If it's cold where you live, what are you heating with and what is it costing?
   / If it's cold where you live, what are you heating with and what is it costing? #291
I’d like to see a btu cost breakdown with that as well. In my experience if natural gas is available you should burn it because it’s typically the cheapest bought fuel.
Closest I can find googling is ~$300/ton and 16.5M BTU/ton..
@85% efficient, that works out to $21.39 per million BTU
Heres how that compares in my area:
1. Heat pump.....300% eff.........$0.14/kwh........$13.67/Mbtu
2. Firewood.........70%eff...........$250/cord........$14.88/Mbtu
3. Biomass..........85% eff.........$300/ton...........$21.39/Mbtu
4. Propane...........95% eff..........$3.25/gal........$37.45/Mbtu
5. Elec Resistance..100%eff.........$0.14/kwh......$41.00/Mbtu
   / If it's cold where you live, what are you heating with and what is it costing? #292
Can you find those stats for other areas of the country, like far north, far south, etc.? I'm still on the fence about heat pumps when it's below zero.
   / If it's cold where you live, what are you heating with and what is it costing? #293
Just this year I put in two geo thermal wells at the house in steamboat, not really to keep it warm, but to melt the driveway. I also put in a new driveway and sidewalks with pex. I don't have a year under my belt to see what temp beyond the natural temp the geo thermal produces to melt all the snow. The contractor suggested I just circulate the water, which is around 55*, to see how it works. I think once the cold really sets in, I will have to have the boiler come on to maintain this. I was paying about 10K a winter for snow removal. The last few years it's been a pain to find a reliable snow removal company that does a good job. That is what really prompted me to go to this set up. I should break even on the cost of the well and concrete in about 8.5 years. I also have a wood stove for when I'm there. Nothing dries out wet ski clothes than a nice dry fire.
At the ranch it's propane and wood heat.
At the city house, it's natural gas heat.
At the cabin...it's wood heat only.
   / If it's cold where you live, what are you heating with and what is it costing? #294
And whats mind blowing to me, is I know people who build a house, and either set it up for propane or wood heat....but still install an air conditioner. IF you are already installing an air conditioner....I dont understand the logic to NOT go ahead and make it a heat pump. The cost difference is very minimal. And at temps above 40°, I dont think there is any cheaper way to heat (as long as your in an area that has reasonable electricity rates)
For real. My buddy next door puts up to three window A/C units into his house every summer (his winter heat is combo of woodstove and propane furnace). I tried to show him how easy it was to install my $2200, 24k BTU MrCool heat-pump mini-split. We use it for heat whenever its above 40f outside, if needed (pretty rare) but obviously it is primarily for luxuriously-capable, whole house air conditioning. Still pumps great heat out at 20f outside temps, but probably sucks 1500-2000 watts to do that.
Regarding "cost of everything goes up" for comparing heat sources... uh, well no, my chainsaw gas is only $3/gallon still LOL. Sorry, sorry, not starting that again.
   / If it's cold where you live, what are you heating with and what is it costing? #295
I would have no idea where to find those stats.
Look on craigslist and market place and see what a cord of wood is bringing in your neck of the woods.
Look at your electric bill. What Cost / kwh usage will get you your electric rate.
Same for propane and other sources. Then its just becomes simple math...
But regarding a heat pump....down to 0°F, air to air isnt gonna be efficient at those temps. Alot of variables based on the cost of both electric and other fuel options....but once you go below freezing.....other sources of heating start to become more efficient than a heat pump.
But as long as loops are properly sized, Geo dont care if its zero outside. Its still gonna be cheaper per BTU. So when you say on the fence about "heat pumps", are you talking air to air or geo?
   / If it's cold where you live, what are you heating with and what is it costing? #296
Both. I'm concerned that to air isn't going to work in our cold when we need it most. Almost certain of that. Geothermal installation price I'd have to look at the return on investment. We're currently running a 30+ year old gas furnace that seems to be working well.
   / If it's cold where you live, what are you heating with and what is it costing? #297
I agree with the natural gas.
Dont know current pricing....so dont know if its still holds true.....but in my area NG has always been the cheapest energy. And that anyone with it available, usually had NG heat, as well as stove, water heater, and dryer.
Where as propane.....is real close to electric in terms of cost per BTU if you average it out over a decade or so. Some years is cheaper, some years its more. Like just a few years ago when propane was ~$1/gal......and now its like $4. But thats where a electric heatpump/furnace with propane backup is the best "labor free" heat if you dont have nat gas. Then on the years when propane is dirt cheap like a few years ago....just switch the t-stat to emergency heat and dont let the electric run. On years when propane is high....let the electric do all it can.
But regardless of wood, pellets, natural gas, or anything else.....its VERY hard to beat the efficency (cost per BTU) of a heat pump. And that dont matter if its geo or air source.
In Fall and Spring we use our HVAC air to air heat pump. When we start seeing ice on the ponds we crank up the floor heat. Reverse in the Spring.
   / If it's cold where you live, what are you heating with and what is it costing? #298
Here is a calculator for the cost vs efficiency - copy and paste into excel and adjust for your local area and heat source.
ENERGY COST CALCULATOR
Enter the costs in Column E below for the various fuels in your area, or just use
the numbers already listed.
FUELENERGY CONTENTUNIT PRICEHEAT CONVERSION EFFICIENCYCOST PER MILLION BTU
Kerosene
130,000​
BTU/gal
$4.05​
/gal91%$34.23
#2 Fuel Oil
135,000​
BTU/gal
$4.00​
/gal89$33.29
Propane
92,000​
BTU/gal
$2.69​
/gal94$31.11
Natural Gas
100,000​
BTU/therm
$1.79​
/therm*94$19.04
Electricity - Resistance
3,412​
BTU/kWh
$0.34​
/kWh**100$99.65
Electricity - Heat Pump
11,945​
BTU/kWh
$0.34​
/kWh**100$28.46
Coal
13,200​
BTU/lb
$300.00​
/ton75$15.15
Firewood-Hardwood
25,000,000​
BTU/cord
$375.00​
/cord60$25.00
Wood Pellets8,200BTU/lb$350.00/ton85$25.11
Shelled Corn
6,800​
BTU/lb
$6.00​
/bushel75$21.01
   / If it's cold where you live, what are you heating with and what is it costing? #299
Kerosene
130,000​
BTU/gal
$4.05​
/gal91%$34.23
#2 Fuel Oil
135,000​
BTU/gal
$4.00​
/gal89$33.29
Propane
92,000​
BTU/gal
$2.69​
/gal94$31.11
Natural Gas
100,000​
BTU/therm
$1.79​
/therm*94$19.04
3,412​
BTU/kWh
$0.34​
/kWh**100$99.65
11,945​
BTU/kWh
$0.34​
/kWh**100$28.46
Coal
13,200​
BTU/lb
$300.00​
/ton75$15.15
Firewood-Hardwood
25,000,000​
BTU/cord
$375.00​
/cord60$25.00
Shelled Corn
6,800​
BTU/lb
$6.00​
/bushel75$21.01
Your electric rates are brutal at $0.34/kwh
   / If it's cold where you live, what are you heating with and what is it costing? #300
Yes they are - just went from .22 to .34 in August due to cost of fuel
Also, here is a link to the calculator where you can download the excel file.
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
Box of Transport Ratchet Straps (A55851)
Box of Transport...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
199049 (A51243)
199049 (A51243)
Sterling AT (A55301)
