Bearing removal
/ Bearing removal #1
gmk5150
Member
mitsubishi
I have 2017 branson 3520cx tractor...the bearing on front axle is shot on piinion shaft i was able to seal out...now bearing stuck on shaft...Any suggestions how to get it out..thank u
/ Bearing removal #3
I thought you talking about the kingpin?
I welded a nut onto mine and used a cheater bar on a socket wrench.
/ Bearing removal #4
I think this is what you are talking about. There is a snap ring behind the bearing. Looks like if you took a block of wood and place it on the shaft and tap it with a hammer the bearing would come off. See screenshot below. Hope this helps.
/ Bearing removal #5
Better problem definition is needed.
/ Bearing removal #6
These may help:
Also if you don't have the service manual there's some in a sticky thread in the Branson section of this site.
/ Bearing removal
Think ur saying hit pinion from front...and snap ring might break...i cant get to snap ring from front it blocked by seized bearing
/ Bearing removal #8
Yes I am saying put a piece of wood on the end of the shaft and tap the wood with a hammer. The snap ring should not break. The snap ring would hold the bearing and shaft should go inside the housing. Then you can remove the bearing.
/ Bearing removal
Im confused where to pound on shaft...from front of tractor or rear...im sorry.
/ Bearing removal
Im confused how shaft can go it..dont it rest on ring gear lol im 80 yrs old maybe time give up tractor repair...thank u kindly
/ Bearing removal #11
I like the word tap. Lol But tap on the end of the shaft driving it into the housing. See arrow on drawing below.
/ Bearing removal #12
I believe it should rotate off the ring gear as it goes in. That is why tap is better than pound. Lol
/ Bearing removal
Omg understand now i try later..ur the best thank u
well i tapped for 10 mins shaft never moved to front..pounded few times..how far should it Move...thank u for assistance
/ Bearing removal
I also took 3 bolts off pinion at front of tractor
/ Bearing removal #15
Is there a way you can post a picture of the bearing and shaft? I would not think it would need to move much before the bearing gets free.
/ Bearing removal #16
You may have to remove the differential case first. I was hoping it would move in enough to free the bearing.
/ Bearing removal
Think i got bearing out but i dont see no c clip to get shaft out..less still part bearing left in..i had to split bearing to get out..lol i might be over my head
/ Bearing removal #18
It definitely looks like the outer race is still in there. You may be able to pull it with a slide hammer but catching just the race and not the snap ring will be a challenge.
/ Bearing removal
Thank so much for help only 193 hours on...strange bearing go fast
/ Bearing removal #20
I agree with that! Wonder what type of oil was used in the front end?
iDrive TDS-2010H...
2020 Kubota KX057-4 Mini Skid Steer (A61166)
2020 Kubota...
Kubota L3901HST
Kubota L3901HST
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2012 Ram 1500 4x4...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
