John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,748
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
As the owner of the TC33D that broke at the clutch housing, I can tell you that it had nothing to do with the backhoe. The backhoe has not even been on the tractor in over 10 years, and was used lightly and rarely before then. My break was likely due to extensive loader work (I was attempting to dig out a small stump when it finally let go all the way, though the evidence shows that the crack had started a while ago.) My tractor is really too small for the logging I have been doing with it. I'm careful, but after 21 year of that use, apparently I'm not careful enough. As we were disassembling the tractor for repair, we found a couple of bolts that had worked loose, and one of the loader mount bolts was broken. Those loose bolts are the kiss of death when you are working these tractors hard.
Problems with cracked transmission or clutch housings are a known issue with these tractors (which is exactly why I have the backhoe subframe on it, even though I don't really use the backhoe: The subframe provides a lot of reinforcement.)
The ONLY way I wold use a backhoe on a compact tractor is with a subframe (I suppose there may well be some models that can handle it, but why chance it.) There are a number of CUTs that when equipped with a well-designed subframe can handle an appropriately sized backhoe, you just have to use some common sense when operating it. If you are picking up the tractor and slamming it around, you are abusing it and it's likely you will eventually have problems. Stump duty is one of the tougher jobs.
A CUT with a backhoe can do a lot of work, but having used a mini excavator (my neighbor owns one), I can tell you that I will not buy a backhoe for my new tractor. If my neighbor sells is mini excavator, I'll just rent one. Anything I can do with a backhoe on a cut, I can do easier and quicker with a mini excavator. Renting a mini ex for the few times I might need it is far less expensive than buying a backhoe and subframe.
