Radiator hose "snapped"
/ Radiator hose "snapped" #61
A good radiator shop should be able to fabricate a complete radiator for WAY less then 1K. They can order all the components and put the top and bottom tanks on the core, and it would be all metal.
/ Radiator hose "snapped" #62
I see they don't show a price. Is this one of those "if you have to ask..." situations?
I think Omnipitent checked - they want $800 - might as well buy new. I would be looking for a "close" aftermarket replacement if a repair is not possible.
/ Radiator hose "snapped" #63
/ Radiator hose "snapped" #64
I had a problem with my friends tractor radiator hose connection crack, he checked into a radiator for it and it was over 600.00 dollars,so i did some checking a found a source that had the same radiator for 175.00 so do some checking a lot time radiators are interchangeable i wish you luck
/ Radiator hose "snapped" #65
My cousin had this happen too. The final solution is to go to a great radiator shop and have him find a brass radiator that fits, it’s not rocket science, the radiators are made in standard sizes, just buy a replacement. Much cheaper in the long run
/ Radiator hose "snapped" #66
The lower tank is structural fiber and not repairable
I was wondering what type plastic it is too, but I've repaired some plastic stuff in the past with limited success. anything that gets cycled between hot and cold with plastic and metal doesn't seem like a good choice of materials to use. I can't imagine any repair to that plastic tank that I would put trust in. Honstly, I hate it when I see plastic parts used on engines. Some parts are fine depending on thier purpose and type of polymer it is. When I encounter a failure of a part on my stuff, I look to replacing it with something better than the original, which usually involves exploring salvage yards or fabricating a new part or modifying the original so it won't ever fail again. The downside of what I do is it takes more time to complete the fix vs. replacing the part with another original design part. I guess I'm stubborn and cheap, but I don't end up getting angry over another failure on the same component. Tractor parts are ridiculously priced. I suppose if you need it fixed sooner than later you could try scouring the interweb for used replacement parts that will just bolt right in and get you moving again for a little less moolah than $1000 bucks. I wish you luck Citydude. Please let us know how you make out.
/ Radiator hose "snapped" #67
That's the best solution if you can get it. It's worth the effort.
  • Good Post
Reactions: bgr
/ Radiator hose "snapped" #68
Just get a new rad. Its a lot cheaper than an engine.
Better yet, take it to a rad shop, and get a steel rad made. It will cost more, but the tanks are repairable in the future.
/ Radiator hose "snapped" #69
Good day and happy new year.... Less sniffing of glue and let's get to fixing problem...See if somebody has a "suitable substitute" that will work if you do not want to go OEM...why did this fail in the first place?? damaged from debris? and or bad mounts??...Fix it and fix it once..Cheaper to fix it right than to BLOW it UP!
/ Radiator hose "snapped" #70
Well as the description says, was out clearing some brush and started smelling radiator fluid, checked and found this:
Closer inspection revealed this:
As you can see, the plastic part of the lower radiator, clean snapped off and is still in the hose. My guess is the only option is replace the radiator, but figure I'd check here first before buying something.
One last photo showing the broken opening on the radiator:
For the record, this is a Bobcat CT335....I don't think that matters but figured I'd throw it out there.
To all you making fun of a JB Weld radiator repair, all 3 such emergency radiator repairs I did over the years never failed. Presently driving a Toyota with a JB repaired radiator done 15 years ago & never failed. (yet) In a pinch I would do a JB fix and (maybe) eventually replace the rad if it made me nervous. I'd clean it up really well and lay in some reinforcing material to widen the holding area. Just do it.
/ Radiator hose "snapped" #71
Not at all impressed with these plastic radiator header tanks. They seem to last about 15 years or so and then come apart.
I played with Audi 5000s for a number of years, those radiators usually broke after 10 to 12 years. There was a large internet Audi user group, and a broken spigot on the top tank was not an unusual problem. There were some very talented and resourceful people on that group, but nobody was ever able to find a solution to fixing these things so they stayed fixed. 99% of these cars are gone now, I have not been on the Audi newsgroups for at least a decade so I don't know if anyone has found a solution for later models (which still use these plastic radiators).
