2655 HST Pump gone bad, no help from Mahindra
/ 2655 HST Pump gone bad, no help from Mahindra #1
Grim Reaper
Mahindra 2655 HST
My 2655 went into the shop in November leaking yellow fluid. The dealer determined that the HST pump was failing. The tractor is still under warranty so it shouldn't be a big deal. Mahindra didn’t have any pumps in stock but told the dealer they could ship one in late January! Today the dealer called me and said that the new ship date is late March! I don't have a backup and work is piling up. I called Mahindra customer service and spoke to Yolanda and she said that she can't help me. Thanks Yolanda! Anyone ever have a similar experience? Any suggestions? I'm in a bad place.
Thanks!
Grim Reaper
/ 2655 HST Pump gone bad, no help from Mahindra #2
The component manufacturer that makes those HST pumps has been behind for ~2 years now. Like, 13 months+ worth of backorders. I'm sure Yolanda was telling you the truth: there's nothing they can do because the parts just aren't available. It's not unique to Mahindra. People have been running into that issue with lots of tractor manufacturers the past couple of years.
/ 2655 HST Pump gone bad, no help from Mahindra #3
Any chance you can get the original pump rebuilt as a temporary measure? It may cost you a few bucks but it'll get you out of a bind
/ 2655 HST Pump gone bad, no help from Mahindra #4
Thanks!
Grim Reaper
I feel your pain GR! About 10 posts below yours you can see my similar Frustrating 4 month search to replace my same failed pump on my 2538. I wish you luck in your search.
Thank you for the insight. I thought Mahindra might have been able to do several things to keep a customer happy:
1) Since Mahindra is still building these tractors, pull a pump from the manufacturing line.
2) Contact the pump manufacturer to get me a valid date for when I can expect to receive the part.
3) Extend the end date of my warranty since I'm not logging hours on the tractor.
I appreciate the situation that they may be in, but I'm disappointed in how willing they are to let me twist in the wind without exercising a little creativity.
Great idea, but I wouldn't have any idea where to find someone to do that.
/ 2655 HST Pump gone bad, no help from Mahindra #7
1) While it sounds easy, it is not. Especially in the global manufacturing realm.
2) Same as 1.
3) This can and should be done.
Dealer also has some actions he could take such as either loaning you or renting at a discounted rate a used tractor off his lot to allow you to at least make some progress on your work.
/ 2655 HST Pump gone bad, no help from Mahindra #8
From what I 'understood', from my dealer, is that he used a buyer located in India to source the pump.....that was manufactured in Korea. 4 months later it arrived!
I admire the creative thinking that went into this solution. Given that it's a $10,000 part, I wonder how it would be covered by the warranty.
/ 2655 HST Pump gone bad, no help from Mahindra #10
2) Same as 1.
Pull a pump off a new tractor.
/ 2655 HST Pump gone bad, no help from Mahindra #11
You said " leaking yellow fluid" , What is that? Sounds like water in the oil to me.
Looked like anti-freeze but I believe it was transmission fluid
/ 2655 HST Pump gone bad, no help from Mahindra #13
When my HST pump went it leaked out the 'reddish' color hydro fluid and all functions ceased .....had to be winched onto a flatbed.
/ 2655 HST Pump gone bad, no help from Mahindra #14
10 grand! The pump I purchased was total, with shipping, & install about 2 grand.....
/ 2655 HST Pump gone bad, no help from Mahindra #15
Extending the warranty would be possible.
Also, maybe the dealer and or "Mahindra" would be a short term lease for a good price on maybe a used dealer tractor or a new one.
They certainly would not pull one out of a new tractor, especially seeing as how it requires splitting the tractor to remove the Pump/Motor unit.
Breaking the tractor in half and reassembling must cost $2000. You must've gotten the pump for free? Where do I get a deal like that?
/ 2655 HST Pump gone bad, no help from Mahindra #17
There is a Uniform Commerical Code adopted by practically every state. One of the rules concerning warranties is that if the warranty fails of its essential purpose, the buyer can be entitled to a refund. So if they can't or won't make repairs under the warranty on a timely basis rendering the tractor useless to you, you might discuss your rights with a litigation lawyer. There have been plenty of these cases involving both cars and tractors over the years.
/ 2655 HST Pump gone bad, no help from Mahindra #18
/ 2655 HST Pump gone bad, no help from Mahindra #19
That is your hydraulic pump for your remotes and 3 point on the larger section and your power steering on the small section.
Your main "hydro" pump would usually be construed to mean the portion of the hydrostatic drive system that drives the motor section.
/ 2655 HST Pump gone bad, no help from Mahindra #20
Thanks Lou, That looks more like that $$$!
KUBOTA SR2790 SKID STEER QUICK ATTACH ROCK RAKE (A60429)
KUBOTA SR2790 SKID...
2004 TAKEUCHI TL140 SKID STEER (A60429)
2004 TAKEUCHI...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2013 JOHN DEERE 772G MOTORGRADER (A60429)
2013 JOHN DEERE...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
Scag STT52V-27CH 52in Zero Turn Mower (A59228)
Scag STT52V-27CH...
