CT225 head gasket?
/ CT225 head gasket?
Assuming the grit in the head is the common ingredient found in many types of head gasket fix, I don’t need to worry about it remelting below 800c
“Liquid glass” (sodium silicate) is added to the system through the radiator, and allowed to circulate. Sodium silicate is suspended in the coolant until it reaches the cylinder head. At 100–105 °C sodium silicate loses water molecules to form a glass seal with a re-melt temperature above 810 °C.
The ck25 kioti is the closest equivalent to the ct225. The trick is both the Bobcat and the kioti have mid model changes that happened on different schedules. The engine in my rig is a daedong td1300lxe. The ck25 head bolts and gasket was a match. The kioti dealer had most of what I needed I stock, whereas the bobcat folks were telling it takes months for them to receive in stock parts from the big warehouses and no expectations for made to order stuff. For instance, the instrument cluster shroud that showed in stock, that was ordered from a bobcat dealer, took 10 weeks to be delivered to them. I’ll work twice as hard to find a kioti cross referenced part before I call bobcat again. The coolant hose and intake gasket that the kioti didn’t stock was a 5 day lead time and they offered to ship it to me because I told them they are an hour + drive from my house.
If that is a photo from your expansion tank, if mine I would pull the radiator and take it to a radiator shop and have them to clean it. That is a lot of gunk floating around in a radiator.
I took your advise and had the radiator checked by a local shop. Thank you, I would have never thought to have it checked without you're suggestion! The shop tried to "boil it out", next they pulled the tanks off an tried to clean the passages my mechanical means both attempts to save the radiator was a fail. They said it was like "cement" and plugged up beyond repair. One week and $750 later they had the unit re-cored. I was shocked but it's still better than a new one at $1314.24 and god knows how long till Bobcat bothers to ship it out.
/ CT225 head gasket? #24
Clearly prev. owner did not take good care of this CT225, sorry you started tractor ownership with these experiences. Like me and snowmobiles.
/ CT225 head gasket? #25
Wow! I feel bad for you. Can you identify a failure in the head gasket? The reason I ask, is the real chance of a crack in the head or block. The head can be magnaflux checked for cracks, but the block can't (unless it's all apart...). The lower section of the block is probably caked up pretty good with that gunk, as well. It'd probably be a good idea to pop out the freeze plugs and get in there with some strong brushes and/or scrapper tools.
An add'l (big) pain for you though...
I am no expert, I was hoping to see something obvious like a blowout. What I identified to be the problem was a an area on the rear most cylinder. The cylinder itself is discolored and the piston has more carbo. In my unprofessional opinion, the tell was the head gasket. on the front two cylinders the metal part of the gasket that mates with the surface around the cylinder was clean and shiny, the rear most was covered in soot/carbon. I think this is consistent with the symptom as well. The oil and the coolant never mixed and the coolant never seemed to be burning off, or not enough to give me the tell tail sign of white steamy "smoke" from the exhaust. When I would pressure test the coolant system, it would hold 15PSI all day but when I would run the tractor, it would start to bubble up into the overflow tank. At one point the overflow tank was clogged and the pressure has no where to go so It blew the top hose.
On that first drive, it over heated and the top hose started to expand, when I hit it with an IR temp gun, it was showing well 150-160°F at the radiator. Now I know the rad was plugged up from this head gasket BS!
Cleaning the head and block, at this point with the cost involved in recoring the radiator, I think I will drop the head off a at a machine shop and have it magnafluxed and skimmed if it's warped. When I started pulling the head I was looking at at $150 for head bolts and a head gasket. I work at a machine shop so I could easily have one of the machinist block the head up on a surface plate and indicate it for me. Now that several other gaskets, a coolant hose and a $715 radiator repair was added to the mix might as well have the head checked I am well over $1000 into it at this point. I am still rolling the dice on the block, but I suspect that is a relatively low risk.
I picked up a set of bottle brushes from the jungle website like these and plan to spend a very boring evening cleaning all the coolant passages out. What has me on edge about cleaning it up is the sodium silicate the is going to be flung in every direction, if enough of it gets in the block an into the bearings, the motor will be cooked. My plan is to use tape and plugs to block all the passages to the oiled areas of the block as best I can. Once I get as much of this crud out of the engine as possible, I will run several gallons of drain oil through the block, hoping it will grab any sodium silicate that made it past my tape and plugs. Then I will top it off with a fresh filter and Rotella. I might even dump the oil and coolant after 2-3 heat cycles.
My radiator shop told me that whatever was in there was like cement and the only option was to recore. He said that he tried to boil and ultrasonic it, once he did that it started to spring leaks. I asked him for the core back because I am curious, anyone ever see a core cake up like this? I can tell you it didn't look like that when I dropped it off. There was some buildup but nothing like this!
Here are the crosses to Kioti numbers for my "A59B11001 and above" tractor with a Daedong TD1300lxe 3 cyl
Head gasket E5500-03315
Valve cover gasket E6510-14532
Head bolts E5500-03452
There are more but I don't have them in front of me at the moment
/ CT225 head gasket? #29
Sorry to hear about all of your troubles, after you get everything cleaned up and replaced you are going to have a good tractor there.
