Puma-54 Snowblower chain stretching
/ Puma-54 Snowblower chain stretching #1
tractor-rookie
TYM 254
Hi. As it says in the title, I have a TYM 254 tractor running a Puma-254 chain. I believe that the chain has been stretched. That's how I found this web site, searching for info on how to route the chain tensioner. I adjusted the tension sprocket down almost as far as it would go, and got the tension required to keep the chain running smoothly, at least for the time being. Now I'm concerned that the chain may be over stretched and at risk for failure, which I would not want to see happen next time I go to use it. Should I be purchasing a new chain for the blower? I was also thinking of purchasing a chain breaker, and learning how to use one, so that if anything goes wrong I will be somewhat prepared to fix it when the time comes. I'm also wondering if I could just use a chain breaker to remove 1 or 2 links from the existing chain, rather than changing the whole thing? Thanks. As a basic NEWB I would love to get some advice about the right thing to do with the blower chain. Cheers
/ Puma-54 Snowblower chain stretching #2
Chain wears out, faster if not oiled.
Old chain will have a master link with a clip. You can shorten the chain a couple links and put it back on, but keep in mind a well worn chain will eventually ruin the sprockets.
Depending on how long the chain is, two links short might be too much, you might have to use a "half link" to put it back together.
You can buy new chain and cut it to length and be new again. It's likely #50 chain, should be stamped on it. Usually can be bought cheap at parts supply place.
I don't use chain breaker, put in vise, and use angle grinder to take head off of the rivet and pin punch to push it out.
I keep various chain, master links and half links on hand. Broken chain not fun in middle of storm or job and everything closed.
/ Puma-54 Snowblower chain stretching #3
/ Puma-54 Snowblower chain stretching #4
NOOOOOO; no chain mending of old chain with new chain links period!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RULE number 1.
Roller chain for snow blowers is to be tight on the top run of chain to maintain tension on the chain flight
as it rotates in only one direction. By doing this the lower flight of chain will stay tight on the sprocket teeth.
Rule number 2.
Top run sprocket roller chain tensioners are either the torsion type with the rubber flexing tensioning spring arm
or the adjustable type with the worm adjuster. With the worm thread adjuster very little tension is needed to keep
a roller chain tight with a worm thread tensioner-very little.
Rule number 3.
Oil the chain using good 90 weight oil wiped on with a rag or motorcycle chain lube in the spray can.
If you use the snow blower every day you should oil the chain every couple of days as well as greasing the PTO shaft spiders/crosses/bearings and also greasing the PTO shafts grease fitting(s).
Now as far as the PTO shaft you may have a grease fitting in the yoke as well as a grease fitting in the side of the outer sleeve they both should be greased with 8-10 pumps of grease. for every 8 hours of use.
pump one or two pumps of grease in the tensioner sprocket as well every 8 hours of use
You need to grease the fittings every couple of days depending on how many hours you use that beautiful made in Quebec snow blower.
The cross shaft open flange bearing needs to be greased as well with a few pumps of grease.
The open flange bearings supporting the snow blowers open auger needs to be greased as well with a few pumps of grease EVERY 8 HOURS of use.
About tools YES, you need to buy the following items:
1 box of #50 roller chain-this is normally a 10 foot length of chain in the box- by the time you buy a smaller length of chain you will pay more for it per foot
than just buying a 10 foot box of #50 chain.
You need to buy:
6 master links.
1 chain breaker for # 50 chain.
1 hand chain tensioner for 50 chain-you need this to pull both ends of the roller chain together to install the master link. You use the tool by placing the tensioning jaws in between the upper and lower flight of the new roller chain to bring the ends of the roller chain together.
You also have to install the master link with the pins facing in. It is easy to do before you lace the chain on the sprockets.
Back the tensioner sprocket off all the way before you lace the new chain on the sprockets as you want enough slack in the
roller chain to move it to put the chain together with the master link using the chain tensioner.
Put the new chain and master link together and then put the master links in the chain box and put the chain tools in the toolbox.
