Newbie shopping 1st tractor
/ Newbie shopping 1st tractor #1
bthom70
Southbury, CT
Bobcat CT2025
I'm in CT and have Kioti, Bobcat and Kubota closest to me. Started pricing Kioti CK2610 and Bobcat CT2025. Bobcat was swinging my vote until I started reading about the FL7 loader issues and less lift # compared to Kioti. Bobcat has a better dealer network and more staff vs. Kioti. This Kioti dealer is primarily power equipment and also sells tractors for 25+yrs but only has 1 dedicated tractor employee.
Kioti CK2610 is about $1,000 more than Bobcat CT2025 both with 3rd function. I did get pricing from a Kioti dealer in Katonah NY, only 10-15min further travel and he was $2,000 less than CT. I need to call Bobcat and have them quote a CT2035 next. I'm going to Katonah this weekend to work out more numbers for CK2610 and CK3510. This dealer is 1/2 tractor, 1/2 power equipment and has more tractor employees.
/ Newbie shopping 1st tractor #2
I'd personally pay close attention to the dealer, and the feeling you get from them; I can't imagine you'd go wrong with either, so long as all the dealer prep was done properly.
I love my CK2610, it's been great.
/ Newbie shopping 1st tractor #3
If you can ask the dealer if you can take test spin in there yard.
Have the tractor controls come to you and comfortable seat operations.
Also check the service department.
Should I even consider the CK3510? I'd rather not regret later. Cleaning up 3acres of downed trees and brush.. Took down 12 standing dead oaks and have 24-30"+ logs to cut and split. There will be plenty more in future years.
/ Newbie shopping 1st tractor #5
Check the lift specification a little closer. The Bobcat is measured at the lift point to the highest lift point, 1369 LBS @ 95". The KL2610 Kioti loader is 1252 LBS @98.2". Please understand that is at the lift point. When you put a pallet fork on the loader and lift at the middle of the fork it will pick up less, that is true with all loaders.
/ Newbie shopping 1st tractor #6
Get a Quote on a CT2040 it is only $600 more.
/ Newbie shopping 1st tractor #7
There is one question to ask; do you mind working a little slower?
The 2610 will do everything the 3510 can do, it's just going to do it a little slower, and that's guaranteed. In return you get a little more simplicity, and that's what sold me over the higher horsepower machines. I already work pretty slow, so it's not a thing for me.
With that said, I refer to the actual working speed of the machine, not the hydraulic speed, the hydraulics are great.
/ Newbie shopping 1st tractor #8
Are you still seeing KL2610's? I'm seeing the KL4030 and KL4030C on all the CK series these days.
I wouldn't bother with any of the other loader options, assuming they're still available. The KL3040 should have been on them from the start.
[EDIT]: Whoops.
Are you still seeing KL2610's? I'm seeing the KL3040 and KL3040C on all the CK series these days.
I usually see KL4030 on all CK2610
/ Newbie shopping 1st tractor #11
I am very happy with my 2025 at 103 hours. When i was shopping during summer 2021 there was a substantial price jump to the 35 and 40. Tried them both, for my use totally satisfied with the 25hp. I have 2 long time dealers within 20 miles and service has been excellent.
/ Newbie shopping 1st tractor #12
[EDIT]: Whoops.
Can you tell me what the lift capacity is to the highest point? Kioti is a little tricky with the lift capacity on the KL4030? All other tractor MFG's give the capacity to the highest point, 98.4".
We not not comparing apples to apples.
/ Newbie shopping 1st tractor #16
I wonder what the truth is? The geometry does not work that way.
Typically the weight drops as the height increases, so I'm pretty excited about my Kioti's ability to defy physics.
I've not lifted anything heavier than a half-pallet of shingles and my father-in-law, and I don't rightly know how much that was.
I do know that man doesn't weigh more than 200. 🤣
/ Newbie shopping 1st tractor #17
Thinking about it, I don't rightly know if I'd want to move almost 2k pounds at full height. Even well ballasted I can't help but feel that's asking for trouble.
/ Newbie shopping 1st tractor #19
All it takes is one root or hole, and you can find yourself quite surprised.
/ Newbie shopping 1st tractor #20
it'd help to describe a bit of what you intend to be doing with the tractor...the tasks...how large is your property. I'm a John Deere guy so not familiar with models you're looking at but it seems other are and I'd say would be able to help you better by understanding what you're using the tractor for.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2015 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2015 Nissan...
