Wood chippers
/ Wood chippers #21
I use an old Bear Cat SC5540 with my JD 3520 that has 30hp at the PTO.
Some other advice on chippers:
Keep the blades sharp, know how to remove the blades, know how to sharpen the blades, invest in a replacement set of blades.
Ear and eye protection are a must have.
Enjoy (and be VERY careful with) whatever you end up with! :)
/ Wood chippers #22
A short story. I have a Wallenstein BX62S. It's considered a manual chipper. IE - no hydraulic in-feed. It's rated to handle up to 6" round stuff. It's designed for 35 to 100 engine hp. So with my M6040 being 62 engine hp - I'm nowhere near the top of the range.
I thin my pine stands every other year. I identify, fell, drag to pile, chip approximately 800 to 1200 small Ponderosa pines during this month long project.
For me - this means pines from 1" to 6" on the butt. With my setup this chipper chips faster than I'm able to retrieve the pines off the pile. I have no need for a larger chipper nor more tractor hp.
Bottom line - I think you will find that the chipper you are considering will be more than adequate for your projects.
One of the main reasons I didn't go for a larger chipper. A green Ponderosa pine that is 6" on the butt is all I want to drag around to the pile. It is a bulky and long thing. Plus - when I'm finished felling all the small pines in one stand - it looks like a giants game of Pick-Up-Sticks. Trees are lying everywhere and in all directions. Crawling over this mess and dragging a 6" pine is neither easy nor fun.
/ Wood chippers #23
If you can burn a match is alot cheaper than a chipper....if you want chips call a tree company and offer a free dump site.
I have cleared acres and used many hundreds of yards of chips with no chipper.
I agree with the above. If someone gave me a chipper, I'd probably use it for a bit and then sell it to someone actually needed it. My preference is to burn. If it's big enough to burn in a wood stove, then I give it to someone who can use it. Otherwise, it's going in the burn pile and I'm done with it. The only thing it'll cost me after that is a few hours sitting around the fire to make sure it doesn't get out of hand. No fuel costs. No hours on the tractor. No wear and tear on my body. No danger of getting sucked inside the spinning chopper vortex of doom.
I know this doesn't contribute to your original question, but I figured I'd offer a perspective that may save you some time and energy in the future.
/ Wood chippers #24
I chip because wildfire is so prevalent from April thru October. During this time we are dry as a popcorn fart. It's just not worth the chance. And then there is right now - foot of snow on the ground and 14F outside. I really don't like monitoring a burn in this cold wx. Right now - in the house with a hot cup of coffee and JD.
Different strokes for different folks.............
/ Wood chippers #25
For sure. I mainly chip limbs downed by nature or brush from downed trees. Being able to drive around the property and chip where the stuff lies, blowing the chips into the woods is great. No hauling stuff to a burn pile and then spending hours tending the fire.
/ Wood chippers #26
My neighbor had a chipper that didn’t have hydraulic feed. It would chip small diameter, firewood ready logs very well. It did not work well on stuff he wanted to chip (brush, limbs with leaves, etc.).
He sold it and we went in on a Woodmaxx WM8H 50/50. Worked great on stuff we wanted to get rid off, even pine with all the needles. I ran it with a 29 hp Kubota B, his tractor was a mid sized Kubota L.
I never used his non-hydraulic feed chipper. He told me back when he had it that I could use it any time, but it wouldn’t work for what I wanted to chip.
/ Wood chippers #27
Get a face shield too!
https://en.stihl.ca/STIHL-Products/Accessories/Head-Eye-and-Ear-protection/274807-74782/‘A’-Helmet-System-(Type-1-2-Class-E).aspx
/ Wood chippers #28
I run a Woodmaxx WM8H with my L3301. We are at an elevation above 4,000 ft. 4“ is about the max I chip, because everything else gets cut and split for the wood stove. Power has not been an issue whatsoever; and 2 power feed rollers is a great feature; not to mention the ability to instantly reverse the feed if the material gets stuck.
Jack
/ Wood chippers #29
I had a Woods brand chipper which could do 5" logs for my Kubota B2150 which was 24 hp. It worked fine. I didn't read all the threads but what I would say the shredder was a bit scary to use. For me the chipper worked well (I used it to make horse bedding). Not super fast but acceptable. Very noisy. The main advantages of a PTO chipper/shredder is you don't have another engine to maintain and they are somewhat compact compared to a totally separate trailer driven type unit. But they are very heavy and a pain to align to the 3 pt hitch. I suppose a trailer type would be easier to use off your propoerty as you would not need to take your tractor.
/ Wood chippers #30
I like having the equipment also, but for the amount I use it, I don't want the cost/maintenance. Last time a cleared an area, I rented a much larger than I needed for not a whole lot of money. Cost depends on the size you need and time you want it.
/ Wood chippers #31
I’ve got a woodland mills 6”. I chip mostly mesquite with a new Holland 33hp. Most of the stuff I do is 4” or less and it does great. It’s got a smaller flywheel than the rest but the only time it let me down was as my clutch was going out in the tractor, I just had to chip smaller brush. The customer support is outstanding. As with any PTO implement, especially a wood chipper make sure you your clutch is good
/ Wood chippers #32
For $3300 you can get a Woodmaxx WM8H. It's an 8" square throat chipper that's got hydraulic feed. The larger throat means less trimming of branches than a 4" or even a 4x10 like the Titan. Hydraulic feed is much safer than self-feeding. I have one of each kind of chipper and the power feed is so much better.
