Heavy Hitch
/ Heavy Hitch #1
Duds13
Charlton, NY
Kioti CK2610, Kubota BX 2200
/ Heavy Hitch #3
Has anyone purchased from Heavy Hitch? If so, are you happy with the quality? Also, is the one in the link what I need for my Kioti CK2610? Thanks for the help!
That will fit your tractor. If you're spending a premium on this brand why not pay $40 more and get the option for weights?
If you're not using it to pull stumps I'd recommend a cheaper version, I have a similar one that's fine for moving my trailer and plan to eventually use it as a base for a concrete ballast box.
/ Heavy Hitch
Good idea on paying a little extra for the option for weights.
I do like the price of the one you recommended, I'm just trying to stay away from China as much as I can!
/ Heavy Hitch #5
Fair enough, seems like a well made product. I'd suggest you also ask about the difference between standard and super duty, couldn't find anything on the website explaining it.
/ Heavy Hitch
I believe the super duty has a safety chain hook
/ Heavy Hitch #7
I’ve got a category 2 HH I mainly bought for suitcase weights to use as counterweight and just to store the weights conveniently. Excellent quality. I made the T to slide in the receiver so it would free stand on the HD dolly I also built. Works out real nice 👍
/ Heavy Hitch #9
If you are going to use that for moving trailers around I'd recommend a safety chain so that the 3 point can't be pushed up higher then it should go.
You can see my limiting chain going down to a clevis in the drawbar to stop unintended over lifting.
/ Heavy Hitch #10
I have always towed from the drawbar, but getting older I might not of done a limiter tied to the drawbar with this setup. Of course I would now!
Thank you for posting this.
/ Heavy Hitch #11
that limiter chain is a good idea, as long as you don't forget and actuate the 3pt lift. I bet you some tractors could bend the draw bar or atleast rip the hook off.
/ Heavy Hitch #12
I have my chain set so the max lift is just starting to pull on the drawbar.
/ Heavy Hitch
Definitely going to do this!
/ Heavy Hitch #14
I made one using my old 3PH drawbar. The hitch isn't rocket science, if the vendor product is cheaper/faster than you can make it then buy it.
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
GATOR UTV (A63276)
GATOR UTV (A63276)
Front Tank Bracket (A64126)
Front Tank Bracket...
