5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 28,967
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
If you don't lube them, they fail quickly. Just common sense to me.
Once chains stretch/wear, they no longer match the pitch (tooth to tooth) of the sprockets. When that happens, the worn chain quickly wears the sprockets which are harder to replace. Chain is cheap so replace it when needed.
In case anyone else is wondering, the chain doesn't stretch per se, the metal is the metal and does not stretch, but the pins will wear, causing the pitch (length) to expand.
So, as there is the wear in the pins and inner links, it is best to spend the $40 on a new chain, versus taking a link out and still having the wear in the pins and inner links.
Learning morning for me. New chain is ordered. For what it's worth, my blower took a #60 chain.