Woodmaxx also has other chippers. There's also Woodland Mills. Their design is different from Woodmaxx but like the Woodmaxx they are designed in north america and made in China.
While my Titan pallet forks have been fine, from what I read Titan has little support or parts for their implements. (there's not much that can go wrong with pallet forks). If you need anything that's not a generic part like belt or bearing you will have to find someone else who imports the same Chinese machine and does have parts. I do see that they have replacement blades.
My Branson puts out 32hp at the PTO. There have been times I could use more power for bigger stuff but now that I have a decent wood stove I am not chipping large material as much. Anything over 4-5" and I set the feed as slow as it will go.
Some units like the 8H gear the rotor up to about 2x the pto input speed so the flywheel has twice the inertia as one of the same weight and diameter that is direct drive.
I have the WM8H, bought it slighly used and it is a wonder to have. The blades can be flipped(they will sharpen them for 15$ plus shipping). My wife loves this thing. She puts the shavings in her garden. I've run it on a IH464 and a NH WM50, no issues.
/ Wood chippers #33
We have a Woodmaxx WM8H. It's wonderful. Sits on our JD3039r a good share of the year. We have 160 acres to maintain. what can't be burned or buried is chipped. After 4 years it's been terrific. When I find some pictures I'll post. Good luck.
/ Wood chippers #34
Wow a true do it yourselfer.
/ Wood chippers #35
I sure don't know how you've been able to burn. Atascosa County has had a burn ban for the last couple of years due to the drought. We're a good 20" behind on rain just this year. When you only get ~28" a year, that's a drought. And Atascosa County generally follows your Bexar County on burning. The only way we could burn is in a burn barrel. That's how I dispose of paper waste. If you know anything about Sothern Mesquite, you should know you have to keep them trimmed if you want to be able to get under them. I've collected four HUGE brush piles waiting to be burned. They're so big now I'd risk burning up the whole county. I know my neighbors wouldn't appreciate burning their property. And as mentioned, I certainly can find more useful things to do with my time than tending a fire. Having a chipper will allow me to keep up with the growth and get up my driveway. ;)
/ Wood chippers #36
I looked at 3-point hand skid steer mount chippers. I ended up buying a tow behind model off of Auction Time. I paid about $5000 for a very lightly used Morbark 2060D. It's rated for 6" and has a CAT diesel engine.
Now, as to the why I went this route:
1) I'm not putting any hours or wear on much more expensive equipment.
2) I can set the chipper up in a good spot and use the tractor to move debris to the chipper, instead of having it tied up running the chipper.
/ Wood chippers #37
Hi guys, looking for a little help from this great well of knowledge. I'm looking to buy a wood chipper, I like the idea of 3 point attachment chipper. Titan has one for $2,300 that goes to 4". It's the WCBX42S.The manual says 35 PTO hp for maximum capacity and capability. My lx3310 is around 27 PTO hp. So I'm wondering if I'll lose efficiency. I'd have thought 540 is 540. My 5' brush hog runs around 2100 or so rpm at 540.
Also, does anyone think this is a good piece of equipment?
I also have the option of their tow behind, 5" chipper for $1,900 which looks like a good deal but it's one more motor to mess with.
Grateful for any input or recommendations, thank you all!
After much research, I bought a Woodmaxx Mx8800 last year. I run it on my Kubota B2900 and JD 4066R. My B2900 only has 21hp at the PTO but this chipper is amazing. It will handle up 5-6” trees with branches attached without bogging. In fact it works so well with my little tractor, I don’t use my JD with it may all. The wide hydro infeed, built quality, made in USA, and poet of this unit is amazing. We have an organic tree farm with over 70 acres of wooded land, so this thing gets used a lot. It’s pricey, but worth every penny in my opinion.
/ Wood chippers #38
Woodmaxx hydraulic feed chippers are worth what ever you gotta pay for them. I can't imagine anyone being disappointed. When I was on the fence whether or not to buy one, I phoned a guy in my region who I saw on their customer comment page. He sold me on it and I'm glad he did.
Agree. See my reply to the original thread.
/ Wood chippers #39
We have a 90 acre organic tree/ fruit farm with many animals and about 70 acres of woodland. For years I removed dead, fallen, unwanted branches/trees And burnt whatever couldn’t be used for firewood. Wife talked me into a chipper. Will never go back. Makes cleanup faster, creates wonderful mulch for garden, orchards, and trails, and I know exactly what type of wood is in the pile. If you have a local tree company dump their mulch for you, be careful of harmful species that can be toxic to your plants.
/ Wood chippers #40
We have an older Wallenstein BX 42, that looks just like the Titan one you are considering. We use it on a JD 1050 which is about 32HP, and it's been a workhorse. I don't see the BX42 on their website any more, but I suspect they build for Titan, or sold the design. Good luck with it.
2250' of 5" Tile (A66408)
2250' of 5" Tile...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
3 Point Hitch Root Rake (A65579)
3 Point Hitch Root...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A64556)
2019 Chevrolet...
2011 Ford F-350 Tow Truck, VIN # 1FDRF3GT1BEB95969 (A65563)
2011 Ford F-350...
