Barndominium/Shop or "real" House?
/ Barndominium/Shop or "real" House? #181
What is the advantage to 8 foot tall garage doors? Seems like a huge expense making the entire building taller, and paying more for 8 foot tall doors over the standard 7 foot tall doors.
My ten foot wide, 7 foot tall, insulated doors are almost $1,700 each for just the basic doors. I haven't decided on the openers yet.
/ Barndominium/Shop or "real" House? #182
I put a 7' high door in my garage addition. It's only used for storage, and my little machine, so it's no big deal. But my front garage has 10' high door. I can drive the suburban in with a canoe or my mother in-law's van in with a car-top box. The few times I needed it, I was happy.
/ Barndominium/Shop or "real" House? #183
In the OP's case he simply made the hole larger, not the building. I totally agree with that philosophy. All it cost him is the additional cost of the door size. I had two 7x9 doors in my previous house garage. I hated them. But in that case I didn't have a choice. When we built this time we calculated in larger doors. The wife's attached garage door is 8x12. Much more comfortable to use.
/ Barndominium/Shop or "real" House? #184
I have a 10x10 door on my workshop, and I think it's too small. I should have gone 12 feet wide. Whenever I get around to building my dream workshop building, I'll get the tallest doors that I can fit in the building. Hopefully 14 feet tall so I can drive my backhoe into it.
But for a garage, where you are just driving automobiles into it, why would you want to spend the extra money to make the entire building a foot taller so you could have 8 foot tall doors, when you have a huge workshop right next to the garage with doors that are a lot bigger?
/ Barndominium/Shop or "real" House? #185
Not that much change required for 8ft doors. Seems like a no-brainer:
I wasn't paying attention to the inches in the two drawings. It looks like the overall height of the building is increasing just a couple of inches to get the 8 foot tall doors. Not as big of an expense as I first thought.
But I still don't see the advantage to spending the extra money on 8 foot tall garage doors
/ Barndominium/Shop or "real" House? #186
My shop doors are 12x12. I have to lower the boom on my hoe to get it in. I didn't want to spend the money to raise the building another 2ft to gain a 14ft tall door.
Again, in the OP's case all he did was redraw the door openings. This is based on his comment and his drawings. So in his case, why would he put in smaller doors?
No different than you building a new shop with 16ft eaves and putting in 12ft doors.
/ Barndominium/Shop or "real" House? #187
I thought Moss gave very good reasons.
/ Barndominium/Shop or "real" House? #188
Vans or pickups with roof racks, even some suburban style vehicles, a pickup with an appliance in the back. Numerous reasons too.
/ Barndominium/Shop or "real" House? #189
On our garage addition, I put a row of concrete block all the way around the edge to raise it 8". I like to hang things from the ceiling and every bit helps. Bikes, boats, pool toys, car bodies, etc. So any additional height to me is worth it. Even in our 10' front garage I sometimes wish for more headroom.
The overall building height didn't change. I moved up the floor for the living space which made those celings less than 8 ft, so I put in scissor trusses to gain taller ceilings in the living area.
/ Barndominium/Shop or "real" House? #191
I noticed that. Nice touch!!!
So I'm thinking, if I go with scissor trusses in the living space, is there a benefit to having them in the shop space? I plan to have steel on the inside of the shop, walls and ceiling. Probably go with 4ft of plywood up the walls from the concrte slab, then transition to steel, so work benches and other stuff are not digning up the steel and I guess the plywood can be replaced later if it gets beat up.
Scissor trusses make it harder to install steel on the ceiling?
Not sure I can think of many benefits over just normal gable trusse in the shop.
/ Barndominium/Shop or "real" House? #193
I can't think of a logistical reason to do them in the shop. Your eave is plenty high enough to give you tall ceiling height. Might be some asthetics if that matters to you?
I don't think it would be much harder to install the ceiling. If the center is in the middle of a panel I'd just try to curl it to fit. If that can't be done, cut and then finish with trim.
There's a mile of difference between a 14ft ceiling and a 16ft. My shop is 14, Son's is 16. I don't see any need for scissor trusses in his shop.
Laying in a 5 Ton Bridge Crane:
Normally the crane columns are tied into the wall columns of the building for anti-racking support. Not sure this can be done with a wood post & beam frame building? Normally these are installed in steel buildings.
/ Barndominium/Shop or "real" House? #195
When I saw you fantastic crane I got this crazy idea while thinking of the difficulty of moving your furniture upstairs ...
That closet arrangement does look better. I was not a fan of the way I had the door to the balcony all the way in the corner.
For the stairs I didn't have a door like you show because I wanted to pull the wall back toward the north and have a removable railing for furniture moving. However a door for the stairwell might be a good idea to further isolate the shop from the living space.
/ Barndominium/Shop or "real" House? #197
I figured if I took the stairs out of the well and put them on the east wall of the shop you'd have more room to sort things out 🙂
/ Barndominium/Shop or "real" House? #198
Still need to put in the shop bathroom.
A toilet and sink would fit nicely under a relocated stair case on the east* wall of the shop and tie in easily with your existing plumbing.
*I said north wall but I think it's east.
I figured if I took the stairs out of the well and put them on the east wall of the shop you'd have more room to sort things out.
Yeah, my design started out that way but I moved them in to reduce the square footage. Taxe$$$$...
/ Barndominium/Shop or "real" House? #200
I want one of these soooo bad. I just can't justify it for no more use than it would get. But I still want one!!!!
2014 Freightliner M2 106 24FT Reefer Box Truck (A59230)
2014 Freightliner...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
Wacker Neuson VP1550AW Vibratory Plate Compactor (A59228)
Wacker Neuson...
