/ If it's cold where you live, what are you heating with and what is it costing?
#282
5030
Rest in Peace
- Joined
- Feb 21, 2003
- Messages
- 28,967
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
The issue with that is, your electricity rates keep going up so the higher they go, the more it costs to glean those BTU's. Both of my biomass stoves are 85% efficient. I'm good with that and our new Bryant condensing furnace is rated at 95% efficient.Others have mentioned it, but no smoke and mirrors.
Dont confuse efficiencies of various heating methods with cost.
Wood, propane, and fuel oils are never 100% because they exhaust. That exhaust is wasted heat.
Electric resistance is no waste. Dont matter if its ceramic, quartz, infared, your oven, a blow dryer, or a light bulb. With electricity, one watt produces 3.414 btu's of heat.
With refrigerant and a compressor, we can generate 9 or 10 btu's of heat for watt of input. So hence 300% eff. Its a simple way of saying its can produce 3x the heat on the same electric usage (or the same heat on 1/3 the usage).
