Bearing removal
/ Bearing removal #1
gmk5150
Member
mitsubishi
I have 2017 branson 3520cx tractor...the bearing on front axle is shot on piinion shaft i was able to seal out...now bearing stuck on shaft...Any suggestions how to get it out..thank u
/ Bearing removal #3
I thought you talking about the kingpin?
I welded a nut onto mine and used a cheater bar on a socket wrench.
/ Bearing removal #4
I think this is what you are talking about. There is a snap ring behind the bearing. Looks like if you took a block of wood and place it on the shaft and tap it with a hammer the bearing would come off. See screenshot below. Hope this helps.
/ Bearing removal #5
Better problem definition is needed.
/ Bearing removal #6
These may help:
Also if you don't have the service manual there's some in a sticky thread in the Branson section of this site.
/ Bearing removal
Think ur saying hit pinion from front...and snap ring might break...i cant get to snap ring from front it blocked by seized bearing
/ Bearing removal #8
Yes I am saying put a piece of wood on the end of the shaft and tap the wood with a hammer. The snap ring should not break. The snap ring would hold the bearing and shaft should go inside the housing. Then you can remove the bearing.
/ Bearing removal
Im confused where to pound on shaft...from front of tractor or rear...im sorry.
/ Bearing removal
Im confused how shaft can go it..dont it rest on ring gear lol im 80 yrs old maybe time give up tractor repair...thank u kindly
/ Bearing removal #11
I like the word tap. Lol But tap on the end of the shaft driving it into the housing. See arrow on drawing below.
/ Bearing removal #12
I believe it should rotate off the ring gear as it goes in. That is why tap is better than pound. Lol
/ Bearing removal
Omg understand now i try later..ur the best thank u
well i tapped for 10 mins shaft never moved to front..pounded few times..how far should it Move...thank u for assistance
/ Bearing removal
I also took 3 bolts off pinion at front of tractor
/ Bearing removal #15
Is there a way you can post a picture of the bearing and shaft? I would not think it would need to move much before the bearing gets free.
/ Bearing removal #16
You may have to remove the differential case first. I was hoping it would move in enough to free the bearing.
/ Bearing removal
Think i got bearing out but i dont see no c clip to get shaft out..less still part bearing left in..i had to split bearing to get out..lol i might be over my head
/ Bearing removal #18
It definitely looks like the outer race is still in there. You may be able to pull it with a slide hammer but catching just the race and not the snap ring will be a challenge.
/ Bearing removal
Thank so much for help only 193 hours on...strange bearing go fast
/ Bearing removal #20
I agree with that! Wonder what type of oil was used in the front end?
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
296385 (A57192)
296385 (A57192)
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
17601CFL (A59228)
17601CFL (A59228)
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
