Heavy Hitch
/ Heavy Hitch #1
Duds13
Charlton, NY
Kioti CK2610, Kubota BX 2200
/ Heavy Hitch #3
Has anyone purchased from Heavy Hitch? If so, are you happy with the quality? Also, is the one in the link what I need for my Kioti CK2610? Thanks for the help!
That will fit your tractor. If you're spending a premium on this brand why not pay $40 more and get the option for weights?
If you're not using it to pull stumps I'd recommend a cheaper version, I have a similar one that's fine for moving my trailer and plan to eventually use it as a base for a concrete ballast box.
/ Heavy Hitch
Good idea on paying a little extra for the option for weights.
I do like the price of the one you recommended, I'm just trying to stay away from China as much as I can!
/ Heavy Hitch #5
Fair enough, seems like a well made product. I'd suggest you also ask about the difference between standard and super duty, couldn't find anything on the website explaining it.
/ Heavy Hitch
I believe the super duty has a safety chain hook
/ Heavy Hitch #7
I’ve got a category 2 HH I mainly bought for suitcase weights to use as counterweight and just to store the weights conveniently. Excellent quality. I made the T to slide in the receiver so it would free stand on the HD dolly I also built. Works out real nice 👍
/ Heavy Hitch #9
If you are going to use that for moving trailers around I'd recommend a safety chain so that the 3 point can't be pushed up higher then it should go.
You can see my limiting chain going down to a clevis in the drawbar to stop unintended over lifting.
/ Heavy Hitch #10
I have always towed from the drawbar, but getting older I might not of done a limiter tied to the drawbar with this setup. Of course I would now!
Thank you for posting this.
/ Heavy Hitch #11
that limiter chain is a good idea, as long as you don't forget and actuate the 3pt lift. I bet you some tractors could bend the draw bar or atleast rip the hook off.
/ Heavy Hitch #12
I have my chain set so the max lift is just starting to pull on the drawbar.
/ Heavy Hitch
Definitely going to do this!
/ Heavy Hitch #14
I made one using my old 3PH drawbar. The hitch isn't rocket science, if the vendor product is cheaper/faster than you can make it then buy it.
