Doorman’s next big adventure
   / Doorman’s next big adventure #51
Go as big as you can with the door! You'll never regret it.
Also I noticed in the plans that you have an overhead door and your sliding doors in the same area of the building. Overhead from the side and sliding from the end. Unless there's a real good reason for it, having 2 larger doors in the same corner of the shop seems a bit redundant. You won't regret spacing them out a bit more to serve different area's of the shop.
Edited to add that I realize that eventually this is going to be your wife's building and what she wants, she wants, but I would point this out to her and get her to think about it for a bit.
The shop is only 20x24……not much room to spread them out.
Update…….
Reached out to the builder……..
Timeframe pushed back to April.
The slab most likely sooner.
The slab sooner means I’d probably have all utilities and the driveway done before the buildings even built.
Father in law is a bit bummed.
He’s gonna be back from Florida in early May.
   / Doorman’s next big adventure #53
Update…….
Good news, I think. :)
FIL just doesn't want to miss out on anything!!!!
   / Doorman’s next big adventure #54
Did he say why it's being pushed back to April? When was the original start date? Are you getting any red flags? Always trust your gut when things start happening that you didn't expect to happen, and the reason doesn't make sense. In every case that I've come in to fix or finish a job, the client knew almost from the beginning that they where in trouble with their contractor.
No real red flags
Weather/material delays.
They’ve always been responsive when reaching out and honest about how busy and short handed they are
   / Doorman’s next big adventure #56
No real red flags
I assume your weather is similar to ours. April start isn't far off. Heck it may set in and rain the entire month of March.
Motion going forward on the barn build is slow…….
Talked to contractor last week and he’s supposed to get the forms/stone/grading done this week.
3 of his guys quit…..weather has been wet…..all a bit frustrating.
After forms are up I do underslab work next weekend
Electrical pipes
DWV for bathroom/kitchen/laundry.
If he pours the following week things will move forward
Water/septic trench
150’ gravel driveway
Electric pole/meter/disconnect
These tasks require the builder to do his part first……fingers crossed!!
   / Doorman’s next big adventure #58
Who is doing the rebar?
   / Doorman’s next big adventure #60
NEVER EVER use wire in concrete. For it to work, it has to be pulled into the concrete while pouring it. Usually they will pull it up when they first get started for pictures, but as soon as the work gets serious, nobody has time for posing for fake pictures. As soon as they pull it up, they walk on it and push it back down again. There are few absolutes in construction, but one of them is that is wire is used on a slab, it's on the bottom of the slab, not doing anything. The reason they like to use wire is that it's cheaper, faster and easy for them. If you are doing something small, and you do not have to walk in the concrete while spreading and leveling it, and the wire is in the middle or bottom third of the slab, then it's great. Since this is IMPOSSIBLE to do when walking on it, any contractor that wants to use wire instead of rebar should be fired immediately.
Same thing if they use rebar, but don't use chairs. If chairs are not used to support the rebar during the pour, the rebar will end up at the bottom of the slab and be worthless. Hack contractors don't like to use chairs because they trip over the rebar, and it makes it harder for them to spread the concrete.
Fiber is a fun gimmick that doesn't really accomplish much. Sometimes the fibers stick out of the slab when it's done and that can be really annoying. If used with rebar, and they mix the mud with too much water, fiber can help hide some of the cracking.
Concrete cracks because of too much water. When the excess water evaporates, a void is created in the slab, and it cracks. When pouring, the concrete should not flow smoothly, or be like soup. It should be like mashed potatoes. You want it to pile up, not spread out. When mixed properly, it's a lot more work for the crew to spread it. When water is added, it gets easier for them to spread it. Some will just keep adding water to the point of making soup.
FORD DEXTER TRACTOR (A52708)
FORD DEXTER...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
DRAFTING TABLE, METAL MOTOR STAND (A58374)
DRAFTING TABLE...
Kubota MX5200 (A57148)
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
