Bought a new trailer
/ Bought a new trailer #1
jyoutz
Super Star Member
Edgewood, New Mexico
Kubota MX6000
Found a good deal on a new 7x20’ trailer with a steel deck, dual 5.2K axles for a weighted load of 10.4K. $5900 including a spare tire, rear jacks, and slide out ramps. It will work for my needs.
/ Bought a new trailer #4
Awesome find. About 1/2 of what a new one would cost you here. Been sorta looking myself. 20 ft fits most full size tractors with loader and gannon
/ Bought a new trailer #6
/ Bought a new trailer #7
Very nice trailer. It'll serve you well!!!
/ Bought a new trailer #12
I like the jack supports on the rear. Must have hide-away ramps. No need for those 200lb ramps you have to flip up. Good score! (y)
I would put brakes on the other axle for sure
That’s doable. But I was told that most people run single axle brakes. I’m going to see how it handles with single axle brakes before doing anything. The brake controller is turned down pretty low when I use my gooseneck stock trailer because the single axle brakes works pretty good.
Yes, hide away ramps that have a nice wide attachment pipe for variable width machines.
/ Bought a new trailer #16
Hide away ramps free up some deck length but they’re harder on your back than flip ramps ever thought about being. Flip ramps can have spring assist and they aren’t bad at all to flip. There’s no avoiding lifting the whole weight of a hide away. Even if the flip ramp didn’t have springs you’re only lifting 1/2 the weight.
/ Bought a new trailer #17
Always thought I would not like flip up ramps. But I have them on my GN trailer and they are easy to use and extra wide.
/ Bought a new trailer #18
I had a GN a few years ago with mega ramps. Aside from being wide they were the best loading angle for a deckover that I’ve had. My current deckover trailer just has regular ramps but they’re spring loaded and aren’t that heavy to fold up. My dump trailer has stow away ramps. A 5ft ramp heavy enough to load a skid steer ain’t light. They suck to put in their holder. My tilt trailer is my favorite option for loading.
/ Bought a new trailer #19
I agree, they are not bad at all.
/ Bought a new trailer #20
First thing I notice about single axle brakes is tire wear. If you are carrying a load large enough that trailer brakes are needed, it's a lot of scuff on those two tires. Second thing is in a panic stop.
Depending on axle/brake size, $600 should add brakes to the second axle.
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
Curtis Dyna Fog 100 Gal Fogger (A64912)
Curtis Dyna Fog...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2023 Monroe-Tufline DS1144T 12ft. Hydraulic Box Scraper Tractor Attachment (A66734)
2023...