Wife had a Mazda, the radiator got broken by some moron at one of the big franchise "brakes for $99.95!" joints, they convinced her to get a radiator flush and broke the top tank. Of course, "it was like that when it got here". Subsequently, she agreed that in the future *I* was going to be her mechanic. New radiator installed, it was right around a hundred dollars plus antifreeze and some hand cleaner.
2001 Honda Accord, came to me out of an estate in 2003, it has been my daily driver and "beater" since. Radiator top tank split, new radiator was only $65 from eBay, I decided it wasn't worth the time to fool around with trying to fix the old one, problem solved for another dozen years (I hope).
I think I'd look at Summit or a hot-rod shop and let them find an all-metal radiator that will fit. It has to cost less than $1,000, and then you'll never have to worry about it again. Even if it does leak eventually, it can be fixed. These plastic radiators are best regarded as a long-term consumable, they do NOT last indefinitely.
Best regards, and have a happy and safe new year!
Mike/Florida
/ Radiator hose "snapped" #72
You'll NEVER clean it good enough for any kind of "glue", including JB. A radiator shop may be able to "weld" it, but I doubt it. A new one is in order, I believe.
My 3 different JB radiator repairs went from being emergency fixes to permanent fixes. After years of not failing. I just decided there's no use fixing anything that aint broke. I also patched a leaky gas tank with JB and that also became permanent after lasting for years. Go to town and buy a radiator or a gas tank, or send away for them if you have the money and the time. When you need a fix right now, JB can be a lifesaver. I don't leave home without it in my tool box.
/ Radiator hose "snapped" #73
I am cheap. $1000 for a plastic radiator seems out of line to me. If I could not fix it, I would look at finding a car/truck radiator that was close to the same size.
A few years ago, I bought a new radiator for a Ram truck and it cost less than $100. They might be $150 now.
A few years ago, I bought a new radiator for a Ram truck and it cost less than $100. They might be $150 now.o
Me too, as long as it aint a show tractor. Make it stronger any time you can.
/ Radiator hose "snapped" #74
looks like you are up for a new radiator, or at least a new bottom header, if you can get one. I would say a branch has got in there and snapped it off, you may want to provide some protection for the new one?
/ Radiator hose "snapped" #75
/ Radiator hose "snapped" #77
My first question before fixing it is, What caused this. Usually a broken engine mount or?. Something shifted causing it to break off like that. I have repair them before with super glue and baking soda mixed. Because there is no pressure at that point other than heat expansion. Something hit it or it flexed to break like that. My 2 cents worth. If you glue it I would also use this to staple it.
Motorguard (JLMMS2500) Magna Stitcher Plastic Repair System​
/ Radiator hose "snapped" #78
I'm not a tractor mechanic but I owned and ran several mechanic shops for 40 years. Every new car on the road has a radiator with plastic tanks. I have tried every possible fix over the years but never had any fix that lasted long except replacing the radiator. Try a company called 1800 radiator. They have been able to match several radiators for different types of equipment for me over the years and have saved me a crazy amount of money on some of them. I fixed a forklift for a buddy recently. The forklift company wanted $900 for the radiator. They found me an exact match for less than $200. They will ship.
/ Radiator hose "snapped" #79
Interesting to see the number of first posters on this thread 10 - welcome to TBN! Could this be search related to radiators?
Hope you get this sorted soon Omnipotent!
/ Radiator hose "snapped" #80
What was the outcome - replaced/repaired or still looking?
Andersen Fifth Wheel Hitch (A61166)
Andersen Fifth...
UNUSED WOLVERINE M-SB42 42" MINI ROCK BKT (A62131)
UNUSED WOLVERINE...
Hustler Super 104 104in. Zero Turn Commercial Mower (A61567)
Hustler Super 104...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2019 John Deere X380 Lawn Mower (A63116)
2019 John Deere...
2023 Ford F-350 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A61165)
2023 Ford F-350...
