New L2501
/ New L2501
I'm liking these ideas of using a box blade as a work bench / carry-all. I'm trying to locate a used one. Does it matter whether 5' or 6'? Both have Cat 1 and are wistin HP range.
The mid PTO was not a consideration for me. I have a 72" Scag Turf Tiger that handles all the mowing.
/ New L2501 #27
Get one as wide or wider than your rear wheel spread.
/ New L2501 #28
I think this is a great size tractor. My brother has this model. He can do most everything my MX 5400 does. Just takes a bit longer on some projects. My MX is a just over two years old. I looked into downsizing but the value of my 2 year old tractor is about the same as a new L2500 when equipped in a similar fashion. I have 23 acres but have done most of the “big” tractor work and maintaining is where I am today. I also have a BX tractor and a Kubota zero turn. So I am at the overkill stage with equipment 😀
/ New L2501 #29
I have a MX and only 20 acres. I think it’s the perfect size for the land. I mow much of the acreage, so I appreciate the ability to use a larger cutter. I also appreciate the ability to use a heavy blade for road maintenance and the stability for loader work.
/ New L2501 #30
I bought my L2501 HST last March and have been very pleased with the grapple work I've been able to accomplish with it. There's no way I could have gotten as much done in the past year without it.
But...I spent about a month either making or buying various guards to protect the grill and filters before I started using the grapple. Part of me can't believe that Kubota's filters are so exposed IMPO on the belly of the L2501 or that the plastic front grill is so vulnerable to sticks in OEM state. Fortunately, it's fairly easy to add expanded metal or mesh to the front guard to protect the grill and radiator. Adding guards to protect the filters under the tractor is more challenging, but they can be purchased from a couple of different sources if you don't want to mess with making your own.
/ New L2501 #31
I like the idea of using the box blade as a work bench / carry-all. I'm trying to locate a used one. Does it matter whether 5' or 6'? Both have Cat 1 and are wistin HP range.
LINK: USA or Canada Manufactured TRACTOR 3-Pt. TRANSPORT BOXES / DUMPING CARRYALLS
With <26 horsepower you will be better served by a TPH Category 1 Box Blade with a 60" operating width. It is highly probable you tractor will stall out with a 72" box blade filled with dirt. You are more likely to cut hard Texas dirt and move more total material per hour with a 60" Box Blade, assuming a 60" Box Blade covers your L2501 tire tracks as tractor was configured by the dealer.
/ New L2501 #32
For sure you want 60". I have a pair of 25 and 26 hp tractors, my 1560 Land Pride is all they can handle. Even if it is sightly smaller than the tire footprint. Box blades gobble hp as bad as snowblowers.
/ New L2501 #33
Yes, good choice. Since you've already purchased pallet forks, I would suggest getting a box scraper. You will probably find that you have some dirt to level out, but it will also help to counter balance your lifting load. Also, look into water filling the rear tires if not already done.
Also look up Pat's quick hitch and hydraulic mid-link arm for it.
/ New L2501 #34
I drove 3 hours away...and got the exact same rig for $3700 less.
Good for you. Best way to fight inflation is to hold on to your cash. "THEY" can't survive without 'BUYERS.'
Back in Community College, you learned about Business Cycles, right? Well, all cycles come to he who waits for it!
/ New L2501 #35
Right Arm! Love that set-up! Wish I'd known about the Quick Attach things for the front when I bought my Kubota! ut the Pats are well worth the $
/ New L2501 #37
Water filling tires ? never heard of that, hopefully you live in an area where the temperature is always above 32° Fahrenheit, if you are you're a lucky 👦 enjoy the weather 😉
/ New L2501 #38
Welcome to the forum. Enjoy.
I'll double down on the previous avice about counterbalance if you don't have something. Liquid filled tires were my choice...and they make a world of difference.
/ New L2501 #39
If you have a gravel driveway, a landscape box on the 3pt would to be useful to maintain your drive and help with the ballast situation without resorting to fluid/beetjuice in the tires.
Most box blades suitable for that size tractor are pretty light weight. I recommend both the implement and tire ballast of some kind.
/ New L2501 #40
Water filling with an anti-freeze agent.
2011 AMERICAN 14 T/A DOG HOUSE (A65643)
2011 AMERICAN 14...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
2022 EZ-GO ELITE...
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
2014 QUALITECH FUEL POD TRAILER (A65643)
2014 QUALITECH...