/ Puma-54 Snowblower chain stretching #5
The chain on my blower definitely stretched over time, and I broke it many times when something would get wedged in the auger. After a while you just need to replace it. I compared my old with new and it was quite remarkable how much it has stretched. I always kept a few master links in the tractor so I could get things running again in case of a break. I probably should have replaced the chain much sooner than I did. None of the parts are particulaly expensive, so really no excuse for letting it go so long.
/ Puma-54 Snowblower chain stretching #6
Let me start off by saying pardon my ignorance on the matter, and I apologize in advance, just trying to understand this better. Now that that is out of the way, what is the difference between removing a link or two versus getting a new chain? I am aware visually how sprockets wear down, but how does a chain wear down? I thought that it stretched, hence the need for a new chain or removing a link or two.
I ask as I have a MK Martin Meteor blower and my tensioner gear is nearing the bottom of its adjustment channel as well.
Thank you much folks.
/ Puma-54 Snowblower chain stretching #8
In case anyone else is wondering, the chain doesn't stretch per se, the metal is the metal and does not stretch, but the pins will wear, causing the pitch (length) to expand.
So, as there is the wear in the pins and inner links, it is best to spend the $40 on a new chain, versus taking a link out and still having the wear in the pins and inner links.
Learning morning for me. New chain is ordered. For what it's worth, my blower took a #60 chain.
/ Puma-54 Snowblower chain stretching #9
My round baler is all roller chain driven and the chains get oiled after every use and I've never had any stretch after the initial run in. I use motorcycle spray on chain lube when the chains are warm.
/ Puma-54 Snowblower chain stretching #10
My 25 year old, heavily used snow blower is on the original chain and I've never taken a link out. I have a spare chain in the shop, bought it 20 years ago.....
/ Puma-54 Snowblower chain stretching #12
Once chains stretch/wear, they no longer match the pitch (tooth to tooth) of the sprockets. When that happens, the worn chain quickly wears the sprockets which are harder to replace. Chain is cheap so replace it when needed.
/ Puma-54 Snowblower chain stretching #13
Lube my blower chain using old paint brush and used motor oil.
When the tensioner gets near the limit it’s time to replace the chain, my blower is only 2 years old so I’m not expecting to need to replace the chain anytime soon.
/ Puma-54 Snowblower chain stretching #14
I have a similar style snowblower on my tractor and being **** about details I adjusted the chain as I would on any piece of equipment.
I had no issues with mine (chain) until I decided to give it a good pm which included adjusting the chain per standard practice.
During the first storm the chain broke ☹️. I installed a repair link and it also broke in short order. This happened several times before I realized what’s was happening. If the chain is adjusted per standard practice you are not allowing sufficient clearance for the snow gets compressed into ice between the chain & sprocket.
This ice buildup makes the chain rise higher on the sprocket putting incredible stress on the chain breaking it. General use roller chain has a breaking strength of approximately 25,000 Lbs.
The solution is to loosen the chain beyond what you feel is acceptable allowing a significant amount of sag. Counter intuitive the the norms.
No more problems!
90cummins
/ Puma-54 Snowblower chain stretching #15
That alone is the major reason roller chain should be
outside the cross auger housing and behind a guard
as it would solve so many problems and improve
ease of access speed repairs.
It would be worth every penny to change the worm
tensioner with a rubber torsion arm sprocket tensioner
but it would not be useable with a roller chain and
sprocket assembly mounted in the cross auger housing
unless it was behind a shield covering the roller chain
and sprockets.
If the snow blower manufactures used idler sprockets to support the roller chain
in the lower flight the snow blowers would have fewer chain problems as they
would support the roller chain and reduce roller chain sagging, twisting and vibration.
www.youtube.com/watch?v=5mKuus4W0b4
I have no idea why the link will not work BUT if you type reist snow throwers in the search
bar it will go right to it and it will show their snowthrowers in great detail.
/ Puma-54 Snowblower chain stretching #16
Right, also
Some better quality chains are pre loaded/pre stretched from the factory. That avoids initial run in elongation by the user
Diamond and others pre load /every chain
Then as you posted there is worn out
/ Puma-54 Snowblower chain stretching #17
The pins and the rollers wear and the strap plates will stretch.