The block and the head were more caked up than I figured. The block took a lot of probing with various bottle brushes and gallons of water to flush it out.
As I was finding a point of acceptance with the block, I moved my attention to the head.
The head showed more wear than the hour meter suggested. The valve seats were hammered and the guides needed tightened up. Oh and they took a few passes to resurface the mating surface.
I was optimistic that the pressure test and hot tanking cleaned the cake out of the head. Not so much, I ended up pulling the freeze plugs to do my best at getting the bs out.
/ CT225 head gasket? #31
View attachment 782521View attachment 782522View attachment 782523View attachment 782524View attachment 782525
You are doing an exceptional job on cleaning up one great big mess someone else made. (y)(y)
Just a small update. I started putting things back together and hit another roadblock. According to the Bobcat service manual that I bought, I need to put the engine on TDC. TDC is indicated two ways, by the timing gear set indicators under the waterpump under the timing cover or by the timing window on the flywheel housing. After searching for this window with no luck I hit the internet. Eventually I ended up back on the forum in a kioti thread that lead me to believe the window is covered by the loader bracket attached to the frame.
I got stumped again when I thought I took all the bolts out of the bracket and it was not budging. This morning I realized there is a bolt INSIDE of the mounting bracket that I failed to remove!(Number 5)
It never seems to end with this tractor! I am sure my inexperience is a factor, but geez!
:rolleyes:
Thought I would continue to document headgasket job
The timing markings on flywheel were not visible because of surface rust. My solution was to take a piece of red scotch brite pad and wrap it over a 3/4" socket extension, it fit perfectly through the "window". I rotated the engine by hand from the crank pulley and pushed in on the extension/pad to clean off the rust and reveal the markings. From there, adjusting the valve lash was straight forward. I put it all together and let it sit like that for a couple of weeks till last night. With the fuel lines cracked open at the fuel distributor, it primed and started quickly. I left if idle for 10 min or so then bumped it up to 2000 rpm and let it run till it warmed up. It started to just barely creep past the second dot so I shut it down because it was after 10pm and I wasn't sure if I had a air in the coolant. I popped the radiator cap off an realized the system never pressurized fully but it was warm and had not gone down. I fired it up again and ran it for a few minutes again, this time from shutting it down the temp was half way between the second dot and the red. I let it idle till the temp came back down and shut if off. It was too late to mess with it for long and my garage is heated so leaving the doors open too long is not ideal. With the cost of electric these days, you need to be mindful about stuff like that.
With the loader and the loader mount off, I discovered there is a leak that will be way easier to address now, so that's next on my list. I just need to clean all the caked up dirt and oil off everything so I can see where its coming from.
2 of the hydraulic couplers for the loader seem to leak when disconnected. if there an easy trick to fix this or should I just not worry about it since they don't leak when terminated?
/ CT225 head gasket? #35
If you don't remove the loader very much and use the tractor without it I could see no need to worry much about the couplers
/ CT225 head gasket? #36
That looks like "incompatable" antifreeze mixed together. I have seen this happen to a jeep 4.0L engine..... clogged almost the entire block!
Hope you can get enough of it out.
In typical fashion, I hit another set back. I pulled the tractor out of the garage Tuesday night last week. Tonight, I hoped any air worked it’s way out of the system. When I opened the radiator cap, I was happy to see it needed topped off. It was only when I heard it running out of the back of the head did my heart sink. The rear core plug in the head was pushed completely out and wedged between the firewall and head. We did get a cold snap last night for about 6 hours and I foolishly left strait water in the engine. I’m hoping the cold snap didn’t freeze and crack anything. I was suspect about this plug when I installed it. It just went in too easy. I put a thin coat of sealant on the plug so I figured it would be okay.
Now I need to see if taking the firewall and gas tank out is more difficult than pulling the head again I don’t want to buy another round of bolts and gaskets if I don’t have to or if the block is cracked anyway.
When does this roller coaster end!
/ CT225 head gasket? #39
I've always used a bit of gasket cement on freeze plugs, but I've heard of many that use epoxy or JB Weld. A straight install (using the correct tool/socket without deforming or banging it sideways any) and a good, clean surface is very important. They should be a very tight fit (like - almost too "big"). Maybe the one you used wasn't correct? But it's good that it popped out, if the water was frozen...
Anyway, this sucks, for sure. Hopefully you can get in there to fit a new one, without other damage done.
I was able to find the head gasket ($65) and the head bolts ($130) at a Koti dealer about an hour from my house. I was also found that a bobcat dealer near the Kioti dealer had the core plug in stick for $4.
I am on the fence about reusing the head botls and gasket. They have about 10 minutes of run time on them and I very well could get it all back together and discover the block is cracked. On the other hand, I could snap off an already yielded bolt in the head and curse myself about being cheap when I am grabbing the drill and easy-outs.....
I question if the head actually froze, it seems odd that it went from frozen solid enough that it pushed the core plug out to completely thawed a few hours later. I know when I installed the plug, it made me uneasy how little the resistance was. I suppose the radiator would be the first thing to freeze and crack, I will know once I get it back together. I hope not, I had over 700 in the radiator recore alone! It some strange way, I would rather find out this last problem was my fault!
