, the no ECM engine means that you can fix DPF issues without throwing the engine into limp mode.
/ TYM 494 or Branson 4820 #130
I have a blade with guide wheels and a box blade, but I hardly ever use the blade. We have a steep drive. The box blade has been good for dragging gravel back up the hill when it washes down the hill. I rarely use the rippers, but used them recently to repair my neighbor's potholes in his driveway.
/ TYM 494 or Branson 4820 #131
So when you say "Legacy" models.....are these still being produced and available? I guess they must be, the one I saw for sale is a 2023?
Yessir. My local TYM dealer is getting all of the 15 and 20 series 2023 models. TYM has also been putting the A series diesel made by Kukje in more of their own models too, as customers have asked for it. The 4820 is a nice little NA machine
/ TYM 494 or Branson 4820 #135
Pretty sure you can buy a 3515, which has an IDI engine and can be equipped with a cab
You sure can!
Not much on TractorHouse for Branson's in Canada, so this is in the States, but lots of photos.
I really like Branson, and came real close to buying one; just ended up being more comfortable with the Kioti dealer. You really can't go wrong with them!
I'm jealous, but right behind you, well maybe another 6 weeks or so. It seems like we have shared much of this journey. I'm looking forward to your posts when you start putting it to work.
So, are we taking delivery this week? 😁
/ TYM 494 or Branson 4820 #139
574. I cannot pass up the extra HP for only about 1500 more.
My only problem now is getting complete prices from my 3 dealers.
/ TYM 494 or Branson 4820 #140
This sure hit the spot, I am in the same boat, 4820 or 494. They both have pros and cons but the pros seem to lean more to the 494.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
(10) UNUSED SDLANCH RS5007-2" RATCHET STRAPS (A65055)
(10) UNUSED...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A65055)
UNUSED RAYTREE...
2025 10,000lbs. Two Post Auto Lift (A64194)
2025 10,000lbs...
