Quick attach root ripper for M59
/ Quick attach root ripper for M59 #1
M59
Fairview NC
Kubota M59 TLB/ Mahindra Max 24 TLB/ KX-080-5
Just received and installed a root/ frost ripper onto Kubota M59 TLB modified with quick coupler that mates to the Kubota KX excavator series of buckets and tools and was mentioned in earlier thread ( Backhoe - M59 backhoe quick attach) started by Smokeydog.
In another thread ( Digging stumps SA425) started by Scott440 I mentioned I spent two hours trying to remove a 20+ inch stump and gave up after making poor headway. The 12 inch excavator bucket couldn't break the roots and I didn't want to dig a 10-12 foot dia hole to get stump out.
Spent two hours and stump is out of the hole. Hole ended up about 5-6 feet in dia and 5 feet deep. Broke 5-6 side roots of 4-6 inch dia and tap was massive.
More fun with quick attach backhoe tools.
/ Quick attach root ripper for M59 #2
I’ve considered getting a ripper for my KX40. But I’ve been in the fence about how much it would accomplish. How much time would you guess it saves vs the 12” bucket?
4570Man
I will compare the M59 to the KX40 which you running. Kubota indicates the M59 has 7600 Lbs of bucket curl force and the KX 40 has 9500 Lbs of force.
I spent 2 hours using the KX40 bucket and was unable to break roots at/ close to the stump. Gave up and came back at it with the root ripper. Two hours later had stump out of the ground and only added about 10-16 inches of extra space to all sides of the stump.
Had I continued with the 12" bucket, I figure I would have spent 5+ hours and had a hole 10 feet in dia. in order to break/ loosen roots further away from stump.
Bottom line. Root ripper saved more than 50% of the expected bucket time and the amount of excavated dirt was less than 1/3 of what would have come out using bucket. Ripper absolutely worth the money to me.
Bought ripper from USA Attachments. Frost Rippers for Excavators
/ Quick attach root ripper for M59 #4
I used to have a M59 and the 40 is definitely a good bit stronger. But 2 hours for one stump is pretty depressing when my cat would do it in 1 minute. I’m probably still going to buy a ripper for the 40 because it moves a lot more than the cat does. I’ve considered buying a ripper for the cat. I think I could split stumps in half to increase the burn ability if I had one.
4570Man,
I've dug out many stumps with the M59 and this is the worst one I have ever met. The very large and long tap root was hard to get at. Yes, larger machines with greater curling power would make short work of the stump. I don't have my KX80 yet. Missed a very reasonably priced low hour one in TX.
I work with with what I have have until I find the KX80 and D3 or equivalent dozer.
I can't really justify bothering a friend to bring his CAT 385 over to dig out a stump.
What sized CAT do you have? Always interested in equipment and owner's impressions.
/ Quick attach root ripper for M59 #6
4570Man,
I’ve got a Cat320L and a D5 dozer. I wouldn’t count on the D3 to do much with a stump. If you had a ripper on the back you might could bust up a stump but the dirt blade won’t do much.
4570Man,
Thanks. I see the 320 is 50K pound machine. Twice the KX 80 size. What caused you to buy the larger machine?
A D3 is large enough for my grading/ road work and don't intend to stump with it. Also same weight class as KX80 so hauling is simplified.
My reason for modifying the M59 hoe with coupler to use the KX buckets and tools is to be able to use same tools when KX80 arrives.
/ Quick attach root ripper for M59 #8
4570Man,
I needed something to dig 25 acres of hardwood stumps.
Maybe time to upgrade to 100K Lb machine or get a root ripper for existing. Either way, depending on how heavily populated those stumps are, you are going to be spending lots of time. My friend with 385 figures an acre an hour for stumping. With time somewhat depending on how wet ground is.
/ Quick attach root ripper for M59 #10
I’m probably going to order a stump ripper for the 320. You can pretty well move the 320 in one piece with a regular semi and you could probably do the same with a 330 but much bigger and things get considerably more difficult.
Yeah, 385 requires special transport permit and training, can only be moved on specific days and between certain hours.
/ Quick attach root ripper for M59 #12
Significant decrease in time and wear. Less ground disturbance requires less reclamation time, wear and possibly materials. Adding a new blade to an already impressive Swiss Army knife of tractors. One of the many advantages of KX QA mounting system on the M59. Swings well above its’ weight class.
  • Good Post
Reactions: M59
I was wondering when you would arrive to this conversation. Dig that stump out yet? ;)
/ Quick attach root ripper for M59 #14
Rent/hire. I had a 27 ton machine in recently and it pulls those stumps out in under a minute. Ended up being cheaper to hire a guy than to rent a machine, fuel and operate it myself. Freed me up to get other jobs done at the same time.
If you look at the cost per root your M59 gets pretty expensive if you are spending even 15 minutes on one root when I am taking out 30 roots in an hour on the bigger machine.
Rent/hire. I had a 27 ton machine in recently and it pulls those stumps out in under a minute. Ended up being being to hire a guy than to rent a machine, fuel and operate it myself. Freed me up to get other jobs done at the same time.
Mikester,
Agree with your point on cost per root with M59, but I don't do commercial and retired at fairly young age so seat time on M59 keeps me out of wife's hair. I am looking at adding KX 80 or equivalent and D3 dozer to the stable when quality at reasonable price presents itself. This particular stump was well rooted and I only had access to 2 sides so it took much longer than usual.
If I had work like 4570Man ( 25 acres of stump) then I would be using a much larger 50K Lb machine.
/ Quick attach root ripper for M59 #16
I’ve got a 20 ton machine on the job.
/ Quick attach root ripper for M59 #18
First stump with ripper. 14” Persimmon, 24” at base.
Used the front grapple to rake and wheels to compact hole spoils several times.
Stump moved to gully digester. 30 minutes total time.
Agree considerable less time and ground disturbance over a bucket. Good attachment for this little machine. Much use in its future.
Mega outrigger pads, outrigger steps, hand thumb control and KX quick attach made for an easy and fun job.
Had a 30” dead oak fall across and block the driveway Saturday. Tractor safely carries the chainsaw and log chains. $1500-2000 tree specialist job. Safely cut, moved and cleaned up 1.5 old man hours without tearing up the driveway. Not the machine I would use to clear 25 acres or build a subdivision but for farm/estate maintenance hard to beat.
Time to get another stump.
Used the front grapple to rake and wheels to compact hole spoils several times. View attachment 782708
Ahhh, fun times with new toy.
/ Quick attach root ripper for M59 #20
I wanted a root ripper for the same reasons.so I welded some old pieces together and stuck a Cat sticker on. It really does speed up stump removal, but I concerned about my windshield or I just have to remember to open them out of the way.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2020 KUBOTA RTV-X1140 UTV (A63276)
2020 KUBOTA...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
CATERPILLAR D3GXL CRAWLER DOZER (A65053)
CATERPILLAR D3GXL...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
