Do These Actually Work...
/ Do These Actually Work... #41
I use the Stihl sharpening tool. I was skeptical at first but after I bought one, and watched a video on YT, I love it!!!! It's fast, easy and gets the chain very sharp. It also maintains the height relationship between the cutting teeth and the raker teeth (aka heigth gage). Watch a video on it and you'll understand better. It's about $30 and you should get some spare round files but they are only about $3 each. Highly recommend this tool. I have the electric chain sharpener you get from Northern Tool but this far easier.
/ Do These Actually Work... #42
Seems that there is a flood of these sharpening tools for sale on i-net last few days, do they actually work..... Concept looks good, just can not believe its a quality produce for the $29 to $49 price sellers are asking, down from $79......
Other question is has many "sellers" seized on these as a "scam" to get you to order and they never deliver?....
And no I'm not really going o buy...
This is actually a Chinese Knock Off of a GAMN Sharpener patented in the '80'. I had a GAMN that did work, but I put the Carbide burrs in a battery drill and cut the teeth. At least this didn't burn the teeth. I don't know about these knock offs. Patent must have run out! Picture shows one on eBay currently.
/ Do These Actually Work... #43
So, I bought one on a lark- it works, barely and is certainly not an improvement over either a file with a guide or my Dremel chainsaw sharpening attachment.
Minor correction- the “ratcheting” feature is an improvement over either of my other sharpening tools.
/ Do These Actually Work... #44
I use a regular chain grinder in my shop, its fast and accurate. Tried that round stone once and it lasted about 5 min. I charge 3.00 off and 7.00 on. I retired but still have people coming in.
/ Do These Actually Work... #45
I use the Stihl sharpening tool. I was skeptical at first but after I bought one, and watched a video on YT, I love it!!!! It's fast, easy and gets the chain very sharp. It also maintains the height relationship between the cutting teeth and the raker teeth (aka heigth gage). Watch a video on it and you'll understand better. It's about $30 and you should get some spare round files but they are only about $3 each. Highly recommend this tool. I have the electric chain sharpener you get from Northern Tool but this far easier.View attachment 773721
Yep, couldn’t agree more. It’s fast and works incredibly well.
Mike
/ Do These Actually Work... #46
I've tried a lot of sharpeners, but the only one that has given consistent results is the Stihl 2 in 1.
/ Do These Actually Work... #48
For a light touch up just use a file, but it takes practice to hold the correct angle and pressure - practice on an old chain for a while. As stated by others - a Dremel tool attachment is a good option, you can change depth or size of stones for different chains. Again it takes practice to get it right - there are some absolutely terrible videos out there on this, completely ass-backwards demonstrations. Do it right and you'll be pleased with the results. Personally I've used a Dremel for probably 20 years.
/ Do These Actually Work... #49
I don't see how that cranked thing could do much. Stones need to turn fast to do the job. Although I always have a file with me, and can touch up sitting on the ground with the saw facing me, I have an Oregon 12v that I put a trailer plug on and use it on my tailgate (if the truck is near).
/ Do These Actually Work... #50
Def looks like a Timberline, right down to the color. I have a timberline and like it. I don't sharpen often enough to get good at the technique so it makes it really easy to always get good results. Not cheap, but a high quality tool. Not for everyone, but it does a good job. As for the knock off, it might work fine. I'll stick with the Timberline though. I have multiple carbide cutters for it to use for all my saws.
/ Do These Actually Work... #52
Not sure how much you use your chainsaw but if I did not know how to sharpen a saw I would
1, learn the fundamentals of what is needed to make a chain cut. And what is needed to allow the bit of the chain to cut. Don't forget to find out what happens when you get either wrong and how to correct the mistake
2, When I have dulled[not destroyed]the chain. Then I would take the time to sharpen it.
You will both learn patience and formulate some method of keeping your chain out of the dirt/how to keep your chain sharp......"repetition makes muscle memory practice makes perfect"
That said....I am cheap and would need to run into some serious anger management issues before I resorted to a gadget such as this to sharpen anything even a relatively complex cutting device as a power saw chain is sharpened easily once it becomes habit
/ Do These Actually Work... #54
For me, I run a Stihl hand file sharpener through my chain before using it for the day. I get good chips out of the chain, and it remains sharp for the day.
This is pretty much it. If you keep it sharp with a file, it’s never going to get dull enough to need to grind on it.
You are keeping the edge vs creating it.
/ Do These Actually Work... #55
Yes, but not really. Some of us hit rocks and its always on one side. Now you got lots of material to remove so right and left cutters still match.
/ Do These Actually Work... #56
If that happens then a grinder makes for quick and easy repair of the damaged cutters. Much faster and less work than hand filing.
/ Do These Actually Work... #57
My Stihl dealer will sharpen a chain for $5 including adjusting the depth guides if needed. I use him exclusively. I own half a dozen chains for each saw. Always have a supply of sharp chains available.
Mine was an Ace Hardware that had a sharpening service. I started taking them there to be sharpened. One day, decided a specific tree (within distance of hitting house should it fall the wrong direction) needed taken down. Started sawing and the tree settled, pinching my bar.
Fine... I have an extra bar & chain this very circumstance. Got tools, removed powerhead from bar, put other bar and freshly sharpened chain.... and the freshly sharpened chain would cut melted butter. They neglected or forgot to file the rakers. Chain was useless. Wife's cousin next door....saw was down. Called brother in law, he said he'd come over "later" to see if he could help.
I decided to run into town, get replacements and come back to finish....meanwhile, I had the first cut of my wedge cut meaning the tree was cut something like 1/3 into the face with my bar sticking out.
As it happened, by the time I returned, my brother in law had arrived. He brought his saw and had dropped the tree before I returned.
I've never had anyone else sharpen my blades since then..... AND (if you've seen my comments elsewhere) this is another reason why I like the idea now of just digging part of the root ball and using my backhoe to push the tree over.
/ Do These Actually Work... #58
Yeah, I hate people that make mistakes. 😁
/ Do These Actually Work... #59
Well, it’s a lot harder to keep chains sharp trying to saw rocks as they are not designed to do so.
One of these will help keep you from sawing rocks.
Then you don’t have grind away the rest of the cutting edges on your chain when you mangle one with something it can’t cut.
”stuff happens” though thus the “this is pretty much it”, leaving room for exceptions that can at least keep a blade useful vs trash when mr. Murphy makes your chain eat rocks.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
